Beetles and Fires?
Page: 1, 2, 3 ... 13, 14, 15  Next
WaterboysSuper71
WaterboysSuper71 is offline
PostPosted: Mon Aug 29, 2005 10:39 am    Post subject: Beetles and Fires? Reply with quote
How susceptible is a Beetle to catching on fire. Every once in awhile I run across a story in the forum that ones Beetle caught fire. Is this a common problem? What can be done to help prevent a fire from occuring Question
Patty B.
Patty B. is offline
PostPosted: Mon Aug 29, 2005 11:35 am    Post subject: some causes of fires Reply with quote
Most captions for those pictures or stories go like this 'See what happens when you don't move the fuel filter away from the engine!'. Move it away from the usual spot between the distributor and the coil and clamp it in where you do put it. Check that the metal tube the fuel line enters the carb is tight -some tend to loosen with age. Check the fuel pump to be sure no bolts have loosened--on my '69 the four little screws on the very top came loose enough to rattle, I smelled the fuel before a fire luckily. And I guess just plain old time and heat on old rubber fuel lines can cause a crack and leak. I believe most people carry fire extinguishers with them just in case.
Of course I'm one to talk, I have yet to move the filter myself! What the heck, my battery won't hold a charge this year so I haven't gone anywhere boo hoo.
Delaware Dave
Delaware Dave is offline
PostPosted: Mon Aug 29, 2005 11:52 am    Post subject: Reply with quote
It happens all too often. Just recently two members have lost their bugs due to fire.
The best advice is this. Follow the guidelines set up by the more experienced members for the forums. In a nutshell:
1.If your fuel filter is located in the engine compartment, relocate it to the fuel line under the tank.
2.Replace all your rubber fuel lines on a schedule, say, every other year, or more often if they look/feel hard, cracked etc... (Don't forget the line from the pan to the engine firewall, just at the rear axle)
3.When replacing fuel lines, use the good stuff. The Euro line is fabric coated on the outside, usually gray in color. 5mm internal diameter for carb setup, 7mm for fuelies.
4.Use good hose clamps at all connection points. I use clamps from the local Mercedes Benz place, and they work perfect. Just ask for fuel line clamps. They will be kind of gold in color, and have a clamping band all the way around them. They close with a phillips head screwdriver. They will have an actual MB part number. Don't let then give you a generic hose clamp. (Generic will work okay, but it defeats the purpose of going to MB in the first place).
5.Check the rubber grommet that protects the metal fuel line as it comes through the engine firewall from rear axle area. Replace it if it's worn or old and cracked. That metal line can wear through at this point and cause a leak.
6.No matter what, carry a fire extinguisher!
\X/ Delaware Dave
'71 Standard Beetle Project
'69 Type 3 fastback (sold), '65 Standard Beetle (sold),
'05 Passat 1.8 Turbo, '97 Jetta Tdi (sold)
Miguel Arroyo
Miguel Arroyo is offline
PostPosted: Mon Aug 29, 2005 5:20 pm    Post subject: Reply with quote
Excellent well written advice. I would only add to periodically check the condition of the fuel lines (say monthly, or before/after a long trip). Good luck.
Max Welton
Max Welton is offline
PostPosted: Mon Aug 29, 2005 5:36 pm    Post subject: Reply with quote
Here:
http://groups.google.com/group/rec.autos.makers.vw...mp;rnum=13
Max
1967 Type-3 Fastback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Aug 29, 2005 5:53 pm    Post subject: Reply with quote
Normal maint, change the 30+ year old fuel hoses and carry a fire exstingushier.
I had a small filre, but it was due to a backfire igniting the air cleaner.
464,000 miles and never a fuel related fire.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bandi
bandi is offline
PostPosted: Mon Aug 29, 2005 8:20 pm    Post subject: Reply with quote
I discovered a fuel leak around the accelerator pump diaphragm on my '66 1300, it looked minor, but after driving for a few minutes, the fuel was literally pouring out. Glad I noticed it!
WaterboysSuper71
PostPosted: Wed Aug 31, 2005 6:10 pm    Post subject: Reply with quote
Thanks guys for all your advice and tips on how to keep my family and my bug safe. I will follow all advise. Seems like the first thing I need to do is get rid of that damn fuel filter!
Delaware Dave
PostPosted: Thu Sep 01, 2005 10:56 am    Post subject: Reply with quote
I do hope you mean "relocate" Wink
\X/ Delaware Dave
jgaudiello
jgaudiello is offline
PostPosted: Sun Sep 04, 2005 11:04 am    Post subject: Reply with quote
I'm a fairly new bug owner and am concerned that I may have a potential problem in this area. I want to make sure I know what I'm doing before I cause a fire instead of preventing one. My fuel filter is in the engine compartment and the rubber hoses are not clamped at the filter. I want to change it and put clamps on it but I have some questions. How do I clamp the lines without damaging them while changing the filter and what type of clamps should I use at the filter connections?
Thanks!
Mr. 010
Glenn is offline
PostPosted: Sun Sep 04, 2005 11:35 am    Post subject: Reply with quote
Standard worm gear hose clamps work well. Don't use those cheap $0.50 filters. Get a Fram G2 like I use. The have a bulge on the end to prevent the hose from pulling off.
Use genuine German woven hose and not 1/4" rubber hose.
