BIGGEST TIRES I can safely put on my 76 Westy.
ggolds5
ggolds5 is offline
PostPosted: Mon May 20, 2024 9:56 pm    Post subject: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
I wrote a post the other day about raising the height of my Bay. After many helpful replies I've decided that it is NOT a good idea to alter the suspension. SO, that said, can someone knowledgable in the tire area tell me what the largest tires that can safely be put on my 76 Westy. One member of the forum put on Grabber ATX's. 27x8.5 14. Is there any issue with this size such as fender rubbing etc.?. Thanks.
metahacker
metahacker is offline
PostPosted: Tue May 21, 2024 12:12 am    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
the answers for this will be somewhat anecdotal .. as things vary amongst tires of the same size rating .. and wheel choices differ ...
in terms of diameter,
215/70R15 (26.85" OD) in the front rubbed for me but only in reverse with the wheel cut, even then rarely. was OK as a daily driver (altho went staggered 65 & 70 eventually)
215/65R15 (26" OD) in front did not ever have any issues
both on 15" "Fooks" 5x12 alloys (Porsche 911 Fuchs replicas)
225/75R15 (28.3" OD) in the rear was totally fine (narrow AF split bus 15's, so probably even taller OD than usual)
wheel offset matters a lot .. particularly for sidewall vs fender clearance.
how tired your torsions, bump stops, etc are also matter
richparker
richparker is offline
PostPosted: Tue May 21, 2024 5:31 am    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
27x8.5 Grabbers fit on the stock rim and on the bus without issues. Many people run them.
__________
’71 Westy build
Adventure thread
’65 Deluxe Build
Hoppy Camper
Hoppy Camper is offline
PostPosted: Tue May 21, 2024 6:15 am    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
27x8.5 14" Grabbers are awesome, knobby tires that give your bus an instant lift. I run them on my '79 and love them.
They are also heavier than stock tires and have a larger circumference. These two factors significantly increase unsprung weight and affect the final drive ratio.
Your already slow bus will now be slower.
1979 Mexico Beige Westy auto
The Wilds of New Hampshire!
www.hoppycampernh.com
https://youtube.com/@hoppycamper
View user's profile Send private message Visit poster's website Instagram YouTube Gallery Classifieds Feedback
Willin
Willin is offline
PostPosted: Tue May 21, 2024 7:04 am    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
I run the Grabbers, stock rims.
I will say this once again, They are not 27".
I measured rolling circumference( on the bus)at 81" divided by 3.1416 = 25.7" diameter.
FWIW
73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit".
Bulli Klinik
Bulli Klinik is offline
PostPosted: Tue May 21, 2024 7:32 am    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
I ran 15"s on my old Dormobile. I have friends with later Buses who run 15's with BFG's as well. I think they run a Passat rim? There's some options from the Vanagon world.
I have these 14" Bighorns on my Vanagon. They would fit your Bus as well.
Mike K
Bulli Klinik
Colorado Springs
Shonandb Premium Member
Shonandb is offline
PostPosted: Tue May 21, 2024 8:11 am    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
I used to run 215/65/16 Nokian Extra Load SUV tires all the way around at stock height.
Now I run 225/75/16 Goodyear Wrangler LT on the rear and 215/65/16 Nordfrost XL on the front with ET 33 rims off a Tiguan. I think 215/70/16 or 205/75/16 will fit on the front without rubbing but I have raised spindles.
Previous 1973 Panel Bus:
Click to view image
ggolds5
ggolds5 is offline
PostPosted: Thu Jun 06, 2024 7:56 pm    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
Got the Grabbers and they look great. Love the lift it gives my Bus. Thanks.
ggolds5
ggolds5 is offline
PostPosted: Thu Jun 06, 2024 7:57 pm    Post subject: Re: BIGGEST TIRES I can safely put on my 76 Westy. Reply with quote
Got the Grabbers yesterday. They look great.
