1973 Fastback
nicnmike
nicnmike is offline
PostPosted: Mon Apr 28, 2025 6:58 am    Post subject: 1973 Fastback Reply with quote
Hi! Long-time lurker here. Finally purchased my first air cooled VW. It's meant to be a project for my son and I to work on. I actually haven't even seen it in person yet. My brother went out and looked at it and said it looked nicer in person than it did in the pictures (so that's good). I'm driving up this weekend to pick it up. I've rebuilt engines and do about 95% of most of my own vehicle repairs, so I feel confident in my ability to get it going.
I was told the engine was rebuilt and running 10 years ago. I know I'm probably going to have to replace all the pans and more than likely the heater channels. My brother said the chassis looks solid and the body looks mostly solid with only a few patches that will need to be addressed.
I uploaded the images from the ad to a gallery:
https://www.thesamba.com/vw/forum/album_search.php?search_author=nicnmike
One immediate question I have is if this thing has an AC unit:
Looking forward to working on it and "bugging" you all with questions!
-Mike
Max Welton
Max Welton is offline
PostPosted: Mon Apr 28, 2025 9:42 am    Post subject: Re: 1973 Fastback Reply with quote
Sure looks like an AC compressor. Look for the rest of the system. Follow the hoses.
Max
1967 Type-3 Fastback
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 28, 2025 12:04 pm    Post subject: Re: 1973 Fastback Reply with quote
Max
Yup, what he said. Just a heads up, more modern compressors can be swapped in, as those older units eat a lot of power. My old 70 Squareback had one that killed 3 engines under warranty, not counting the last one that was in it when I got it. If you really think about it, when you're sitting in traffic barely moving is when the AC is working the hardest, and the engine is struggling to cool itself, is why the engine self destructs. My car was from Texas where it saw daytime highs in the 115-117*F range in the summer months, with 100 days of 100+*F temps pretty regularly. That's why it went thru so many engines.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
rosevillain
rosevillain is offline
PostPosted: Mon Apr 28, 2025 12:06 pm    Post subject: Re: 1973 Fastback Reply with quote
The compressor and the under dash unit are there. If the pulley that drives the compressor is there, the rest of the stuff can be figured out. I'd be stoked to have the a/c parts that I can see in that car. Have fun.
nicnmike
nicnmike is offline
PostPosted: Thu May 01, 2025 7:12 am    Post subject: Re: 1973 Fastback Reply with quote
Thanks for the replies. I like the idea of swapping in a more efficient compressor. Just having all to brackets and under the dash components should make it an easier process.
Next steps are spending hours combing through the forums and making a parts and to do list.
I'll post more pictures once I get it home.
Mike Fisher
Mike Fisher is offline
PostPosted: Thu May 01, 2025 4:26 pm    Post subject: Re: 1973 Fastback Reply with quote
Check that your MPS holds vacuum.
Unbolt your injectors and watch their spray patterns.
We have lots of FI parts gathering dust.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
nicnmike
nicnmike is offline
PostPosted: Fri May 16, 2025 9:12 am    Post subject: Re: 1973 Fastback Reply with quote
Finally had some time to work on the car. All in all, it doesn't look like it's been worked on very much. It will need extensive body work done: floors, rust patches, new window seals, etc.
The fuel tank isn't rusty, but sat for awhile, so there's some slugy gunk that needs to be cleaned out. Then clean the fuel lines by disconnecting them from all the components and flush them with compressed air and fresh gas. then pull the injectors and clean them up.
I have a brake bleeder I can use to test vacuum on some of the components. I don't imagine I need to pull too much vacuum, right? Maybe just a few lbs?
I found a few posts listing components to check with a multimeter, so I'll do that too.
I noticed my distributor doesn't have a vacuum advance on it, so that's a bummer.
I read somewhere that when repairing the metal under where the windshield wipers are, you could fabricate a piece that's removable to keep the area clean. Does anyone know of a build, or link that gives an example of one?
Finally, my lazy question: what is this weird button thing on the hub cover?
gtixpress
gtixpress is offline
PostPosted: Fri May 16, 2025 12:59 pm    Post subject: Re: 1973 Fastback Reply with quote
That would be the end of the speedometer cable.
Joe P.
1969 VW Type 3 Squareback
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible
nicnmike
nicnmike is offline
PostPosted: Thu May 29, 2025 11:58 am    Post subject: Re: 1973 Fastback Reply with quote
Did some googling last night to figure this one out. This car is a little costly for the, "just replace everything" route. Hence the extra effort on the calipers.
Other news: I got it titled this morning! And ordered a bunch of fuel stuff to try to get it running. Now that it's titled, I'll start dismantling and ordering all the other stuff (pans, all the seals, lines, hoses, bushings, etc...).
