navyfam2 Samba Member
Joined: August 31, 2022 Posts: 4 Location: Chattanooga, TN, USA
Posted: Mon Sep 26, 2022 5:28 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Sharp64 wrote: |
It’s advice, donas you want, but I would sincerely consider sending the rears back and getting one of the sizes I mentioned. An 11% difference on the rear is significant. And on the asthetic side, will look kinda goofy. Good luck either way. |
called tire shop, they were able to swap the rears out with 205/60R15.
thanks for the advice... I try and take it when given... but I'm quite impatient at times  |
Ecesp004 Samba Member
Posted: Tue Nov 22, 2022 7:20 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hello, Really need some help. Installed 205/65/15 tires on my 15x8 smoothies. I fender literally sit on the tire so they wont work. I was running 195/55/15 but wanted a beefier looking tire and get closer to the 25 inch overall size for the gearing. What do you guys recommend as far as tire size? Fronts are 135/15
slayer61 Samba Member
Posted: Tue Nov 22, 2022 7:41 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Looks badass but something's gotta give. I say re-index torsions until you are happy with clearance & drive it!  _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger |
brolli21 Samba Member
Joined: February 12, 2023 Posts: 1 Location: Obdam - NL
Posted: Sun Feb 12, 2023 9:41 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I've been looking through this topic since i've bought my '63, looking for some more info on what wheels and sizes i could fit.
After some wrenching i came up with this:
Front:
2,5" Dropped spindles
6" Narrowed adjustable beam (Volksprojects(Dutch)
Monroe Airshocks with 6mm airlines
6,5 x 15" Speedline 3 piece with 145/65r15 Nankang
Rear:
Lowered Adjustable Spring plates
Lowered 1 outer spline
5x130 '67-> Drums modified to fit short axles
9 x 15" Speedline 3 piece with 205/55r15 Nankang
A tiny bit of modeling the edge of the arches to prevent rubbing
panicman Samba Member
Joined: December 18, 2011 Posts: 2629 Location: Canby, OR
Posted: Sun Sep 17, 2023 12:00 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Hey everybody,
I have a completely stock 1960, sitting stock height on 165 15's. Stock smoothies.
I have been out of the game!
Can I install 2.5 lowered spindles and be ok with the 165's?
If it will work, do I need to buy any other hardware to do the job? |
DeathRay64 Samba Member
Joined: February 03, 2019 Posts: 217 Location: Arizona
Posted: Thu Sep 21, 2023 9:42 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I think you will be fine with stock wheels and that drop.
However you probably don't want to do the spindle swap yourself. I did it, but it was quite an undertaking. You need a shop press and a reamer tool and will have to re-bush the link pin carrier. So new pins and bushings.
I added disc brakes which makes the front end 5/8" wider and I hope I still have room, but 2.5" isn't really slammed. _________________ Making VW's and America great again. |
Posted: Sun Sep 24, 2023 10:53 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Thanks Deathray! |
The 1969 Beetle Samba Member
Joined: August 31, 2022 Posts: 12 Location: United Kingdom
Posted: Sun Feb 18, 2024 3:44 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Man this has to be the longest thread on this website! so helpful to have though |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2365 Location: Graz, Austria, Europe
Posted: Fri Mar 01, 2024 3:03 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
To each their own, I guess. Many different routes to take.
Personally I totally dislike narrowed beams, small radial tires, widened deep dish rear wheels and slammed stance. Most all look broken to me and compromised in ride quality. Not hating on all of those you guys, just saying. I am on the other side.
4.50 Firestone and 6.50 Goodrich on 3.50-16 Barndoor bus wheels. dropped spindles. about 3/4 click in the rear. Rides perfectly smooth with added tall highway gearing with factory 4.375 and 1200.
_________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
TastyTuner Samba Member
Joined: March 11, 2010 Posts: 121 Location: Tulsa, OK
Posted: Wed May 08, 2024 9:14 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
1963 Beetle
3.5" beam and drop spindles
4" rear drop plates, limebug shocks
4.5 fuchs with 125s
6 fuchs with 215/70s (likely to go to a smaller tire as they do rub on big dips) _________________ TastyGarage |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18043 Location: Eugene, OR
Posted: Wed May 08, 2024 10:48 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
djfordmanjack wrote: |
That is a good looking Lowered VW.
