Make my Stereo Mono?
harrymarlin
harrymarlin is offline
PostPosted: Mon May 15, 2023 12:50 pm    Post subject: Make my Stereo Mono? Reply with quote
I have a Sapphire VIII (8-Track Stereo), but I only have one speaker, and would like to combine my stereo to a single speaker (mono). The manual for the Sapphire VIII warns against not running the amplifier under stereo load (so, there need to be proper 8 ohm resistance for each stereo output/channel). Note: it has a common ground. Right now I have one connected to an 8 ohm resistor, which is great, but I only hear one side of the output, which is fine if I'm streaming in mono - not so great if I'm listening to an 8-track.
Is there an easy (and small) way I could allow both sides of the stereo come out of my single speaker without ruining my radio (I'm trying to keep as stock as possible, but I don't want to wire another speaker to the rear, which is what they did in 1967)?
-Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia
harrymarlin
PostPosted: Wed May 17, 2023 7:45 am    Post subject: Re: Make my Stereo Mono? Reply with quote
Any thoughts on how to take a powered stereo input and output powered mono while keeping load (8 ohm) across the inputs - all without changing a stock radio?
-Harry
clockworkbox
clockworkbox is offline
PostPosted: Wed May 17, 2023 8:05 am    Post subject: Re: Make my Stereo Mono? Reply with quote
Maybe this helps you:
https://www.eeweb.com/stereo-to-mono-converter-based-on-fet/
'69 Beetle (pieces)
Learning the hard way is still learning...
harrymarlin
PostPosted: Wed May 17, 2023 8:09 am    Post subject: Re: Make my Stereo Mono? Reply with quote
Interesting! I may not understand circuits as much as I would like to, but does this accept powered inputs (post amplifier)?
-Harry
clockworkbox
PostPosted: Wed May 17, 2023 8:35 am    Post subject: Re: Make my Stereo Mono? Reply with quote
I do not know as that circuit requires power. Here is a simple circuit like you describe but I do not know what size resistors you would need. My circuit experience comes from r/c car and drone building and playing with Arduino.
'69 Beetle (pieces)
clockworkbox
PostPosted: Wed May 17, 2023 9:04 am    Post subject: Re: Make my Stereo Mono? Reply with quote
Check this out, I would give these guys a call.
https://edcorusa.com/collections/stereo-to-mono-co...ansformers
'69 Beetle (pieces)
harrymarlin
PostPosted: Wed May 17, 2023 9:16 am    Post subject: Re: Make my Stereo Mono? Reply with quote
It looks interesting, but it looks like it accepts line level (unamplified) inputs and outputs line level (unamplified). What I would need would be amplified (powered) stereo inputs to amplified (powered) mono output. I don't believe that the Sapphire VIII can be bridged. Perhaps what I'm looking for isn't possible?
-Harry
clockworkbox
PostPosted: Wed May 17, 2023 10:03 am    Post subject: Re: Make my Stereo Mono? Reply with quote
Shoot an email to this guy and see if he can help you. I would not risk damaging your radio, it is rare and you want to be sure that you are doing the conversion the right way. Good luck!
[email protected]
'69 Beetle (pieces)
harrymarlin
PostPosted: Wed May 17, 2023 10:28 am    Post subject: Re: Make my Stereo Mono? Reply with quote
[email protected]
Thanks! I just sent off an e-mail. I really appreciate your help, and I'll follow up, here.
-Harry
edjose17
edjose17 is offline
PostPosted: Thu Aug 14, 2025 10:27 am    Post subject: Re: Make my Stereo Mono? Reply with quote
Did you receive a response?
harrymarlin wrote:
[email protected]
