storm Samba Member
Joined: April 28, 2008 Posts: 332 Location: Juneau, Wisconsin
Posted: Tue Aug 20, 2024 4:42 pm Post subject: Cool heads but hot oil temps. |
As the title says. Built a 2110 for a ‘57 Single Cab straight axle, transmission 4.12x .89 4th.
Engine spec: 82 crank,90.5 p&c, Fk 41 cam w/cb 1to 4 rockers, cb magaspark distributor, duel Weber’s IDF 40 with 28 vents, idle jets 50, not running main stacks only idles.
Head temps 270 degrees, oil temperature 225 verify with candy thermometer.
78 degree temp day going 35-40 miles per hour in 3third and sometimes 4th in a hilly area.
Doghouse fan and all tin present. Hover bit on cooler.
Also full flow with oil filter and external oil cooler w/fan 30mm oil pump.
IGN timing started w/ 32, 30, 28 no change.
Did stomp on gas pedal to see if engine pinning, nothing noted.
Thought it could be starving for air, because the original engine was a 36 horse. Droves vehicle with rear lid off, no change.
Engine lid is bent on the bottom with a 2 inch gap to the body gasket.
Did put a plastic cover over the engine opening to seal- no change, but oil temp got hotter.
Went up on idle jets to 52,no change. Spark plugs light tan.
Have built many engine this size down to 2 liter and had no problems like this.
I know that oil temps are directly to heads, but with a head temp of 270 degrees where else can be the cause.
I know there has to be reason for these oil temps.
I like to be around 180 to 210 for oil temp and oil pressure 34-40 pounds using 10W40 oil.
Waiting for your comments please. _________________ always ready to learn and give advice |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4066 Location: Rapid City, South Dakota
Posted: Tue Aug 20, 2024 4:49 pm Post subject: Re: Cool heads but hot oil temps. |
If you are running good oil, 225 is not hot at all. I trust my oil, and I have done 235-240 for hours on end in 106deg heat and a headwind.
My '57 single cab seems to make engines run hot as well. Take them out, install in a different vehicle, and they are fine. Early single cabs have the smallest air inlet amount of any of the buses. I think this plays a huge roll when you install a big CC engine.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
b-man Samba Member
Posted: Tue Aug 20, 2024 5:12 pm Post subject: Re: Cool heads but hot oil temps. |
With a single cab you do have the option of pulling cool air from the treasure chest door louvers, at least on a later one like my ‘66. You can cut openings in the 2 removable panels (or space them out at the top) that isolate the fuel tank from the cargo area and then you can pull additional cooling air from those treasure chest door louvers.
The firewall behind the engine is ventilated with large openings so once you cut some louvers or openings in those panels the cooling fan can draw additional cooling air from the treasure chest. Except Brian’s shawty with no treasure chest doors to speak of.
All split buses suffer from lack of engine cooling but I suppose early single cabs more so than others. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15601 Location: Deep in the 405
Posted: Tue Aug 20, 2024 5:17 pm Post subject: Re: Cool heads but hot oil temps. |
225*F oil temps are normal and safe and won't hurt anything.
DO NOT confuse normal 180* water temps of a water cooled engine with normal oil temps. They are 2 completely different fluids.
No way your heads are 270*F normal is 350-375*F. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
richparker Samba Member
Joined: November 24, 2011 Posts: 7557 Location: Durango, CO
Posted: Tue Aug 20, 2024 7:09 pm Post subject: Re: Cool heads but hot oil temps. |
I agree with above, 225° is perfect.
Where is your oil temp sender located and what is the temp of the oil coming out of the external cooler? In my bus set up my sender is located in the T3 block off plate and the oil comes out of the cooler 30° cooler then the gauge says.
In my beetle, the sender is machined into the deep sump. Which produces much different temps then my bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab |
Zed999 Samba Member
Posted: Wed Aug 21, 2024 12:58 am Post subject: Re: Cool heads but hot oil temps. |
"Not running main stacks, only idles"
Hmmm... |
richierich Samba Member
Posted: Wed Aug 21, 2024 1:50 am Post subject: Re: Cool heads but hot oil temps. |
... _________________ Blah.....
