Spark Plug Heat Ranges
Max Welton
Max Welton is offline
PostPosted: Sun Jun 01, 2025 3:06 pm    Post subject: Spark Plug Heat Ranges Reply with quote
On my very mild 1776, I'm running NGK D6EA plugs. I have no complaints but curious what are the pros and cons of going up or down in heat range when I buy fresh plugs.
https://www.ngk.com/ngk-spark-plug-numbering-systems
Max
1967 Type-3 Fastback
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Sun Jun 01, 2025 3:25 pm    Post subject: Re: Spark Plug Heat Ranges Reply with quote
It will run like crap and misfire. Cold plug's are for High CR Or boost engines.
Plugs need to match the engine build. They are not used to correct tuning issues. 5 heat range might melt on ACVW 6 is a good range. I'm going to try a 7 on my new top end with 9:1 CR but its probably to cold.
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
Last edited by DesertSasquatchXploration on Sun Jun 01, 2025 3:50 pm; edited 1 time in total
Max Welton
PostPosted: Sun Jun 01, 2025 3:46 pm    Post subject: Re: Spark Plug Heat Ranges Reply with quote
I'm not trying to cure a problem. My choice of heat-range was pretty much a wag to begin with. Just wondering what I could expect from stepping up or down one number. I assume your input was directed at going too cold. What about going up in heat (numerically lower with NGKs) one number?
Max
daveblank
daveblank is offline
PostPosted: Sun Jun 01, 2025 6:59 pm    Post subject: Re: Spark Plug Heat Ranges Reply with quote
Max
If you go to a hotter plug than you need it could lead to the engine running hotter or some pre-ignition. If yours are good, I would leave them.
1 question on how you're reading your plugs. Are you doing an actual "plug chop" or are you simply pulling them out after normal driving. Everybody does it differently, I was taught the chop so that's how I do it.
Max Welton
PostPosted: Sun Jun 01, 2025 7:35 pm    Post subject: Re: Spark Plug Heat Ranges Reply with quote
As I've been doing a lot of work to dial in my fuel map, I've just been looking at them after normal driving. Then I clean them, make some adjustments and drive some more.
I may just leave them as is.
Max
halfassleatherworks
PostPosted: Mon Jun 02, 2025 9:04 am    Post subject: Re: Spark Plug Heat Ranges Reply with quote
daveblank wrote:
Max
Your reference to "plug chop" Is that in reference to doing a full power pull and then killing the Eng. to get a true look at how the plug is doing??
67rustavenger
67rustavenger is offline
PostPosted: Mon Jun 02, 2025 10:17 am    Post subject: Re: Spark Plug Heat Ranges Reply with quote
halfassleatherworks wrote:
daveblank wrote:
Max
Short answer, Yes you are correct.
Do a full throttle pull and shut the engine off and coast to the side of the road pull some plugs to see what the plugs look like.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
daveblank
PostPosted: Mon Jun 02, 2025 12:11 pm    Post subject: Re: Spark Plug Heat Ranges Reply with quote
daveblank wrote:
Max
Yes, kill the engine while still under power. It's a pain to pull over & pull a plug though.
runamoc Premium Member
runamoc is offline
PostPosted: Mon Jun 02, 2025 1:14 pm    Post subject: Re: Spark Plug Heat Ranges Reply with quote
from my research, the 'curved' electrode will tell you if you have the right heat range. If lower half of that electrode closes to the threads is tan and the rest is black you have the right heat range plug.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
