bajabones Samba Member
Joined: April 17, 2019 Posts: 146 Location: Tacoma, WA
Posted: Sun Dec 03, 2023 6:27 pm Post subject: How to mount WBX to Harbor Freight engine stand? Solved! |
How do you mount a WBX to a HF engine stand?
_________________ 1990 Syncro Doka
2.1 DJ
Triple Knob
Solid shaft
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80666 Location: Sneaking up behind you
Posted: Sun Dec 03, 2023 6:29 pm Post subject: Re: Engine stand |
You buy a VW engine yoke like this:
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Posted: Sun Dec 03, 2023 6:30 pm Post subject: Re: Engine stand |
Where do I get one? _________________ 1990 Syncro Doka
2.1 DJ
Triple Knob
Solid shaft |
steve244 Samba Member
Glenn  Mr. 010
Posted: Sun Dec 03, 2023 7:22 pm Post subject: Re: Engine stand |
| bajabones wrote: |
| Where do I get one? |
I got mine from VintageWorldTools but they seem to not be around anymore.
Don't get a cheap one.. they bend and you'll find the engine on the floor the next morning. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1554 Location: san diego
Posted: Sun Dec 03, 2023 8:30 pm Post subject: Re: Engine stand |
if you have a drill and a grinder, you can make some adapters out of 2'' x 1/4'' plate.
l don't have pictures, but that's what l have done, l don't have space for an extra head for my engine stand, it currently has an inline 4 on it, it's had the occasional EJ22 on it, making adapters made my life easier. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 663 Location: Hi-top Country
Posted: Sun Dec 03, 2023 8:34 pm Post subject: Re: Engine stand |
This is how I modified my stand to accommodate a wbx. I drilled new holes in the plate then added thick washers with one side ground out to clearance the back rib of the wbx. Seems to do the trick.
_________________ '84 Adventurewagen 1Z TDI, '08 Audi Avant Quattro 6spd BHW TDI, '03 Jetta Wagon 5spd TDI |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 6003 Location: Bemidji, MN
Posted: Mon Dec 04, 2023 4:05 am Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
the VW stand adapter allows you to do critical and important work at the flywheel side of the engine, unlike just using the HF arms:
- measure endplay and do the shim shuffle to get it set right
- install oil seal squarely
- install and remove pilot bearings
- bolt up and torque flywheel
- bolt up clutch
in short, it really is a very useful accessory along with an engine stand. otherwise, you're wrassling it around on the floor or sliding it on a bench to do the above tasks. _________________ -dan
www.thefixitworkshop.com |
Glenn  Mr. 010
Posted: Mon Dec 04, 2023 4:58 am Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
You can't split the case if you use all 4 mounts. And using just 2 can cause the case flange to snap and drop the engine.
I also have a 4 arm yoke for 911 and Type 4 engines. _________________ Glenn
Member #1009
#BlueSquare
jlrftype7 Samba Member
Posted: Mon Dec 04, 2023 6:50 am Post subject: Re: Engine stand |
| Glenn wrote: |
Yes, that's what I did. BUT, I can't remember where I bought my YOKE from...
Ah, memory loss...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Tue Dec 05, 2023 9:53 am Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
Assuming you want to work on the engine then buying the VW Yoke mount is the way to do it.
Or you can be cheap or perhaps halfass lazy like me and mount the engine offset to one side attaching 3 of the 4 bars and still strip the engine down to the case with the exception of the flywheel and then put it on the bench to split the case.
You would not be able to make crankshaft end adjustments or remount the flywheel. That would have to be done on the bench. Maybe you could split the case if you removed the bar mount on the upper right. I don't know if I would want to try it.
You might notice that the right lower bar is not connected as the geometry did not fit.
The engine is secure and it's been on there 5 years until I get around to doing something with it. It is mainly to save shop space and move it easily.
_________________ This free advice is worth exactly what you paid for it.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19163 Location: Retired South Florida
Posted: Tue Dec 05, 2023 10:40 am Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
I have no use for my Krebsfer VW 313 engine stand and yoke. I would consider selling, but freight anywhere would be killer. And doesn't answer you question.
This stand was originally intended for air cooled 1600 and smaller. Its designed so you can split the case and rebuild in the stand. I've done a 2.0 on it, but removed the exhaust to lighten the load. Supporting it by only two contact points when you have a larger engine. I suppose a WBX engine would fit. While still completely functional, This tool is more suited for restoration in someones man cave. Getting rare. Porsche realized the problem with only 2 arms and came up with a yoke with multiple arms to better support. The HB one could work fine till you need to split the case. Might get a little awkward at some point. |
Posted: Tue Dec 05, 2023 5:05 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
| MarkWard wrote: |
Sell it through PayPal and use PayPay shipping. Half the cost of walking into a shipper off the street. But... that looks heavy $$$ _________________ This free advice is worth exactly what you paid for it.
hdenter Samba Member
Joined: October 14, 2008 Posts: 2966 Location: San Luis Obispo, CA
Posted: Tue Dec 05, 2023 6:03 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
I have that very same Krebsfer stand that I inherited from my dad. It held my fully dressed WBXer engine just fine.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Fri Dec 08, 2023 5:48 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
Is this safe with just the top 2 bolts?
2.1 DJ
Triple Knob
Solid shaft |
Posted: Fri Dec 08, 2023 9:29 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
NO!!!
Pick one side and use upper and lower. Also, look at how large the mating surface is on the green stand at each bolt to help spread the load and stress. You will break your case with that set up if you keep adding weight.
On a side note... Is that a CB performance throttle body?
'84 sunroof vanagon
'85 weekender |
Posted: Fri Dec 08, 2023 10:59 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
I will change to 1 side
Thanks
Not CB
VWSS brand
I got Mario at the dub shop to put together a Dual ITB EFI kit for the WBX _________________ 1990 Syncro Doka
2.1 DJ
Triple Knob
Solid shaft |
tjet Samba Member
Posted: Sat Dec 09, 2023 2:05 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
What intakes are those? The ones I had were really narrow at the flange (between the port opening and the edge - around .070") The passenger side sucked in the gasket.
A friend of mine added some metal around the port areas
This is the location where the metal was added (before pic)
These are the "after" pics
The green line represents the original flange thickness on the inboard side
I bought the wbx engine below (RJE 2.2) with the dual IDF's from a forum member here.
Posted: Sat Dec 09, 2023 5:47 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? |
I got my manifolds from CSP in Germany
Where do I get the throttle cable long enough like yours?
2.1 DJ
Triple Knob
Solid shaft |
Posted: Tue Dec 12, 2023 6:38 pm Post subject: Re: How to mount WBX to Harbor Freight engine stand? Solved! |
CLIP 1 EMPI engine stand _________________ 1990 Syncro Doka
2.1 DJ
Triple Knob
Solid shaft |
