dlyle Samba Member
Joined: March 22, 2019 Posts: 313 Location: Morgan Hill
Posted: Fri Jun 02, 2023 2:41 pm Post subject: 1969 Manx project |
I found this beautiful Manx two weeks ago and got to see it for the first time this morning. It was about 600 miles away from me but my buddy Chris Hersh volunteered his time to go pick it up and bring it to me. So this morning at 1:30 he showed up and we unloaded it.
It looks like a good early 70's type build. The Commando XT70's and Grantmaster Super 120 tires go all the way back to the mid 60's so who knows how old the tires are. One of the tires must have a flat spot or a bulge because it was a bumpy ride. It has a bit of a crash in the hood that they tried to cover up with flat paint but overall this Manx is in great shape.
Immediate plans are to replace the tires, go through the brakes and tune it up. It's a bit rough at idle and the front brakes pull to the right. Future plans will include fixing the hood (see you soon Miguel), replacing the seats with something a little more 1970, and replacing the cracked windshield. I'd also like to find the same wheels but maybe a different offset to pull them in under the fenders a bit more.
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4599 Location: Fair Oaks/Orangevale, CA
Posted: Fri Jun 02, 2023 2:47 pm Post subject: Re: 1969 Manx project |
Congratulations on your find. It look like it a cool period Manx.
Did you find any parts at the Bugarama?
I looked for you after I setup the Wampuskitty in the show area.
Also cool looking Vaquero buggy you have.
This is when I first put my Kick Out together
This what it looks like now.
I like orange buggies too. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Fri Jun 02, 2023 2:58 pm Post subject: Re: 1969 Manx project |
Also cool looking Vaquero buggy you have. _________________ Joseph
Elrod Motorsports
dlyle Samba Member
Posted: Fri Jun 02, 2023 3:00 pm Post subject: Re: 1969 Manx project |
jsturtlebuggy wrote: |
Also cool looking Vaquero buggy you have. |
Joseph, it really is a small world. Miguel had described the rack on your truck and when you turned in to Bugorama I knew it had to be you.
I got a couple of parts but nothing too exciting. If you are ever down this way (Morgan Hill) reach out to me. If I'm up your way I'll reach out.
I hung out at your car for a while but didn't see you.
Your Kick Out is beautiful! |
oprn Samba Member
Joined: November 13, 2016 Posts: 14777 Location: Western Canada
Posted: Fri Jun 02, 2023 3:50 pm Post subject: Re: 1969 Manx project |
Sweet period correct Manx! I love it, clean and uncluttered!
I wish I was close enough to buy those seats, they look very comfortable for long distance drives! Good luck with the tune up and let us know how it turns out. I see several things you might want to change to make it run better but try the tune up first. _________________ Our cars get old, we get old but driving an old VW never gets old! |
dlyle Samba Member
Posted: Fri Jun 02, 2023 4:00 pm Post subject: Re: 1969 Manx project |
oprn wrote: |
I wish I was close enough to buy those seats, they look very comfortable for long distance drives! Good luck with the tune up and let us know how it turns out. I see several things you might want to change to make it run better but try the tune up first. |
I'm all ears for things to change to make it run better. Will start with getting an intake that has the heat risers. Need to change the plugs and get a blue Bosch coil. I usually get rid of the points too and install a Pertronix but haven't even looked to see if they have those. Probably will go to an alternator too to get rid of the external regulator.
Here's some shots of the engine.
Posted: Fri Jun 02, 2023 7:59 pm Post subject: Re: 1969 Manx project |
Sorry I missed seeing you. My Brother and I setup in the car show and then went to the swap meet area.
Here a picture of my Ford truck with a different buggy rack on it. I had to build a new rack as it not fit the Dodge bed. The Manxter Dual Sport I built before the Kick Out.
I sold it to another club member. When I built it in 2008 there was only about five Dual Sports that had been finish and drivable.
Elrod Motorsports
oprn Samba Member
Posted: Sat Jun 03, 2023 4:33 am Post subject: Re: 1969 Manx project |
I will just tell you what I would change on the engine if it were my Buggy. You can do as you like.
1) find a stock distributor that matches the carb, with vacuum advance. Pertronics are WAY over rated, been there, done that and it failed in very few miles. Points last for years and require very little attention. https://www.thesamba.com/vw/forum/viewtopic.php?t=711733&highlight=
2) move the fuel filter to over the transaxle. Then if it leaks it won't be on the ignition wires.
3) with the intake change, drill the exhaust heat riser port on the left side but on the right side cut the flange off, build a 1/2" tube to go from the intake to the "U" bend just before the muffler. Have it extend into the middle of the "U" bend and slash cut the tip facing the muffler. That will give you good flow through the heat riser. More ideas in this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=755518&highlight=
4) take the air cleaner off and check to see that it has a tube above the carb to contain the fuel stand off. I think the stock one was about 3 or 4 inches tall. I would bet the farm that yours doesn't.
5) complete the cooling system with all the bottom tins, thermostat and flaps for more consistent engine temperatures all around. Helps make the engine easier to tune, improves drivability by running more consistent highway vs around town, the engine lasts longer and warms up quicker.
I just run the stock generator but then I have no extra lights, fancy sound systems and don't do much night driving.
