Help identify missing tins
sportin-wood
sportin-wood is offline
PostPosted: Wed Dec 25, 2024 10:14 am    Post subject: Help identify missing tins Reply with quote
Merry Christmas my fellow Sambanistas!
Aside from the rear rubber engine seal, this is clearly missing some tins, or at least the furthest rear. Trying to find out what the correct name is? Is it the pulley tin? Plus, I'll need one that has the hole for the hose from the air cleaner. Any idea which ones might fit? Can you tell from this pic if you can tell that anything else is missing? The tube from the EGR valve has been cut. I'm thinking of deleting that but I believe the manifold will need to be replaced? It doesn't have a block off with 2 bolts like I've seen others have.
Dave
1966 Bug project
1973 Thing project
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Dec 26, 2024 10:21 am    Post subject: Re: Help identify missing tins Reply with quote
Download the parts manual located in the Technical section of this forum. Immensely helpful.
https://www.thesamba.com/vw/archives/manuals/thing_parts_manual/Type_181_Parts_Manual.pdf
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
sportin-wood
PostPosted: Fri Dec 27, 2024 9:04 am    Post subject: Re: Help identify missing tins Reply with quote
Awesome - thank you Semper_Dad!
Dave
1966 Bug project
1973 Thing project
