Pictures of tire, wheel, and suspension thread for FAQ's
Page: Previous  1, 2, 3 ... , 113, 114, 115  Next
navyfam2
navyfam2 is offline
PostPosted: Mon Sep 26, 2022 5:28 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Sharp64 wrote:
It’s advice, donas you want, but I would sincerely consider sending the rears back and getting one of the sizes I mentioned. An 11% difference on the rear is significant. And on the asthetic side, will look kinda goofy. Good luck either way.
called tire shop, they were able to swap the rears out with 205/60R15.
thanks for the advice... I try and take it when given... but I'm quite impatient at times Wink
Ecesp004
Ecesp004 is offline
PostPosted: Tue Nov 22, 2022 7:20 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Hello, Really need some help. Installed 205/65/15 tires on my 15x8 smoothies. I fender literally sit on the tire so they wont work. I was running 195/55/15 but wanted a beefier looking tire and get closer to the 25 inch overall size for the gearing. What do you guys recommend as far as tire size? Fronts are 135/15
slayer61
slayer61 is offline
PostPosted: Tue Nov 22, 2022 7:41 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Looks badass Cool but something's gotta give. I say re-index torsions until you are happy with clearance & drive it! Very Happy
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
MSD Box and distributor
1 5/8 merged collector w/ hater stinger
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
brolli21
brolli21 is offline
PostPosted: Sun Feb 12, 2023 9:41 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
I've been looking through this topic since i've bought my '63, looking for some more info on what wheels and sizes i could fit.
After some wrenching i came up with this:
Front:
2,5" Dropped spindles
6" Narrowed adjustable beam (Volksprojects(Dutch)
Monroe Airshocks with 6mm airlines
6,5 x 15" Speedline 3 piece with 145/65r15 Nankang
Rear:
Lowered Adjustable Spring plates
Lowered 1 outer spline
5x130 '67-> Drums modified to fit short axles
9 x 15" Speedline 3 piece with 205/55r15 Nankang
A tiny bit of modeling the edge of the arches to prevent rubbing
panicman
panicman is offline
PostPosted: Sun Sep 17, 2023 12:00 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Hey everybody,
I have a completely stock 1960, sitting stock height on 165 15's. Stock smoothies.
I have been out of the game!
Can I install 2.5 lowered spindles and be ok with the 165's?
If it will work, do I need to buy any other hardware to do the job?
DeathRay64
DeathRay64 is offline
PostPosted: Thu Sep 21, 2023 9:42 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
I think you will be fine with stock wheels and that drop.
However you probably don't want to do the spindle swap yourself. I did it, but it was quite an undertaking. You need a shop press and a reamer tool and will have to re-bush the link pin carrier. So new pins and bushings.
I added disc brakes which makes the front end 5/8" wider and I hope I still have room, but 2.5" isn't really slammed.
Making VW's and America great again.
panicman
panicman is offline
PostPosted: Sun Sep 24, 2023 10:53 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Thanks Deathray!
The 1969 Beetle
The 1969 Beetle is offline
PostPosted: Sun Feb 18, 2024 3:44 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Man this has to be the longest thread on this website! so helpful to have though
djfordmanjack
djfordmanjack is offline
PostPosted: Fri Mar 01, 2024 3:03 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
To each their own, I guess. Many different routes to take.
Personally I totally dislike narrowed beams, small radial tires, widened deep dish rear wheels and slammed stance. Most all look broken to me and compromised in ride quality. Not hating on all of those you guys, just saying. I am on the other side.
4.50 Firestone and 6.50 Goodrich on 3.50-16 Barndoor bus wheels. dropped spindles. about 3/4 click in the rear. Rides perfectly smooth with added tall highway gearing with factory 4.375 and 1200.
54 Oval project
62 Dickholmer, Seeblau L360
TastyTuner
TastyTuner is offline
PostPosted: Wed May 08, 2024 9:14 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
1963 Beetle
3.5" beam and drop spindles
4" rear drop plates, limebug shocks
4.5 fuchs with 125s
6 fuchs with 215/70s (likely to go to a smaller tire as they do rub on big dips)
TastyGarage
Mike Fisher
Mike Fisher is offline
PostPosted: Wed May 08, 2024 10:48 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
That is a good looking Lowered VW.