Zed999 Samba Member
Posted: Wed Aug 21, 2024 5:28 am Post subject: Re: Cool heads but hot oil temps. |
Head temps look ok for running on idles. Mine get this low at low speed, he's not ever putting any power through the engine without mains but likely running lean trying to keep the speed up feathering the throttle or whatever. Oil temp will get up to running temp eventually, as it has.
All this temp talk seems a bit pointless without the mains though.  |
storm Samba Member
Posted: Wed Aug 21, 2024 7:25 am Post subject: Re: Cool heads but hot oil temps. |
Storm back, thanx for responses. Definitely seems a fresh air issue. b man, between the gas tank and engine bay there is no opening. I would have to take the gas tank out before adding louvers.
Rich Parker, temp is measured at oil bypass valve by crank pulley. I could put the sensor at the flywheel side which would be cooler temperature from the doghouse cooler, but I wanted to what the temp was draining from the heads first.
Zeed999, mains were left out so I can get the idle jet size and check spark plug color. Running a 50 idle jet with the mains in now.
When driving no popping and performance is good up to 55 mph.
Vw racerdave temp is to low your right. I don’t have IR gauge to measure temps, would have to borrow one to verify temp.
Why this temp is important to me is I have other buses that have temps of 190-200 in 90 degree weather. I just feel more comfortable with lower temps, but this time I have a old SC that used a 36 horse motor with less louvers to cool. _________________ always ready to learn and give advice |
RickS Samba Member
Posted: Wed Aug 21, 2024 7:37 am Post subject: Re: Cool heads but hot oil temps. |
storm wrote: |
Why this temp is important to me is I have other buses that have temps of 190-200 in 90 degree weather. I just feel more comfortable with lower temps, but this time I have an old SC that used a 36 horse motor with less louvers to cool. |
190-200 is too low for oil temperature. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4116 Location: San Diego
Posted: Wed Aug 21, 2024 8:24 am Post subject: Re: Cool heads but hot oil temps. |
Assuming oil temp measured is correct, not really any choices for raising it, other than drive faster. My new 1776 runs about 190 in city, 210 on fwy. About 80f outside. Thats measured where it goes back in the case from the full flowed filter. |
b-man Samba Member
Posted: Wed Aug 21, 2024 10:13 am Post subject: Re: Cool heads but hot oil temps. |
RickS wrote: |
storm wrote: |
Yeah I kinda figured that the earlier single cabs would have a solid firewall.
The firewall in my ‘66 has a lot of open area, before I put in my new 2276 I’ll do something to open up some vents in those 2 cargo compartment divider panels. The late single cabs are unique in this way unlike any other early Type 2.
That’s a 20 gallon custom fabricated aluminum fuel tank that you can see behind the firewall.
1957 L41 Black Oval Window Beetle |
Posted: Wed Aug 21, 2024 10:32 am Post subject: Re: Cool heads but hot oil temps. |
Ain't nothin' like that in my Shawty...
I wish there was, and I really wish there was an easy way to get lots more air into ALL bus engine bays.
I ran the numbers comparing a 36hp engine at 4000rpm, to a 2180cc engine at 5000rpm. The piston demand CFM was 1.5 times more for the 2180cc. So in theory, it would need at least 1.5 times more vent area to feed it. And that is only intake engine air, not any added cooling air.
-Modok
b-man Samba Member
Posted: Wed Aug 21, 2024 10:38 am Post subject: Re: Cool heads but hot oil temps. |
Brian_e wrote: |
Brian |
I guess that’s why I see a lot of early buses running around with the deck lid left unlatched and flopped open an inch or so.
Might have to become a part of that crowd myself.
