Spring plate lowering
JayWat
JayWat is offline
PostPosted: Mon May 12, 2025 8:59 am    Post subject: Spring plate lowering Reply with quote
Lowered a 76 1 inner spline.
What bottoms out first ?
The spring plate ?
The place that used to hold the bump stop ?
Or the stock length shock ?
Bottoming out on something solid and I can't see where.
Starbucket
Starbucket is offline
PostPosted: Mon May 12, 2025 2:17 pm    Post subject: Re: Spring plate lowering Reply with quote
Have someone jump up and down on the rear bumper while you watch under the car and see what is hitting. My money is on the shock.
JayWat
JayWat is offline
PostPosted: Tue May 13, 2025 4:45 am    Post subject: Re: Spring plate lowering Reply with quote
The car is too low to see what's going on.
I may remove the shocks temporarily and take it for a drive.
Anyone know a shorter shock part number that has been used successfully ?
Starbucket
PostPosted: Tue May 13, 2025 7:04 am    Post subject: Re: Spring plate lowering Reply with quote
All the vw suppliers sell them, cip1 jbugs, wolfsburg west, etc..
clockworkbox
clockworkbox is offline
PostPosted: Tue May 13, 2025 9:06 am    Post subject: Re: Spring plate lowering Reply with quote
If it is hitting the bump stop stub (assuming you removed the rubber bump stops), you should be able to see if the trailing arm made contact. There should be some kind of scrape or paint missing from the stub and/or the stop on the chassis.
'69 Beetle (pieces)
Learning the hard way is still learning...
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue May 13, 2025 3:14 pm    Post subject: Re: Spring plate lowering Reply with quote
Get your phone in there and pointed in the direction. Then, if you can see the screen, see what is happening. If not, take a video of it, then watch that.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Buggeee
Buggeee is offline
PostPosted: Wed May 14, 2025 5:04 am    Post subject: Re: Spring plate lowering Reply with quote
Aside from the shock, between the spring plate or the naked bump stop, it would be the spring plate. People notch them as one method of winning the limbo contest.
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
JayWat
JayWat is offline
PostPosted: Thu May 15, 2025 5:30 am    Post subject: Re: Spring plate lowering Reply with quote
So, spring plate will hit the stop before the naked bump stop correct ?
