TheArmand Samba Member
Joined: May 11, 2016 Posts: 92 Location: Santa Monica
Posted: Sun Jan 01, 2017 8:25 pm Post subject: Westfalia Cabinet Catches - Suitable Replacement Found |
Hey all,
Upon my decision to use Westfalia latches on my custom cabinets for my passenger van conversion, I had to figure out how to source the catches, or at least figure out a suitable replacement. After searching quite a bit it seems that these catches are simply NLA, at least in the states (if you know otherwise please do tell).
Here are some photos of the OEM catches for reference:
During a trip to a Rockler store today, after scouring their catches, I found this item, linked here: http://www.rockler.com/ball-catch
This is the only catch I've found that has come close. The bend in it is correct, and although quite small, is a very sturdy piece of metal with zero flex. The single screw with dual tang attachment points is a bit lacking to the original 3 screw attachment, but this should be more than sufficient for regular use (sans catastrophic accident), especially if you're using quality 3/4" baltic birch for your face frame.
To keep things safe in the event of an accident, a second ball catch can be installed on the lower end of the cabinet door, so the forces can be distributed to two catches. This will require a little tug to open the cabinet door (to compensate for the actual ball catch, which has quite a stiff spring), instead of an effortless opening, but should give a nice solid feel to the door.
Hopefully this helps others who find themselves in my shoes, cause I sure didn't find **** anywhere online about this! _________________ 1988 2.1 Vanagon GL - North American High Top - Custom P22 Inspired "Nahtfalia" Edition Camper |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8474 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jan 01, 2017 9:46 pm Post subject: Re: Westfalia Cabinet Catches - Suitable Replacement Found |
I could see cutting/bending up a handful of these from scrap
sheet metal (think furnace duct) in 30 minutes or less...???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
sak94 Samba Member
Posted: Sun Dec 22, 2024 9:39 pm Post subject: Re: Westfalia Cabinet Catches - Suitable Replacement Found |
I too liked the idea of maintaining the westy style cabinet door latch throughout the van. I discovered that binder clips actually have the perfect shape for a catch. You'll probably only yield one latch catch per binder clip but it really does seem to work well. |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 980 Location: Sammamish, WA
Posted: Mon Dec 23, 2024 7:50 am Post subject: Re: Westfalia Cabinet Catches - Suitable Replacement Found |
Do you have a picture of the binder clip? I’m having a hard time figuring it out from your description.
Also, it looks like the original picture and link from TheArmand post are no longer valid, does anybody know if he was referring to the following catch?
https://www.rockler.com/brass-ball-catch-choose-size
This latest catch doesn’t seem to fit correctly though.
sak94 wrote: |
_________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7282 Location: Honolulu,Hawaii and France
Posted: Mon Dec 23, 2024 10:41 pm Post subject: Re: Westfalia Cabinet Catches - Suitable Replacement Found |
pnwkayaker wrote: |
sak94 wrote: |
These seem to match his description, for a DYI
https://www.google.com/search?q=binder+clips&o...p;ie=UTF-8 _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
sak94 Samba Member
Posted: Wed Dec 25, 2024 3:20 pm Post subject: Re: Westfalia Cabinet Catches - Suitable Replacement Found |
Yes, here are a couple photos of the binder clip catch and one photo from the outside1
Posted: Wed Dec 25, 2024 8:34 pm Post subject: Re: Westfalia Cabinet Catches - Suitable Replacement Found |
Thanks, this makes total sense now. Very inventive! _________________ 87 Syncro Westy EJ25 ("Tardis")
