Blown Engine (1500cc Air Cooled) - Advice Needed
Page: 1, 2, 3  Next
foxacoon
foxacoon is offline
PostPosted: Sat Feb 18, 2023 8:23 am    Post subject: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Hi All,
Looking to get an experts opinion.
I recently purchased a Brazilian bus from a company listed on these forums, and after about 100 miles of driving, the engine blew and I ended up throwing a rod.
The bus I purchased is a 1975 air-cooled 1500cc Brazilian Bus (restored). Upon delivery, I put 20w50 oil in it.
As I was driving back from getting the bus inspected in preparation for registeration/title application, I noticed a significant decrease in power and a loud knocking in the engine bay. I was on the highway and attempted to take the first exit, but before I got to the next exit, the bus came to a hault, a loud pop noise and a puff of white smoke shot out the rear.
After I had my bus towed home, I noticed a big hole in the block - a clear indication that I threw a rod.
So, my question is... where would you recommend me looking to get a new motor? I have a little experience working on my vintage land rovers, but not a ton.
You can see pictures attached.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Feb 18, 2023 8:38 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
So you have to assume the long block is a total loss.
You could buy a rebuilt 1500/1600 single port long block and move the tins, intake, exhaust, generator, distributor, carb over and that might be the cheapest option.
Or you could go with a 1600 or 1776 dual port which will require new tins, shroud and intake.
Last year we had a customer with a similar problem, 1975 Brazilian Bus with a seized 1500SP. Case as already cut twice, crank and rods were gone and heads not good. After discussing the cost to build a new engine or buy a long block... it was cheaper to buy a 1600SP long block and move all the good parts over to the new engine.
Obviously, we could not warranty the engine since we didn't build it but we've dealt with this vendor in the past and have had good results.
http://steelbugin.com/
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
gt1953
gt1953 is offline
PostPosted: Sat Feb 18, 2023 8:49 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
You have to step back and decide are you going to drive this alot, road trip it or going to keep the stock look in the engine bay area.
A 1776 would be a good overall choice and a quality engine builder may do it in a single port to keep the stock look.
What ever you do do not cheap out once and done.
72 type 1
72 Squareback
94touring
94touring is offline
PostPosted: Sat Feb 18, 2023 9:00 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Great opportunity to go with something larger. I drove a slow Brazilian around for a bit and quickly went with something that could manage highway speeds better. Not knowing the condition, I also opted to send the transaxle out as well and regeared to match the new engine. You'll want to switch to 10w30 fyi.
Q-Dog
Q-Dog is offline
PostPosted: Sat Feb 18, 2023 9:02 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
1776 single port with a cheater cam.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Bugged Again
Bugged Again is offline
PostPosted: Sat Feb 18, 2023 9:03 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Do you plan to do the removal and installation yourself? Also, your location may make a difference. If your area has some VW shops with good reviews you may want to go with them.
Otherwise, get some how to VW books and ask questions. I’d suggest you gain some VW experience by pulling you’re engine out first. Then see how you feel about doing the install.
Mr. 010
Glenn is offline
PostPosted: Sat Feb 18, 2023 9:05 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Agreed.
You can also go NUTZ.
A few years ago I built a 2017 for a 66 Bus. The owner wanted to be able to go anywhere and any elevation without messing with the carb or timing. So we went with EFI and crankfire ignition.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
slalombuggy
slalombuggy is offline
PostPosted: Sat Feb 18, 2023 10:01 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Are you expecting to drive at modern speeds for extended periods of time on the highways and byways. If so I would look at an engine displacement of at least 2 liters, twin carbs and upgraded factory cooling.
johnnyvw164
johnnyvw164 is offline
PostPosted: Sat Feb 18, 2023 10:29 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
IMO, the two most important factors are budget and how much you are willing to work on maintaining the engine. Dual carbs will give more power but have to be able to tune them as needed. No sense looking to do a big engine if you have a very tight budget
As Glenn mentioned, if you can find a good condition running 1600, it would be the quickest and cheapest solution.
buckswilde
buckswilde is offline
PostPosted: Sat Feb 18, 2023 1:06 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Just go with a stock 1600 DP or SP. There are many shops all over the US that can handle that with no problem. I sold a strong running used 1600 DP turnkey last year for $600. It's an affordable solution that will have a bit more power than the 1500.
nsracing
nsracing is offline
PostPosted: Sat Feb 18, 2023 4:25 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
First of all, why did you use that thick oil?
And where are you located? Motors are all over the place in all flavors. Choose your poison.
foxacoon
foxacoon is offline
PostPosted: Sat Feb 18, 2023 4:51 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Great question. I asked the guy that I bought it from and he specifically said 20w50. I didn’t didn’t ask questions or get a second opinion, but I wish I did.
