Murt Samba Member
Joined: October 01, 2017 Posts: 306 Location: Kent, England
Posted: Sat Mar 23, 2024 2:00 am Post subject: VS v CSP Exhaust |
Chaps, after some quick advice if I may ? pros and cons etc.
Exhaust system for a stock AD 1600DP in a 67 Splitscreen, (No Heat) both roughly the same cost, which would you choose and why ? CSP or Vintage Speed ?
Cheers
_________________ 1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi |
richparker Samba Member
Joined: November 24, 2011 Posts: 6989 Location: Durango, CO
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7233 Location: Videbaek Denmark
Posted: Sat Mar 23, 2024 7:11 am Post subject: Re: VS v CSP Exhaust |
If you are after rpm power, take the sidewinder. If you are after better power in the driving rpms, take the VS. and preferably the SS143 version. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3296 Location: Rapid City, SD
Posted: Sat Mar 23, 2024 7:29 am Post subject: Re: VS v CSP Exhaust |
That sidewinder is just an AA performance. It will drone really bad, and they are quite loud in a bus. I have one on my shorty now. Not by choice…. It will also induce the “sidewinder dip” and make tuning difficult.
I always vote VSpeed, although a little overkill for a stock engine, they are very nice, make good power, and last a long time.
Brian _________________ www.type-emotorsports.com |
Posted: Sat Mar 23, 2024 8:43 am Post subject: Re: VS v CSP Exhaust |
Brian_e wrote: |
That´s part of the "fun" with a Sidewinder
On a stock engine the afr dip is typically almost not evident, because the intake is a little restricted and the cam overlap is minor.
Brian |
sled Samba Member
Posted: Sat Mar 23, 2024 9:00 am Post subject: Re: VS v CSP Exhaust |
absolutely I would choose the Vintage Speed classic sport over any sidewinder
they sound better, the packaging is much tighter (removing muffler to adjust valves is annoying), and more appropriate for a stock engine
oh and they look better _________________ drive your split. |
