Tiptronic-Modification now public Domain
xoo00oox
xoo00oox is offline
PostPosted: Wed Mar 22, 2023 11:14 am    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
rogertj wrote:
Question? Could the 4WD in the 4motion (AWD) be reversed? like the subaru gears are doing it?
If you go with a manual transmission, the 4mot works reversed in a Vanagon.
Ray_V6TDI
Ray_V6TDI is offline
PostPosted: Wed Mar 22, 2023 1:47 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
I doubt that, unless we are thinking different solutions.
The Subaru gearbox uses new ring/pinion in the diff. And a flipped diff cage.
Audi/Passat do not have the room in the gearbox casing to allow the diff cage to be flipped. If those had, people would have done it decades ago.
While Subarus allow machining the gearbox shell to make room, the Audi doesn´t. You can see the bulge for the crown wheel in the lower right of this picture:
https://www.google.com/imgres?imgurl=http%3A%2F%2F...egUIARDIAg
Also, the clutch arm is in the way to create room for a new bulge on the lower left bellhousing.
All you could do (and people have done) is to mount the gearbox upside down...incl all the caveats
xoo00oox
xoo00oox is offline
PostPosted: Wed Mar 22, 2023 2:04 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Yes, different solution. I'm talking about engine running counter clockwise and transmission and rear diff (now in the front) remaining unmodified.
Ray_V6TDI
PostPosted: Wed Mar 22, 2023 2:11 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
I remember that thread, very impressive. But it´s only proven on 1,8T
On V6...not that I know of.
rogertj
rogertj is offline
PostPosted: Wed Mar 22, 2023 2:40 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Would you be up for designing again Ray? I can send you some expense money for that. Is it expensive? I have a good good budy of mine that has a machine shop in San Clemente California hes in the aerospace industry and could figure out the apropiate shop for that or maybe after review he could do it for us. I just send him your design for a quote. Let me know. Send me a pm with your email to contact you and your current time zone.
Thanks my friend
Roger
Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
View user's profile Send private message MSN Messenger Twitter Gallery Classifieds Feedback
rogertj
rogertj is offline
PostPosted: Wed Mar 22, 2023 3:01 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Sorry for not answering your message xoo00oox I checked it on my phone and by the time I answered yours was present. Cool Ideas for us Vanagon lovers.
Do you have the thread for the mods that you and Ray are discussing to check them out?
Roger
xoo00oox
xoo00oox is offline
PostPosted: Thu Mar 23, 2023 5:55 am    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=568346&highlight=quattrosyncro
rogertj
rogertj is offline
PostPosted: Thu Mar 23, 2023 10:33 am    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Oyeah I remember that thread awesomeness!!!!
Roger
Ray_V6TDI
PostPosted: Thu Mar 23, 2023 11:54 am    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Sorry, but no.
The 2WD version was completely reverse-engineered from scratch, back in 2004/2005.
Buying a trans, taking it apart, getting bolt patterns and other dimensions laser-measured etc.
Finding out the spline sizes of the gears...
I hoped to sell a few of these, in the end only three sets were made in total. Luckily, the other two reduced the net cost of mine.
I had personal interest to get mine rolling, but I don´t need the hassle again.
Also, I don´t have a 4WD gearbox available for research.
Another comparison I just found on my HDD:
Regards
Raimund
P.S. By the way: How do you want to shoehorn the 4WD into the Vanagon, when the extra propshaft flange would cut right through the rear crossmemeber where Vanagon´s gearbox is usually fastened?! Run the propshaft above the interior carpet?!
rogertj
rogertj is offline
PostPosted: Thu Mar 23, 2023 12:15 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Ray_V6TDI wrote:
Sorry, but no.
Regards
Raimund
Thanks Ray for your response, bummer that you dont have a 4 motion handy if I were a millionar I would send your 3 to play with lol
Roger
rogertj
rogertj is offline
PostPosted: Thu Mar 23, 2023 12:24 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Question is the red circle the ones that you were refering to?
Also what about the question mark that Ive placed, I imagine that does to have to ve modified?
Roger
Ray_V6TDI
PostPosted: Thu Mar 23, 2023 12:46 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
The circles:
On 2WD, the planetary output shaft drives the first of the three middle gears.
On 4WD, that shaft runs THROUGH the first gear into the torsen diff, which is then driving both the first gear and the propshaft flange.
Clearly visible on the schematic drawing I am showing in the posts above.
What other question mark are you referring to?
rogertj
rogertj is offline
PostPosted: Thu Mar 23, 2023 12:47 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Ray_V6TDI wrote:
The circles:
Ups! my bad, forgot to place the photo
Roger
Ray_V6TDI
PostPosted: Thu Mar 23, 2023 12:51 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Your circle shows the end of the 2WD version gearbox. Everything right of it is the 4WD content.
