metoooo Samba Member
Posted: Mon Jul 03, 2023 1:26 am Post subject: Rear wheel brake cylinder |
Hi.
I need to replace the rear brake cylinders in my 65' Type34.
I've ordered new set using the part number 311611067c.
When I've got the new cylinders I've compared them to the old ones and found that the bleeding nipple location is not the same.
I think they send me a super beetle cylinders.
Can I still use them or should I send them back?
Here is a pic of the cylinders. old on the left, new on the right
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 634 Location: Boston Metro West
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6000 Location: Brooklyn
Posted: Mon Jul 03, 2023 9:46 am Post subject: Re: Rear wheel brake cylinder |
Little known Squareback fact:
The rear wheel cylinders on the '64-'65 are the ones with the 361 part number, which were later used as front wheel cylinders on Super Beetles. They are different from the '64-'65 Notchback wheel cylinders which had a 311 part number.
The 361 Squareback wheel cylinders are larger bore diameter than Notchback rear wheel cylinders. I think about 1 mm difference.
Either one will fit but you should used the Squareback/Super Beetle ones because they are bigger and more braking is better. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22439 Location: Kimball, Mi
Posted: Mon Jul 03, 2023 10:22 am Post subject: Re: Rear wheel brake cylinder |
I agree, use the Squareback wheel cylinders. That's what I did on my 64 T-34. What's nice about using the 66 parts is availability, as the 66 Squareback was imported into the USA. This means parts can be had/ordered from any good auto parts store. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jul 03, 2023 12:54 pm Post subject: Re: Rear wheel brake cylinder |
bob you just reminded me, it was in '66, when the Type 3 started getting disc brakes up front as standard, that the rear wheel cylinders on all models reverted to the smaller 22mm bore 311 part number.
But for '64-'65 when the Type 3 still had drum brakes up front, the Squareback had the larger 361 part number rear wheel cylinders - I think ~23mm bore. _________________ 1965 Volkswagen 1500 Variant S
Posted: Tue Jul 04, 2023 5:04 am Post subject: Re: Rear wheel brake cylinder |
Thank you all for the replies.
I will not use them 'cause it will be almost impossible to blead them when the bleadder is upside down.
I will keep looking for the correct cylinders. |
andybla Samba Member
Posted: Tue Jul 04, 2023 7:21 am Post subject: Re: Rear wheel brake cylinder |
lot's of results come up when googling 311611067C |
