Flasher issue
spacebiscuit
spacebiscuit is offline
PostPosted: Mon Jul 07, 2025 12:18 pm    Post subject: Flasher issue Reply with quote
Hi all - bus has been laid up for a while - I've replaced the emergency flasher relay - when I pull the switch all for turn signals flash as expected. But using the turn signal the right side work but on the left side i have nothing, no lights on the dashboard and no flashing turn signals.
My guess is the issue might be around the 4 point cable connector (T3 on the attached image - J2 is the relay). Can I rule out a bad earth if the flasher works?
My bus follows this diagram:
https://www.thesamba.com/vw/archives/info/wiring/bus_8_71.jpg
Any ideas or suggestions welcome - thanks!
[/url]
1972 Type 2 1600cc
1990 MKII Golf 1.6 CL
busdaddy
busdaddy is offline
PostPosted: Mon Jul 07, 2025 1:07 pm    Post subject: Re: Flasher issue Reply with quote
Dirty/corroded fixtures are usually the cause, the bulb shell has to make clean contact with the socket, if it doesn't it finds a ground path through the parking light circuit, it's enough to work on the 4 ways, but not on a single side.
Слава Україні!
spacebiscuit
PostPosted: Mon Jul 07, 2025 1:18 pm    Post subject: Re: Flasher issue Reply with quote
Thanks BusDaddy - so are you suggesting that when the hazard/emergency lights are on it could be picking up the ground from the good side that works independently?
1972 Type 2 1600cc
busdaddy
busdaddy is offline
PostPosted: Mon Jul 07, 2025 4:03 pm    Post subject: Re: Flasher issue Reply with quote
The flasher relay is designed to not flash on one bulb, or flash super fast, it's a way to alert you to a burned out bulb, a weak ground acts just like a bad bulb as far as it's concerned.
The hazards use 4 bulbs so even if one is weak the system still flashes. Walk around with them on and look for the slightly dimmer bulb.
Слава Україні!
70bus Premium Member
70bus is offline
PostPosted: Mon Jul 07, 2025 4:52 pm    Post subject: Re: Flasher issue Reply with quote
A similar issue was just explored on the split bus forum; in their case, the turn signal switch had a bad connection between power and a light circuit. Cleaning it out helped. Also check the Y connector under the dash to the switch for a loose/broken wire.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
mikedjames
mikedjames is offline
PostPosted: Tue Jul 08, 2025 4:26 am    Post subject: Re: Flasher issue Reply with quote
Because the hazards work, proving the flasher relay, wiring to external lamps and the external lamps are OK, its either the indicator switch or wiring between it and where the hazard switch feeds the right hand indicator wiring. The hazard switch shorts the flasher relay output to both left and right hand indicator wiring.
Could be the connector block for the indicator switch under the dash as you say. Its just a bundle of spade connectors. Quite easy to push wires in and miss the spade going into the female socket, so it falls out later.
Ancient vehicles and vessels
spacebiscuit
PostPosted: Tue Jul 08, 2025 12:01 pm    Post subject: Re: Flasher issue Reply with quote
it was the 4 way connector - T3 in the screenshot. Of the 4 wires that should plug into the block only 3 were connected. I fished around and found the wire that had become disconnected - all turn signal now working nicely.
Now to stop that turn signal from moving around the steering column every time I use it!
1972 Type 2 1600cc
busdaddy
busdaddy is offline
PostPosted: Tue Jul 08, 2025 12:36 pm    Post subject: Re: Flasher issue Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=537144&highlight=signal+loose
Слава Україні!