However I’m wondering if the engine will just start recycling hot cooling air from leaving the deck lid unlatched. _________________ 1956 Dove Blue Panel
storm Samba Member
Posted: Thu Aug 22, 2024 6:42 am Post subject: Re: Cool heads but hot oil temps. |
Storm here, we’ll I took the Single Cab out for another drive but this time I left the rear hatch off. An experiment to test air consumption needed.
I tested the head temp guage in hot water an it’s off 15 degrees on the Low side. So head temps are wrong. Either the carbs or the cooling fan are in completing with each other.
With the engine latch off there was more improvement of oil temps.
I now know that my situation is the lack of cool air. Thanks to the responses I received, very helpful.
Solution is to open the area between the rear of the treasure chest and engine firewall. _________________ always ready to learn and give advice |
Posted: Thu Aug 22, 2024 8:31 am Post subject: Re: Cool heads but hot oil temps. |
b-man wrote: |
However I’m wondering if the engine will just start recycling hot cooling air from leaving the deck lid unlatched. |
I couple of years ago I did some testing on my baywindow during one of our road trips. I hung the pickup for a cordless indoor/outdoor thermometer in the engine bay, and put the display up front with me. It was hung with a zip tie, opposite the battery.
Running down the highway, the engine compartment air would be about 10-15 degrees warmer than outside air, regardless of the outside temp.
Then I put a tennis ball over the latch, and a bungie cord to hold the lid down. So it was propped about 2" across the bottom of the decklid. The engine compartment air stayed pretty consistent with the outside air temp. regardless of outside temp.
What DID change with the deck lid propped... as expected... was slow moving traffic, or sitting at a stoplight or drive thru. The engine compartment temps went WAY up, quite quickly. Like 20+ degrees more than outside air temps from the time I got off the highway, till I out of the drive through with my food.
So, as expected, recirculating the hot air is a big deal.
Need to make a motorized, automated latch that opens the deck lid above 30mph, and closes it when going slow. Or just figure some other way to get large amounts of cool air in there on ALL buses. Sled and I have chatted quite a bit about this over the years.
-Modok
94touring Samba Member
Joined: October 24, 2020 Posts: 544 Location: Tulsa - OK
Posted: Thu Aug 22, 2024 9:42 am Post subject: Re: Cool heads but hot oil temps. |
On my early bus vent paneling, I've had good luck with these. Run them during the summer. You can tell the engine bay is cooler when you open the deck lid.
https://www.justkampers.com/earz-engine-bay-air-intake-vw-t2-split-1964-1967.html
They make them for baywindows too, but not sure how effective they'll be in comparison. |
74 Thing Samba Member
Posted: Thu Aug 22, 2024 10:13 am Post subject: Re: Cool heads but hot oil temps. |
I did this test in my Thing about getting enough air into the engine compartment.
Go to your local hardware store and purchase 20 or so feet of small 1/4" nylon tubing. Secure one end in the engine compartment and run the hose out the air vents and into a side window and up to the passenger seat. Take a small water bottle and slit the top and put the other end of the nylon tube in there. If water is sucked upwards into the tube when the engine is on then you need more air.
You may have to modify the engine tin that goes over the trans or do something with the decklid, but if the carbs are taking the air then the fan is not getting enough and visa versa. |
Posted: Thu Aug 22, 2024 10:28 am Post subject: Re: Cool heads but hot oil temps. |
In a consumption race between carbs and the fan, who is going to get the majority of air available?
Or is it simply split? |
Posted: Thu Aug 22, 2024 10:31 am Post subject: Re: Cool heads but hot oil temps. |
Back in the 80's & 90's when Gene Berg was still popular lots of folks ran vent scoops on the side of their early Busses to help engine cooling. Today you rarely see them. Berg also noted the engine on a Bus ran a lot hotter when the side windows were rolled down because it disrupted airflow to the rear engine vents. I don't remember exactly the reason but running a roof rack also effects engine temps. It's time we go back 30-40 years and revisit some of the long lost common practices.
On a Bug the old Herrod Helper is another long lost secret that needs to make a comeback. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
