3 speed SA trans?
BFB
BFB is offline
PostPosted: Mon Jun 16, 2025 7:38 pm    Post subject: 3 speed SA trans? Reply with quote
anyone ever heard of building a three speed swing axle?
Most experts aren't.
oprn
oprn is offline
PostPosted: Tue Jun 17, 2025 4:39 am    Post subject: Re: 3 speed SA trans? Reply with quote
I have been wondering if an auto stick transaxle could be changed over to a 3 speed manual. Not sure why one would do that though... maybe for a VW trike?
Dusty1
Dusty1 is offline
PostPosted: Tue Jun 17, 2025 6:16 am    Post subject: Re: 3 speed SA trans? Reply with quote
BLEAAAAHHHHH!
When all the good ideas are used up we must dedicate the rest of our lives to bad ideas. Twisted Evil
NJ John
NJ John is offline
PostPosted: Tue Jun 17, 2025 3:01 pm    Post subject: Re: 3 speed SA trans? Reply with quote
I always wondered if some wacky beetle owner ever rigged a clutch cable to a semi-auto and drove it as a full manual.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
b-man
b-man is offline
PostPosted: Tue Jun 17, 2025 3:25 pm    Post subject: Re: 3 speed SA trans? Reply with quote
If you have so much torque that 3 gears are enough then simply choose whatever 2nd gear you want to use as your low gear, whether it’s a stock or aftermarket ratio and just skip first gear.
In 1979 I built a 1969 Squareback with a 1964 Buick V6 (225ci 155hp), the transaxle had a 3.88 R&P and .82 4th, otherwise all stock gearing. I would regularly drive it using 2nd and 4th only while driving around town.
1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle
NJ John
NJ John is offline
PostPosted: Tue Jun 17, 2025 7:11 pm    Post subject: Re: 3 speed SA trans? Reply with quote
Look at all that odd fire horse power. Was your car in the KEP catalog back in the day? I remember pics of a bunch of Buick powered VW’s in it.
oprn
oprn is offline
PostPosted: Tue Jun 17, 2025 10:17 pm    Post subject: Re: 3 speed SA trans? Reply with quote
The old 225 V6 was indeed a rough running SOB! One of the mechanics at the shop I worked at put one in his split window panel. I don't recall which it was the clutches or the transaxles that kept failing so he sold it. That would be back in about '73.
oprn
oprn is offline
PostPosted: Tue Jun 17, 2025 10:23 pm    Post subject: Re: 3 speed SA trans? Reply with quote
Dusty1 wrote:
BLEAAAAHHHHH!
Which is why that semi-auto box is still sitting in the hay shed and I haven't done it. I think it could be done but why would I do it? What earthly advantage would it be over a 4 speed box? So I walk by it and wonder...
b-man
b-man is offline
PostPosted: Tue Jun 17, 2025 11:00 pm    Post subject: Re: 3 speed SA trans? Reply with quote
I put quite a few miles on the ol’ Fireball V6 and it wasn’t particularly rough running at all. It was a good running engine out of a wreck I bought for $350 back when V6 engines were few. All the engine needed was a new timing chain set. My car wasn’t featured in the KEP catalog.
If you respected the transaxle it was plenty durable, mine had a Super Diff and an aluminum side cover along with welded 3rd and 4th gears. The KEP 1700 clutch was more than up to the task.
I learned a lot about engine swaps and body work, it was as a fun project and a great freeway cruiser.
oprn
oprn is offline
PostPosted: Wed Jun 18, 2025 5:06 am    Post subject: Re: 3 speed SA trans? Reply with quote
My cousin's husband owned his own auto repair shop and had one in his salmon fishing boat. He told me that is nearly drove him crazy listening to that offbeat idle as he trolled for fish. He explained that it was literally a cut down V8 was why it ran so rough and not a purpose built V6 like we have today.
I suppose some people just got used to them...
