Shock length
Derickpete
Derickpete is offline
PostPosted: Tue May 13, 2025 2:01 pm    Post subject: Shock length Reply with quote
What length shock, extended length and collapsed length is used for a Warrior beam with 8” towers and stock arms. I’m measuring 19” extended and 14” collapsed. Is this correct?
Schepp
Schepp is offline
PostPosted: Tue May 13, 2025 2:16 pm    Post subject: Re: Shock length Reply with quote
You answered your own question.
Derickpete
PostPosted: Tue May 13, 2025 2:27 pm    Post subject: Re: Shock length Reply with quote
From what I understand the 8” beam means 8” shock stroke. I’m getting 5” of stroke. So what is the correct shock.
BFB
BFB is offline
PostPosted: Tue May 13, 2025 5:24 pm    Post subject: Re: Shock length Reply with quote
8" beam typically means 8" wider.
but even if we go with your theory and its 8" towers, the tower doesn't matter. you could have 8 foot towers and you'd still have the same amount of travel out of stock arms.
Most experts aren't.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Tue May 13, 2025 8:24 pm    Post subject: Re: Shock length Reply with quote
8in tall shock tower on either a stock or widen beam, the most common shock that has been used is the rear shock from a 1968-1979 VW Bus
The KYB 5530 was a commonly used shock although the valving may be stronger then you need
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Derickpete
PostPosted: Tue May 13, 2025 8:53 pm    Post subject: Re: Shock length Reply with quote
Thank you. I will look into them.
Derickpete
PostPosted: Sat May 17, 2025 2:45 pm    Post subject: Re: Shock length Reply with quote
Update: The bus shocks worked perfectly for my beam. Thank you for the input.
