vanagon91 Samba Member
Joined: December 31, 2009 Posts: 75 Location: Virginia's Blue Ridge Mountains
Posted: Tue May 18, 2010 5:05 pm Post subject: Lock Question |
How do you change the tumblers in a icepick door handle? Thanks, Sam |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Tue May 18, 2010 6:25 pm Post subject: |
First you'll need to disassemble the door handle.
Then, you'll need to remove a tiny jewelers screw that holds the key lock into the handle
Once that screw is removed, the key lock portion will easily slide out of the handle body
The Brass wafers (tumblers) can then be easily pushed out & replaced _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17573 Location: Left coast, Canada
Posted: Tue May 18, 2010 8:35 pm Post subject: |
RareAir wrote: |
Sometimes not. _________________
VWNate Samba Member
Joined: October 04, 2016 Posts: 432 Location: Sunny So. Cal.
Posted: Wed Dec 20, 2023 7:17 pm Post subject: Ice Pick Lock Question |
How to take the handle apart ? .
Someone must have done this and taken pictures.....
TIA, _________________ -Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71471 Location: Phoenix 602
Posted: Wed Dec 20, 2023 9:06 pm Post subject: Re: Lock Question |
You double-posted this so I pasted in your text below with my answer:
Quote: |
I don't see a thread for how to take the '56 ~ '59 door handles apart, I need to replace the spring and re key it to match my original SG ignition .
Any links would be highly appreciated, I've been searching 'door key', 're key', door handle key', on and on.....
Once you've done it a few times re keying isn't difficult, it's just one more fiddly detail oriented job best done over a white or light colored towel as small parts tend to fall, bounce or PING off into God alone knows what other universe .
TIA, I'm sure someone has done this before .
Bus handle spring replacement thread below, I think they are the same?
https://www.thesamba.com/vw/forum/viewtopic.php?t=146325
Lock cylinder removal, there's a tiny screw once it's apart:
https://www.thesamba.com/vw/forum/viewtopic.php?t=335745
and
https://www.thesamba.com/vw/forum/viewtopic.php?t=313084 _________________ How to Post Photos
VWNate Samba Member
Posted: Thu Dec 21, 2023 7:53 am Post subject: Pre '60 Door Handle Disassembly |
Thanx Everett ;
What I was after was info on knocking the pin out without breaking the pot metal part . _________________ -Nate
VWNate Samba Member
Posted: Thu Dec 21, 2023 8:22 am Post subject: Re: Lock Question |
Thank you Sir .
I have a few decent old handles sans keys I want to mix & match plus re key to match the ignition and T handle . _________________ -Nate