Having the filter in the engine compartment is not the problem. One problem is the brass inlet on the stock carb. Most are just pressed in and when you hand a fuel filter on it, they sometimes pull out due to the vibration and weight of the filter full of fuel.
Another major cause is the lack of normal maint.
Change the hoses every few years. Change the filter every year. Distributor cap and wires should also be changed so they don't arc.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
jgaudiello
PostPosted: Sun Sep 04, 2005 12:35 pm    Post subject: Reply with quote
Thanks! Where can I get the woven fuel hose?
Delaware Dave
PostPosted: Sun Sep 04, 2005 12:38 pm    Post subject: Reply with quote
Thanks!
Sounds like you're worried about fuel spilling while your changing the filter. The amount in the line isn't a lot, even with the big filter. I place a rag under the line, and slowly work the top connection off the carb, then tip it upside down, and drain out what I can like into a cup or something. The lawnmower doesn't care where it's next drink is coming from. Then I take the connection off the pump. The good fabric-braided 5mm fuel line is still very cheap, so I changing it every time.
I have to agree with Glenn. The cheap filter that is most commonly available doesn't have a bulb or a spur on it that grabs and hold onto the fuel line. Check this out:
The two on the right I picked up at a motorcycle shop last week. I'm thinking of trying the smallest one, next time I change filters. Either of the ones on the right are easier to see through, so I should see any crud if it builds up. I want to try the smaller one so that there is a minimum of weight on the brass inlet on the carb. They both have barbed ends so that when used with hose clamps, there's almost no chance of them coming off. You can use the small hose clamps that Glenn mentioned. I use ones from Mercedes Benz (I used to work there) just because I like them better.
In fact, when I change fuel filters, I usually cut two new sections of line, attach them to the filter and put on the clamps on either end of the filter before I ever open the engine lid. All I have to do then is pop the old one off the carb and the fuel pump, and put the new one on. Takes only a few minutes, and if you make two filters like this, you can carry one in your trunk, just in case.
\X/ Delaware Dave
Mr. 010
Glenn is offline
PostPosted: Sun Sep 04, 2005 12:39 pm    Post subject: Reply with quote
Most catalog and online vendors sell German fuel hose. You can also get it from a vendor at a show.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Delaware Dave
PostPosted: Sun Sep 04, 2005 12:40 pm    Post subject: Reply with quote
My local Euro auto parts place has it, so maybe yours does too. The trick is to ask for the 5mm size, don't get the SAE stuff, it might be just large enough to slip off.
\X/ Delaware Dave
Mr. 010
Glenn is offline
PostPosted: Sun Sep 04, 2005 12:50 pm    Post subject: Reply with quote
There's actually 2 sizes... 5mm and the large is either 7mm or 7.7mm.
For a stock engine, get the smaller.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
John M.
John M. is offline
PostPosted: Sun Sep 04, 2005 1:26 pm    Post subject: Reply with quote
I really like Bughaus.com. I ordered some 5mm German Braided Cloth Line for $3.99 a meter.
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Desertbusman
Desertbusman is offline
PostPosted: Sun Sep 04, 2005 4:20 pm    Post subject: Reply with quote
Yep, a lot of them burn. Check out the underside of engine lids and around the engine compartments of a bunch of VW's and see the evidence. Of course you probably won't find blistered paint and soot in nice shinny restored ones. A lot of times it was a fire that prompted the restoration.
I have had the habit of checking the engine, on top and underneath, frequently. Everytime I stop at a highway rest stop and frequently at gas station fill-ups. One of the best preventions is keeping it all clean and spotless all the time. Then any kind of a leak (fuel or oil) is real quick and easy to spot. Also there isn't the slime and junk to burn. And just because it's a woven fabric covered fuel line doesn't mean it is good. Not all are German good quality. Some have been leakers real quick. Months, not a year or two. Keep it all clean and dry and a hose that gets damp or seeps is easy to spot. And every part of the whole system, from one end to the other, and every item involved, is a potential problem spot. Every clamp, screw, connecter, gasket, tube, hose, etc. Check them closely and often.
And there are a lot of other good posts on Samba. Here were a couple recently. I would be afraid to type in "fire" and hit the search button. Might just overload my computer.
http://www.thesamba.com/vw/forum/viewtopic.php?t=131189&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=126925&highlight=
It's good this is a repeat topic. We need the reminder.
71 Superbug
71 Westy
Mr. 010
Glenn is offline
PostPosted: Sun Sep 04, 2005 4:24 pm    Post subject: Reply with quote
I just made it a "sticky"?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
73speedbug
73speedbug is offline
PostPosted: Mon Sep 05, 2005 10:52 pm    Post subject: Reply with quote
not only do you need to worry about gas fires, but under back seat fires. I was in need of a new battery on my 1st bug so being young and not doing my own work at thetime, I took it to sears for a new one. on the way back home with the wife and two kids strapped in the back seat, we heard a bunch of cars honking and my wife noticed smoke in the car. I pulled over and literally yanked my screaming kids out of the car and pulled my back seat out to find under the seat was on fire. i used my daughters jacket to put out the fire. Foud out they did not put the plastic caps over the battery and when I was going over bumps the kids bouncing was making the back seat springs hit the positive post on the battery. Sparking and igniting the burlap stuffing under the seat. Ruined all the wiring and heating my kids butts up real hot. Needless to say I chewed some sears ass and got a new battery and wiring. So check out under your rear seats and cover that battery.
Page 1 of 15