The two extra gears with the question mark are another ratio for the rear diff. The propshaft output flange is not directly behind the "drum" of the torsen diff, but on the lower gear (out of photo´s right side edge).
Those two gears are the ones named "Stirntrieb hinten", german for (?) spur drive rear (?)
Just imagine the picture flipped left to right, and it matches the photos.
rogertj
rogertj is offline
PostPosted: Thu Mar 23, 2023 1:01 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Ok so the question would be if the "Stirntrieb hinten", german for (?) spur drive rear (?) need to be reversed?
I think not
Please excuse my ignorance
Roger
Ray_V6TDI
PostPosted: Thu Mar 23, 2023 1:16 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Ok, basic assumption:
you need to use the Audi rear diff on a vanagon´s front anyway, as the stock vanagon´s front diff won´t match ratios and tear you Van apart (or crunches it shorter...)
Now, say you reverse only the audi´s front output to use in a Vanagon´s rear:
the 2WD part (Audi front) now pushes the Vanagon forward,
the 4WD part (Audi rear) still pushes the Vanagon backwards.
...not good.
You need to reverse both (which, BTW, opens a new can of worms: adding a third gear to those you question-marked).
Or, the clever mean trick: You reverse only Audi´s front, and put Audi´s rear diff into the Vanagon´s front, but upside down!
Confused?!
You´re welcome Wink
...been through all these thoughts, wanting to build a Vanagon quattro!
Still leaves the problem of the 4WD gearbox crashing into the vanagons´rear frame and your rear heat exchanger.
rogertj
rogertj is offline
PostPosted: Thu Mar 23, 2023 1:27 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
This is getting interesting!
ps i dont see a problem on the tranny support beam if they build trophy trucks out of metal tubes why dont build another cross beam for street use? Or may be rocks? lol
Roger
R1stephen
R1stephen is offline
PostPosted: Sat Oct 21, 2023 11:46 pm    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Hi Ray after many hours typing in reverse trans, transverse reverse rotation and getting all sorts of sites and nonsense I have landed here again in this world of amazement and knowledge, I recently posted about trying to do this on a golf transverse box or with a transverse dsg box as I was positive I could install my AWG engine transverse and reverse the gearbox direction but if this can be done installing longitude then i'm all in and already on e-something seeking a donor box. However the codes are coming up varying from 5hp19efr to 5hp19eyf so will this work or does it need to be the exact box and what other parts do i need to scavenge from the donor car.
This is an amazing topic
Currently mono wheeling through life
1980 t3 moonraker running a t2 1700 air cooled for some crazy reason
Honda fireblade 2010 no time to enjoy
Ford Ranger 3.2 6 speed auto why because I can
djkeev
djkeev is offline
PostPosted: Sun Oct 22, 2023 4:19 am    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
Sometimes brilliant minds don't reap the rewards of their efforts.
Tesla comes to mind as does Goodyear.
Their ideas were capitalized on later and without any benefit to them.
Anyway..... I've never noticed this thread before.
It took me a while to realize what a Tiptronic is.
The idea is presented in German car guy language without any translation to what it is and how it affects or can help me .... mr dummy owner.
With the stupid amount of money owners are pouring into these old Vans I'm not convinced that your market is dead.
Our needed drive train parts have become scarce and at times non-existant.
I would encourage you to pick up your idea and reshop the gears you need.
If you offered a drop in transaxle all set up and ready to go I'm willing to bet money you would have a market throwing $$'s at you and probably a line waiting to buy.
But it needs to be plug and play (entire unit or a complete nuts to soup DIY kit) and you need to clearly tell the drive train ignorant owners like me exactly what you are selling and why I need it.
Tiptronic means nothing without some marketing educating me.
Dave
Ghia
Vanagon
Beetle
Ray_V6TDI
PostPosted: Sun Oct 22, 2023 10:37 am    Post subject: Re: Tiptronic-Modification now public Domain Reply with quote
The gearbox is a 5HP19FL
"5" speed, "HP19" is the strength (there are 5HP24 also which can take a higher torque), "FL" is frontdrive longitudinal. "FLA" would be all-wheel drive.
The EFR and stuff is the gearbox variation code, just like DG or MV for Waterboxers.
Every code has different ratios, especially in the gears I changed. If you don´t meet the correct ratio for the related trans ECU, and if the trans ECU won´t match your engine ECU, you will get in software trouble and limp modes.
So: Get a pair of engine/trans that belong together. Then get the exact gear ratio re-febricated for reversal of axle output.
A market is non-existant. I built three reversal sets in 2005, that´s it. Yes, i didn´t advertise a lot, but no one was willing to go the whole way.
The website is from 2005, in German, and the technical details should be translateable with modern AI, shouldn´t they?
By the way, attached the outcome of the last two days: All out!
Converter clutch, Turbo and (at least one) rocker arm busted/missing.
So there you go.
Page 3 of 4
