What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... , 36, 37, 38  Next
Loren Premium Member
Loren is offline
PostPosted: Fri Dec 22, 2023 2:38 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Here is one of the plates installed on my 59 Ghia
obus Premium Member
obus is offline
PostPosted: Fri Dec 22, 2023 3:12 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks again Loren!! I'll have to search for another pair. That is just 2 that i turned for photos
sputnick60
sputnick60 is offline
PostPosted: Sat Dec 23, 2023 12:23 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Loren wrote:
Those little plates go on the doors and cover the ends of the hinges. I believe 60 was the last year to use them. You should have two per door.
My '66 has them and indeed they're covers for the hinge ends as you say.
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
stcj
stcj is offline
PostPosted: Mon May 06, 2024 6:01 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Part came with doghouse tinware set, doesn't look like hoover bit:
PostPosted: Mon May 06, 2024 10:12 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
It looks like a spark plug wire bracket from a Type 3 but a little bent up
Not the clearest photo but
craigolio1
craigolio1 is offline
PostPosted: Sun Aug 25, 2024 3:00 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hey all.
What’s this hose for? I’m looking at a car which has a port for it on the engine but the hose is not there.
Thanks!
Located in the Toronto area.
1971 Ghia Convertible
Join me on my Karmann Ghia journey.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921
NoDents
NoDents is offline
PostPosted: Sun Aug 25, 2024 3:18 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Should have a tube underneath that will suck warm air from under the 1-2 cylinders.
Part number 113-129-511. D or E
No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020
craigolio1
PostPosted: Sun Aug 25, 2024 3:37 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks so much for the reply.
Where does it send the warm air, and what doesn’t work if it’s missing?
Edit: looks like it’s a pre-heating tube. Sends warm air to the air cleaner to preheat the air being drawn in. Does that sound right?
Edit: and then i found this!!!
https://www.thesamba.com/vw/forum/viewtopic.php?p=10112848&sid=e3f62337669b497851e2300df5fa3daf
Thanks for giving me a direction to go.
Thanks!
Craig
NoDents
NoDents is offline
PostPosted: Sun Aug 25, 2024 5:51 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
OK, you found it. However yours would use a bigger tube than the one in the 66 thread.
No Dents
craigolio1
PostPosted: Sun Aug 25, 2024 6:17 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Noted. Thank’s again.
Craig.
mike yapps
mike yapps is offline
PostPosted: Sat Jun 21, 2025 6:42 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I need help identifying these parts. Looks like the glovebox lid is ghia, but not sure what years. The housing looks to be the same color as the lid so I’m assuming it’s also ghia? But not sure what it is since I’m not too knowledgeable with ghias. Please help me out. I’m also looking to sell these so that’s why I am asking.
Vintrick Premium Member
Vintrick is offline
PostPosted: Sat Sep 06, 2025 4:42 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I have been searching far and wide to find a special seal...
My KG is a1968 Coupe but I know it's on most other years as well.
The seals go on each side of the engine bay floor against the body and are about 4 inches long. There's about a 1/4 inch gap between the engine bay floor and the body and these seals go in the gap.. I am including some photos for reference.. The first two photos are a side shot that shows the shape better.
Hopefully someone can identify it and let me know where I can obtain it from....
Thank you!
sputnick60
PostPosted: Sat Sep 06, 2025 10:13 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thank you!
This seal has the same profile as the inner guard to nose as well as the mud splash panel in the back of the front guard.
https://airheadparts.com/vw-part/door-hinge-pillar-cover-plate-seal-141-805-381/
Nicholas
Vintrick is offline
PostPosted: Sun Sep 07, 2025 5:14 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
sputnick60, Thank you!! That is the one!! Very Happy
SYS64738
SYS64738 is offline
PostPosted: Thu Sep 18, 2025 10:31 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hi folks, any ideas what these two parts are?
The black plastic box looks like a cover box for something. It's got a couple little metal tabs on the sides that look like they'd hook into some slots somewhere.
And the little canister thing with the wingnut on it is connected to a hose that is open on one end and on the other end caped off with that eyelet fastener.
Grateful for any ideas! Thanks!
Edit: I'm pretty sure the hose with the canister and the eyelet ring was part of an old Eberspächer gas heater that was once installed in this ghia.
craigolio1
PostPosted: Sat Nov 01, 2025 4:10 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Hey everyone.
What is this?
It’s in a 1971 Ghia. I have a 1970 parts car and it does not have one…. Doesn’t mean it didn’t at one time. Part of a vapour recovery system? Emissions?
Ultimately I’d like to remove it. My trunk smells like gas and I’m trying to figure out what to fix. I’ll start with couplings and seals and such but I’m curious if I need this?
Thanks.
Craig
jeffrey8164
jeffrey8164 is offline
PostPosted: Sun Nov 02, 2025 1:16 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
It’s the evaporation canister. Part of the early emission control system. There should be a charcoal canister in the engine compartment.
You can remove them if you wish. They’ll have no effect on your fuel smell. Usually, the smell comes the filler tube and old cracked breather lines and fuel lines.
If you do decide to remove it, do so carefully and sell it or give it away in the classifieds here. There are people looking for them for restoration purposes.
Volkswagen!
(Compression 8.7:1)
craigolio1
PostPosted: Sun Nov 02, 2025 2:49 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thank you.
I’ll make sure it finds a good home.
Craig
54rag
54rag is offline
PostPosted: Fri Nov 14, 2025 4:06 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Ghia part?
Il est grand le mystère de la DR
MTT3107
MTT3107 is offline
PostPosted: Wed Nov 26, 2025 11:09 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Found this among other parts which came with my Ghia..
No idea what it is
Page 37 of 38