FarmerBill Premium Member
FarmerBill is offline
PostPosted: Wed Jun 18, 2025 6:32 am    Post subject: Re: 3 speed SA trans? Reply with quote
I've never experienced a Buick Fireball 6 but it must have been a lack of balance in the rotating assembly because it has the same firing order as the current GM V6. I looked it up and all I could find was back in the 60s an AMC executive said the Fireball "ran rougher than a cob".
EVfun Premium Member
EVfun is offline
PostPosted: Wed Jun 18, 2025 6:53 am    Post subject: Re: 3 speed SA trans? Reply with quote
The firing order is the same, but the firing pattern isn't. The early Buick V6 was a 90 degree engine with common crank pins, like the V8. As a result, instead of one cylinder firing every 120 degrees, the firing timing was 90 degrees, 150 degrees, 90 degrees, 150 degrees...
The later Buick 90 degree V6 engine had split crank pins to even out the firing pattern. The old Chevy 90 degree V6 had split crank pins to partially correct the firing pattern, with a 108 degree 132 degree firing pattern.
Wildthings wrote:
Dusty1
Dusty1 is offline
PostPosted: Wed Jun 18, 2025 7:15 am    Post subject: Re: 3 speed SA trans? Reply with quote
My '64 Buick Special was one of my truly memorable beaters. Bought it from a junkyard for fifty bucks. Drove it from NYC damn near to Canada all summer, 22mpg @ 70mph. Sold it at a profit when the leaves turned. The family who bought it got a few years out of it.
oprn wrote:
Dusty1 wrote:
BLEAAAAHHHHH!
You could yank the Type 4 out of that buggy and find out.
Lotta great ideas bein' tossed around.
The way we do it with high horsepower bikes is we hold the throttle wide open and thumb the button that actuates the air shifter. We interrupt the ignition as the shift occurs. Even though we're wide open technically makin' 200hp / liter no spark momentarily allows us to shift full throttle without breaking things. Usually.
NJ John
NJ John is offline
PostPosted: Wed Jun 18, 2025 7:45 am    Post subject: Re: 3 speed SA trans? Reply with quote
Boy, we ruined this thread. I had a built even fire 231. Vibrated like crazy. Ran 15.4 at the track in a 77 Sunbird. Could do 8k rpm burn outs and sounded like 2 Harley’s. Crappy oiling system, yet GM kept pushing it along with turbos and eventually superchargers. I was Mr. 231 for way too long.
oprn
oprn is offline
PostPosted: Thu Jun 19, 2025 2:02 am    Post subject: Re: 3 speed SA trans? Reply with quote
Not really, BFB just tossed this question out to get a conversation going. I doubt he cares a pinch of coon poop where it goes. He is no more likely to build a 3 speed box than fly to the moon on a unicorn!
BFB
BFB is offline
PostPosted: Thu Jun 19, 2025 6:18 am    Post subject: Re: 3 speed SA trans? Reply with quote
your right and wrong, I dont care where a thread goes most of the time as long as it just goes. not much worse than dead threads and nothing at being posted .. with the exception of more oil threads.
but I actually have a line on a trans that's supposed to be a 3 speed out of a sand drag car. so maybe you dont know everything and you need to put a saddle on that unicorn because this monkey might be going into outer space.
oprn
oprn is offline
PostPosted: Thu Jun 19, 2025 10:23 am    Post subject: Re: 3 speed SA trans? Reply with quote
Ya - I could see a 3 speed working on something like that. Hardly long enough runs to use more than 2 or maybe 3 gears.
NJ John
NJ John is offline
PostPosted: Fri Jun 20, 2025 11:21 am    Post subject: Re: 3 speed SA trans? Reply with quote
I have an 83 year old customer, just told me that he has a Buick Grand National, that he bought new. It has a built 4.1 and he has a 270 something cube V6 in his living room! He comes to my restaurant on a scooter.
