24 x 16 AC Condenser Air Conditioning
vanis13
vanis13 is offline
PostPosted: Thu Jul 20, 2023 12:04 pm    Post subject: 24 x 16 AC Condenser Air Conditioning Reply with quote
Gonna give this one a try. Looks like it will jjjjust clear the radiator temp switch with a little trimming
20% increase over existing 16x20
+64 sq in = + 20% = 64/320
320 sq in = 16x20
384 sq in = 16x24
It is 16" x 24" I believe an 18"x24" would fit with the height but I couldn't find one.
16x24
https://www.ebay.com/itm/334922079832
My 16x20 install thread from 2010 https://www.thesamba.com/vw/forum/viewtopic.php?p=4776892#4776892
MarkWard
MarkWard is offline
PostPosted: Thu Jul 20, 2023 1:07 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
I’ll have to research the size. Instead of attaching to the radiator, I attached to the body. I used existing holes in the nose for my brackets. I used weatherstrip foam to bridge the gap between the rad and condenser. It happens to be a foam, that when unwound from the roll expands quite a bit. Probably from Lowe’s.
16x 22 with 18” core.
vanis13
vanis13 is offline
PostPosted: Thu Jul 20, 2023 1:26 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
, Based on the clearance you have by the rad switch it can't be a 24
Measurement is from outside of tubes without mounting tabs
The 24 has a 22" core so 4 more inches than the one in your pic. Yours would be a 20"
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Jul 20, 2023 3:02 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
why are you changing it? are you chasing a problem?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
vanis13
vanis13 is offline
PostPosted: Thu Jul 20, 2023 3:37 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
had a compressor crap out. don't know what I'll find inside. Can't flush parallel so a good opportunity to replace.
used to be nice an cold, last year not so much - could have been compressor, could be something else, could be global warming - no reason not to go bigger so I'm going bigger.
MarkWard
MarkWard is offline
PostPosted: Thu Jul 20, 2023 4:21 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
I recall the lower 90 degree fitting limited how close I could move the condenser to the left. Seems to keep the factory routing, the frame rail limited the location.
vanis13
vanis13 is offline
PostPosted: Thu Jul 20, 2023 4:50 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Guess we'll see!
Got a rad switch and it jjjjjust fits!
Will have to trim the mounting tab around the switch.....hope the 90deg fitting isn't an issue.
.....do I have to change my signature until I get the AC going again 😭
dhaavers
dhaavers is offline
PostPosted: Thu Jul 20, 2023 9:10 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Do you have the full set of baffles to install around the condenser?
Mark’s point about foam, sealing to the radiator is equally valid…
As long as you’re going for it, I say go for it! Twisted Evil
- Dave
"The WonderVan"
vanis13
vanis13 is offline
PostPosted: Thu Jul 20, 2023 9:16 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
I do and with this condenser, I will have to make new ones since the original baffles go to the edge of the radiator core and this condenser is wider than that...I'll come up with something and will share pictures
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Sun Jul 23, 2023 8:38 am    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
I have been completely rebuilding/refurbishing my 87 aircon with all new barrier hoses, EZ clip fittings, etc. I was looking for a new parallel flow condenser and inadvertantly ordered a 24x16...D'OH! Brick wall.
I routed my hoses to the PS, trimmed the flange for the fan switch, and was able to utilize the larger unit.
[/img]
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
1991 Jetta coupe TD. Giles Superpump. SOLD
vanis13
vanis13 is offline
PostPosted: Sun Jul 23, 2023 2:45 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
big swifty wrote:
Nice to see it can fit!
Interesting your connection is on the passenger side. My 83.5 and my friends 90 that I work on both have it on the driver's side.
big swifty
PostPosted: Sun Jul 23, 2023 3:54 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Connection is on driver side.
Evan
big swifty
PostPosted: Sun Jul 23, 2023 4:43 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Deleted.
posted to wrong thread
Evan
vanis13
vanis13 is offline
PostPosted: Sun Jul 23, 2023 7:02 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Do you have a right hand drive van? I see on the right in your picture the radiator switch. That is the left side as sitting in the van which is the driver's side in the USA.
The condenser connection in your photo is on the left of the picture which is the right sitting in the van, which is where the passenger sits in the USA.
My condenser connections are on the side where the radiator switch is.
big swifty
PostPosted: Mon Jul 24, 2023 4:44 am    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
I was flustered, sorry for the misunderstanding. LHD. I was thinking about the rad fan switch. I flipped the condenser and routed the lines to the passenger side.
Evan
vanis13
vanis13 is offline
PostPosted: Thu Aug 10, 2023 1:43 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
It fits!
The 24*16 is a juuuust right.
Will button it up later. These pics are with a behr radiator. I have a diff brand where the passenger side is proud of the core only at the bottom and top. On y he e behr it doesn't look like any trimming is needed on the pass side. Yes, the radiator switch is close. Likely need to move the radiator back to replace.
Helped to bend the lower pipe to clear the steering box. This is an early AC, IIRC the later AC has a closer fitting so will likely fit w.o bend.
vanis13
vanis13 is offline
PostPosted: Sat Aug 26, 2023 1:24 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
[/img]
Can you send a picture of the top connection?
I'm also going to flip my condenser with the fittings on the passenger side but the top fitting doesn't fit well against the radiator bulge.
big swifty
PostPosted: Sun Aug 27, 2023 10:37 am    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Not the greatest pics. This one shows the angle of the dangle. I used 90* fittings.
This one shows the coziness of the radiator.
Hope they help.
Evan
vanis13
vanis13 is offline
PostPosted: Sun Aug 27, 2023 3:02 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
big swifty wrote:
This one shows the coziness of the radiator. Hope they help.
Thanks, they do! Thanks for posting them.
How were you able to fit the side tube and still have the radiator in the top alignment pin?
What kind of radiator do you have?
I have a non-Berh so have only the bulge on top and bottom (the Berh has the bulge all the way top to bottom) - so on mine I was able to lower to get under it. With it up higher the radiator wouldn't align in the top pin. The fitting on the driver's side, it is not an issue with this bulge since just the mounting tab needs to clear.
Another solution may be to tilt the radiator back by inserting a spacer on the bottom mount tab between the tab and the frame and use longer bolts. That angle may allow for the clearance needed between the radiator bulge and the front center body horizontal beam....I didn't try this so just an idea.
vik
vik is offline
PostPosted: Sat May 10, 2025 2:40 pm    Post subject: Re: 24 x 16 AC Condenser Air Conditioning Reply with quote
Can we clarify that these are the dimensions I can fit?
Or what would be the other option for condenser? Need to buy something local...
T3 Syncro camper in progress