Cusser
Cusser is offline
PostPosted: Sat Feb 18, 2023 5:03 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
(1) I'd like to see good photos of the entire engine compartment from multiple angles, to see if the heater hoses are all connected. Stuff from the engine build like a leaky valve cover or bad oil cooler seals could've caused the oil to leak out and cause the engine damage.
(2) You said 1975, but is that 1500cc engine have doghouse cooling/shroud?
(3) I know it's winter in northern hemisphere, but I don't think that 20W-40 is what caused the problem, if the oil level was correct.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sat Feb 18, 2023 5:08 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
My advice is do some serious vetting of the business or vendor before pulling the trigger and buying an engine from a rebuilder. There's still some good engine builders out there but there's also some awful ones with horrific customer service. Obviously some do shoddy work using the cheapest parts they can find. These forums have a sellers feedback section. A couple engine builders come to mind that take your order and money and then never meet promised completion/shipping dates. Some miss by months and months while providing excuse after excuse.
If you have the capability to build an engine yourself, that's the perfect world. When I rebuilt my engines, I was able to take my time and double and triple check everything during assembly. I also knew the quality of every part I installed. There's nothing more satisfying than rebuilding or building an engine and lighting it off the first time.
In regards to that thick 50 weight oil, wow! Oil that thick can cause oil pressure issues where the oil relief valve won't open and allow oil to the oil cooler unless the oil gets HOT and thins out. I ran 10-40 in hot Arizona on a freshly overhauled engine I rebuilt. I was running hot oil temps. I dropped to 10-30 and saw a big decrease in oil temps. Now I only run 10-30.
Here's a thread that discusses the oil system- https://www.thesamba.com/vw/forum/viewtopic.php?t=280293
The Samba member since 2004.
Dusty1
Dusty1 is offline
PostPosted: Sat Feb 18, 2023 5:42 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Good question!
For all we know you could be a thousand miles or a thousand yards from a VW specialist.
foxacoon wrote:
I would JB weld that dinky little hole and proceed as if it wasn't there.
Kidding! Still, I'd like to practice my tig skills on that hole. I'll bet I could weld it up and metal finish it. Be fun to do it just to show it can be done although there are likely numerous problems inside the engine.
The typical hole is where #3 exited under the fan shroud. Your case might be busted a lot worse when you get the tin off it.
Imagine every engine contains a tiny engineer with an oversized hammer. As long as your engineer's working conditions aren't too dirty, demanding and dangerous he's a happy camper. Piss him off, (dirty oil, not enough oil or oil pressure, too much heat) he'll knock a big hole in your engine and just plain quit. Often as not he'll ride a broken connecting rod out the hole like Wile E. Coyote on an Acme rocket.
In any case your motor is totgeschlagen.
foxacoon
foxacoon is offline
PostPosted: Sat Feb 18, 2023 6:19 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
I’m located in Dallas, Texas.
More pictures on the way!
94touring
PostPosted: Sat Feb 18, 2023 6:37 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
I always see FB post from some guy in Katy Tx with rebuilt blocks. Not sure of the quality of his work but something to look into.
Mr. 010
Glenn is offline
PostPosted: Sat Feb 18, 2023 8:32 pm    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
You mean like this?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
nextgen
nextgen is offline
PostPosted: Sun Feb 19, 2023 7:56 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Well it is a beautiful bus and it is worth a lot of money. Compared to a Bug, the bus is massive with bug engine.. As some of the guys said you need a larger engine and be aware of what it can push at highway speeds . The weight of the bus empty vs it loaded for a trip with people. Just another thing to think about.
Don't worry guys I am not going to T-4.
email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs
Dusty1
Dusty1 is offline
PostPosted: Sun Feb 19, 2023 8:00 am    Post subject: Re: Blown Engine (1500cc Air Cooled) - Advice Needed Reply with quote
Glenn wrote:
You mean like this?
There it is!
That hole behind the fuel pump in the OP's engine may have been a stray chunk the crank smacked into the case. Your under the fan shroud hole is typical.
I've had success reviving wet stuck engines typical of '71 and later Bugs left outside without the air cleaner. Stuck motors can be a gamble, though. Odds are about 50 / 50 these days the motor is stuck because the #3 connecting rod is jammed up against the case.
Wasn't it Muir who said fifty years ago we should hoard damaged cases in case good ones become NLA? I'd like to bandsaw a slab out of a donor and see if I can't repair the typical exit wound.
Even if the case is warped my buddy has a massive machine for decking diesel blocks and heads. Shouldn't be too difficult to whack a few thou off the mating surfaces to clean it up.
Who is that Texas engine builder who frequently has featured ads in the Samba classified?
Page: 1, 2, 3  Next