You ran the Mobil Economy Run!  _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Richard D Samba Member
Joined: October 27, 2011 Posts: 94 Location: Texas City, Texas
Posted: Wed May 08, 2024 11:15 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Love the wide whites. I like really low cars but not the rubber band tires or camber. |
Posted: Wed May 08, 2024 1:15 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Mike Fisher wrote: |
You ran the Mobil Economy Run!  |
I wish I had !
Tomorrow going on a 600 mile round trip to Southern Germany, let's see about the economy side of tall rear tires.... I will report back on mpg  _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
Posted: Sun May 12, 2024 1:53 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
I am back from my weekend trip to Bavaria and the tall 16" highway gearing is amazing.....
The engine is a mid 1970s D factory 'Austausch', setup with old fan housing and stale air heaters. but contemporary 30 Solex and 1970s type distributor. engine is a bit tired but very reliable.
On country roads I was driving in the 70-100km/h range (ca. 45 to 60 mph).
I got 6.64 liters per 100 km, that's approx 35mpg.
Odometer and speedo readings are correct.
54 Oval project
Nebenz Samba Member
Joined: June 20, 2015 Posts: 14 Location: Los Angeles, CA
Posted: Sat Jun 08, 2024 1:19 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Greetings, I know this post requires pictures and descriptions on wheels, etc., but I have a basic question. I have a 65 VW bug with 67 transaxles (1 1/2" longer) . I am having custom Chromies made, so how deep can I go without the tires rubbing on the fenders. Additionally, how deep can I go in the front as well. Btw, the car is not lowered yet. Thank you! |
Gamba1973 Samba Member
Joined: May 17, 2024 Posts: 34 Location: Perth Western Australia
Posted: Tue Jul 09, 2024 3:30 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Wily wrote: |
clay showalter wrote: |
Can anyone help? I really want to get my new wheels and tires on my bug |
195 is a wide tire for the front, that wouldt look good
i would take 165 max, even 145 is possible...
195 will touch the inner fenders...
I just bought spindels and some 5.5 rims.
The tires i gonne buy are:
front: 145/65
rear:165/80 |
Gday Wily, do you have any photos of your setup?
we just bought a stock 61 and was thinking of 2 1/2 inch spindles and same wheels, what tyre size worked for you? dont really want to start cutting beam for adjusters or getting a narrowed beam if we dont have too..
thanks. |
CLASSIC CAR GUY Transport and Title Guru
Joined: August 09, 2010 Posts: 1611 Location: Phoenix AZ, but originally from Long Island NY
Posted: Mon Oct 21, 2024 10:12 pm Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Haven't posted in 10 years kinda fell out of the VW scene. My 64 has been in storage for the last 10yrs, but picked up this 66
Just did
MOBELWAGEN Wheels
4.5 with 165 65 15
5.5 with 215 65 15
Drop spindles
1 outer click on rear
[/img] _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
"every one wants to reinvent the wheel, but nobody knows how to make it round"
Vintage Volkswagen Sales and Service as well as Classics and Muslcecars all located here in Phoenix Arizona at www.rpmotorcars.com |
ppilotmike  Samba Member
Joined: December 10, 2019 Posts: 75 Location: Oscoda Mi
Posted: Tue Oct 22, 2024 5:54 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
You're car looks perfect with that set up? Are your wheels steel or aluminum? good luck with the sale. |
Posted: Wed Oct 23, 2024 1:32 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
ppilotmike wrote: |
MOBELWAGEN Alloys
https://mobelwagen.com/?srsltid=AfmBOopIzmPrTTKkkcsryLO9NTClvZLKcV-g5yFF1mmA1xs2A487gOF_ _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
shanered Samba Member
Posted: Thu Nov 14, 2024 9:12 am Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's |
Droppy spindles, one spline in back., sway bar, gas shocks valved for th 700 lb curb weight175/60 and 205/70. Handled good before the wreck.