You ran the Mobil Economy Run! Wink
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Richard D
Richard D is offline
PostPosted: Wed May 08, 2024 11:15 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Love the wide whites. I like really low cars but not the rubber band tires or camber.
djfordmanjack
PostPosted: Wed May 08, 2024 1:15 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
I wish I had ! Very Happy
Tomorrow going on a 600 mile round trip to Southern Germany, let's see about the economy side of tall rear tires.... I will report back on mpg Wink
54 Oval project
djfordmanjack
PostPosted: Sun May 12, 2024 1:53 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
I am back from my weekend trip to Bavaria and the tall 16" highway gearing is amazing.....
The engine is a mid 1970s D factory 'Austausch', setup with old fan housing and stale air heaters. but contemporary 30 Solex and 1970s type distributor. engine is a bit tired but very reliable.
On country roads I was driving in the 70-100km/h range (ca. 45 to 60 mph).
I got 6.64 liters per 100 km, that's approx 35mpg. Shocked
Odometer and speedo readings are correct.
54 Oval project
Nebenz
Nebenz is offline
PostPosted: Sat Jun 08, 2024 1:19 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Greetings, I know this post requires pictures and descriptions on wheels, etc., but I have a basic question. I have a 65 VW bug with 67 transaxles (1 1/2" longer) . I am having custom Chromies made, so how deep can I go without the tires rubbing on the fenders. Additionally, how deep can I go in the front as well. Btw, the car is not lowered yet. Thank you!
Gamba1973
Gamba1973 is offline
PostPosted: Tue Jul 09, 2024 3:30 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Wily wrote:
clay showalter wrote:
Can anyone help? I really want to get my new wheels and tires on my bug
195 is a wide tire for the front, that wouldt look good Very Happy
i would take 165 max, even 145 is possible...
195 will touch the inner fenders...
I just bought spindels and some 5.5 rims.
The tires i gonne buy are:
front: 145/65
rear:165/80
Gday Wily, do you have any photos of your setup?
we just bought a stock 61 and was thinking of 2 1/2 inch spindles and same wheels, what tyre size worked for you? dont really want to start cutting beam for adjusters or getting a narrowed beam if we dont have too..
thanks.
CLASSIC CAR GUY
Transport and Title Guru
Location: Phoenix AZ, but originally from Long Island NY
CLASSIC CAR GUY is offline
PostPosted: Mon Oct 21, 2024 10:12 pm    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Haven't posted in 10 years kinda fell out of the VW scene. My 64 has been in storage for the last 10yrs, but picked up this 66
Just did
MOBELWAGEN Wheels
4.5 with 165 65 15
5.5 with 215 65 15
Drop spindles
1 outer click on rear
[/img]
(0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
"every one wants to reinvent the wheel, but nobody knows how to make it round"
Vintage Volkswagen Sales and Service as well as Classics and Muslcecars all located here in Phoenix Arizona at www.rpmotorcars.com
View user's profile Send private message Visit poster's website Facebook Twitter Gallery Classifieds Feedback
ppilotmike Premium Member
ppilotmike is offline
PostPosted: Tue Oct 22, 2024 5:54 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
You're car looks perfect with that set up? Are your wheels steel or aluminum? good luck with the sale.
CLASSIC CAR GUY
PostPosted: Wed Oct 23, 2024 1:32 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
MOBELWAGEN Alloys
https://mobelwagen.com/?srsltid=AfmBOopIzmPrTTKkkcsryLO9NTClvZLKcV-g5yFF1mmA1xs2A487gOF_
(0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
shanered
shanered is offline
PostPosted: Thu Nov 14, 2024 9:12 am    Post subject: Re: Pictures of tire, wheel, and suspension thread for FAQ's Reply with quote
Droppy spindles, one spline in back., sway bar, gas shocks valved for th 700 lb curb weight175/60 and 205/70. Handled good before the wreck. Crying or Very sad
Page 114 of 115
