50Splitman Samba Member
Posted: Sat Sep 30, 2023 12:18 pm Post subject: Carpet cut out for seat - 1950 standard |
| Can someone help me with how much to cut out the carpet for the seats in a 50 standard? I purchased a very nice carpet set for my standard from Marcus, but since there aren't seat tracks on a standard pan, I don't know where to allow for the seat to rest. I'm thinking simply to cut around the seat frame area, as I can't imagine the seat rests on the carpet before tightening the wing nut. Thanks |
Posted: Tue Oct 03, 2023 6:20 am Post subject: Re: Carpet cut out for seat - 1950 standard |
Bumping this thread - maybe I need to ask a different way.
For anyone who has an original standard split window beetle, is the outer seat frame next to each door sitting on top of the carpet, or is the carpet area cut out and the seat frame sits directly on the floor pan?
Thanks |
cory464 Samba Member
Joined: November 25, 2010 Posts: 682 Location: kokomo in
Posted: Tue Oct 03, 2023 12:15 pm Post subject: Re: Carpet cut out for seat - 1950 standard |
| 50Splitman wrote: |
Thanks |
I do not know, but i would say there is no risk to letting the seat sit on the carpet. worst case scenario is it makes marks on the carpet so you will know where to cut. |
Posted: Tue Oct 03, 2023 4:34 pm Post subject: Re: Carpet cut out for seat - 1950 standard |
| So true! I've been searching through the gallery looking for pictures that would show me what I'm looking for. I'd rather not cut the carpet if I am not supposed to. |
TRS63 Samba Member
Joined: December 17, 2017 Posts: 1134 Location: Stuttgart - Germany
Posted: Wed Oct 04, 2023 9:06 pm Post subject: Re: Carpet cut out for seat - 1950 standard |
| Thank you! |
TRS63 Samba Member
Two Glove Boxes Samba Member
Posted: Thu Oct 05, 2023 11:11 am Post subject: Re: Carpet cut out for seat - 1950 standard |
| 50Splitman wrote: |
Thanks |
I have mine resting on top of the carpet, which I have seen on some standard restorations, but originally the standards only had the rubber mat on the tunnel, and the original carpet wasn't that long to be underneath on the outer frame from what I've seen. I do like it on mine; it adds 1% more comfort. 😂 I hope that helps. _________________ 1950 Deluxe Sedan Build
Two Glove Boxes IG |
beetlekey Samba Member
Posted: Sat Oct 07, 2023 10:41 am Post subject: Re: Carpet cut out for seat - 1950 standard |
There are two wingnuts, just make a little hole in the carpet were the screw is. This is not rocket since _________________ Hebmüller 581
1953 oval Typ 11G metalblue
1966 1300
If you are searching for vintage keys, look here:
https://www.facebook.com/WagenmanufakturHO |
RustPatch Samba Member
Joined: August 07, 2007 Posts: 139 Location: Maple Ridge BC Canada
Posted: Sat Oct 07, 2023 2:28 pm Post subject: Re: Carpet cut out for seat - 1950 standard |
For what it's worth.
These pics aren't of a split standard, they're of a 1957 Canadian Custom (standard). They show the carpets that cover the heater channel are cut around the seat and have a binding/border at the edge.
_________________ I've been known to be wrong. |