This is all based on personal experience with stockish engines over the years. Do as you like. _________________ Our cars get old, we get old but driving an old VW never gets old! |
dlyle Samba Member
Posted: Sat Jun 03, 2023 8:28 am Post subject: Re: 1969 Manx project |
oprn wrote: |
This is all based on personal experience with stockish engines over the years. Do as you like. |
Sounds like good ideas thanks for pointing them out. The only one I'm not clear on is the fuel stand off tube. Do you have a picture of one? Assume that with such a short air cleaner it may not be there. |
oprn Samba Member
Posted: Sat Jun 03, 2023 10:28 am Post subject: Re: 1969 Manx project |
Ok, you will have to overlook my redneck air cleaner warm air intake system using a coffee can and a cookie tin. The base for all that was cut off a stock VW oil bath air cleaner so the actual fuel stand off tube is the stock one. It measures 2.5" on the inside down to the carb or 3" total on the outside including the 1/2" that slips over the carb and the clamp goes around.
This is what the bottom looks like.
Two shots from the top.
And with the air cleaner on, not that it matters...
I hope that helps. _________________ Our cars get old, we get old but driving an old VW never gets old! |
EVfun  Samba Member
Posted: Sat Jun 03, 2023 3:36 pm Post subject: Re: 1969 Manx project |
dlyle wrote: |
If you look inside a stock oil bath air filter from a Bug you will see the inside tube goes from the carb to top of the filter. The filter mesh is updraft, then down from right under the top to the carb. That tube length above the carb is needed. I dont fully understand why, but it has to do with the pulsing airflow. Since a Berry Mini-T has no space above the fan shroud I went with a stock Bus/Ghia 40 horse air cleaner pipe for the effect. With a Manx I suspect you have room for a stock filter or short extension pipe between the carb and an aftermarket air filter.
Wildthings wrote: |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1024 Location: South Florida
Posted: Sat Jun 03, 2023 5:30 pm Post subject: Re: 1969 Manx project |
I was trying to make sure my aftermarket air cleaner fit my carburetor better, i.e. without leaking. (See: Tiny hole directly above funky old hose clamp center of top left pic.) Bought a drain plumbing connector at Home Depot, and cut it up to do the job. It ended up giving me a short little velocity stack. So that while achieving my leak-free goal, to my amazement it made my engine run better; smoother, stronger, even at idle, allowing me to lower idle RPM to ~600.
slayer61 Samba Member
Posted: Mon Jun 05, 2023 7:06 am Post subject: Re: 1969 Manx project |
Well done Doug. It seems you have a serious addiction to kit cars. There's probably a 12 step program for that, you know.  _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2884 Location: HdG, MD & NJ
Posted: Tue Jun 06, 2023 2:26 pm Post subject: Re: 1969 Manx project |
Where’s the Vokaro? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
dlyle Samba Member
Posted: Tue Jun 06, 2023 2:53 pm Post subject: Re: 1969 Manx project |
slayer61 wrote: |
Well done Doug. It seems you have a serious addiction to kit cars. There's probably a 12 step program for that, you know.  |
My wife sent you right? |
dlyle Samba Member
Posted: Tue Jun 06, 2023 3:09 pm Post subject: Re: 1969 Manx project |
EVfun wrote: |
dlyle wrote: |
Thanks for the explanation. Now I get it. I may have a stock air cleaner housing somewhere around here. With the current filter there is 3.5" of clearance above it. |
EVfun  Samba Member
Posted: Tue Jun 06, 2023 4:08 pm Post subject: Re: 1969 Manx project |
dlyle wrote: |
EVfun wrote: |
dlyle wrote: |
The only one I'm not clear on is the fuel stand off tube. Do you have a picture of one? |
If you look inside a stock oil bath air filter from a Bug you will see the inside tube goes from the carb to top of the filter. The filter mesh is updraft, then down from right under the top to the carb. That tube length above the carb is needed. |
I would suggest not using a 1200cc air filter (36 or 40 horsepower filter) on a later engine. Some have reported that they run rich at the top end, suggesting excess airflow restriction.
You can cut off the snorkel(s) off a stock oil bath air filter to remove the hot air intake for a buggy, not suggested if you plan to run it year-round. Some of the more knowledgeable people in the performance forum here have input on doing that correctly to improve airflow. It was over there I learned about the Bus intake elbow option when lacking room. _________________
Wildthings wrote: |
dlyle Samba Member
Posted: Tue Jun 06, 2023 5:49 pm Post subject: Re: 1969 Manx project |
EVfun wrote: |
dlyle wrote: |
EVfun wrote: |
dlyle wrote: |
You can cut off the snorkel(s) off a stock oil bath air filter to remove the hot air intake for a buggy, not suggested if you plan to run it year-round. Some of the more knowledgeable people in the performance forum here have input on doing that correctly to improve airflow. It was over there I learned about the Bus intake elbow option when lacking room. |
I won't be using a stock filter. I just have one that I can look at to see how it works. I'm not sure what I'll use. Hopefully something with a 1970'ish look. |
Posted: Wed Jun 07, 2023 6:52 am Post subject: Re: 1969 Manx project |
dlyle wrote: |
slayer61 wrote: |
Cusser wrote: |
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
dlyle Samba Member
Posted: Wed Jun 07, 2023 9:57 am Post subject: Re: 1969 Manx project |
slayer61 wrote: |
dlyle wrote: |
slayer61 wrote: |
I only have 8 cars/bodies in a 4 car garage...there must be a way to fit another. |
