steve244 Samba Member
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32647 Location: Reading Pennsylvania
E1 Samba Member
Joined: January 21, 2013 Posts: 6611 Location: Westfalia, Earth
Posted: Sat Mar 23, 2024 7:28 am Post subject: Re: It liiiiiiiiiiiiiivesssss |
Great Steve, Congrats!!! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
brickster Samba Member
Joined: January 05, 2004 Posts: 512 Location: CO, USA
Posted: Sat Mar 23, 2024 8:38 am Post subject: Re: It liiiiiiiiiiiiiivesssss |
Sounds great, congrats! _________________ 1984 Campmobile Automatic |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 786 Location: WestWorld Nanaimo BC
Posted: Sat Mar 23, 2024 9:33 am Post subject: Re: It liiiiiiiiiiiiiivesssss |
E1 Samba Member
Posted: Sat Mar 23, 2024 9:36 am Post subject: Re: It liiiiiiiiiiiiiivesssss |
^^^ That’s one fine documentary. FACT. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
pathao Samba Member
Joined: November 01, 2012 Posts: 291 Location: Montreal, Canada
Posted: Sat Mar 23, 2024 10:34 am Post subject: Re: It liiiiiiiiiiiiiivesssss |
Nice Work
I do like that muffler/exhaust pipes setup
steve244 wrote: |
I promise to treat her better. |
CHT is your (her) friend _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
tjet Samba Member
Posted: Sat Mar 23, 2024 1:33 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
Sounds like my '77. Those Type 4 motors are great engines. |
Xevin Samba Member
Posted: Sat Mar 23, 2024 2:23 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
Congratulations Steve. Looking good. What wideband meter do you use for dialing that in? I need to suck it up and get my own.
Enjoy. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
space Samba Member
Posted: Sat Mar 23, 2024 2:41 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
Got that Doc Brown Vibe going on
Good to see its back on the road! _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
Posted: Sun Mar 24, 2024 9:02 am Post subject: Re: It liiiiiiiiiiiiiivesssss |
How did you kill the original?
Best to set your timing at 28° BTDC @3800+ rpms, hoses off and plugged. If you have a retard can, do not reinstall the hose to it, if the can does not hold vacuum, but leave the hose plugged off. |
Posted: Sun Mar 24, 2024 3:14 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
It lost compression in one cylinder. Intake seat came -er- unseated.
But it still wouldn't run on 3 cylinders except above high idle. It would start cold then die at idle and refuse to start.
I've got the new engine in tune for dwell and timing and it runs well above idle.
At idle it eventually stalls. Bwahahahaha.
Several people (I'm lookin' at you xevin) suggested using a wide band AFR meter. To my joy this is a brilliant bit of kit. After 2 days installing, it indicates once warm the AFR goes to 21. Way too lean. Turning the mixture screw has no effect, peg to peg.
At 1500 or above AFR hovers around 14-16.
I think this is what left us stranded in FL. Well that and the overall state of the engine.
I'm going to do some reading and thinking. I predict either a new AFM or controller. Or both. Any suggestions? _________________ 82 AC vanagon approx 200K miles (3K are mine).
DD is a 2015 Leaf
Road Trip to Hell (FL 2023)
The Vanagon's drivetrain and chassis restomod thread. Best sung to the tune of I Did It My Way... |
Synergy Solutions Samba Member
Posted: Sun Mar 24, 2024 4:33 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
Check your AAR, it could be stuck open. Fuel injection corp in northern CA can rebuild the AFM, fuel pump, fuel psi regulator, AAR, and injectors. And they can test the CSV. _________________ Im a Mobile Aircooled VW mechanic, and work on old and new cars alike. Specialty in Camper busses/Vans, TDI, and FI diagnosis and repair.
(206) 841 7324 |
Xevin Samba Member
Posted: Sun Mar 24, 2024 4:35 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
Did Brothers do an initial break-in for 20 minutes before they shipped the crate to you? I gotta think they did. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15148 Location: Syracuse, NY
Posted: Sun Mar 24, 2024 7:08 pm Post subject: Re: It liiiiiiiiiiiiiivesssss |
air cooled vanagons are tuned to the lean from the beginning..
so doesn't take much to get them hurting..
do a search and on here there's a 'hack' for lack of a better term that allows you to dial in the AFR via the T-II sensor with a potentiometer at the dash.
here's a thread.. has helped some..
https://www.thesamba.com/vw/forum/viewtopic.php?t=248511 _________________
Abscate wrote: |
