'40's guy Samba Member
Joined: February 13, 2021 Posts: 51 Location: Spo-Kane Wa
Posted: Fri Jan 20, 2023 8:50 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I have a 1967 bus with a 1600 DP, RGBs and a big nut transaxle. The trans was recently rebuilt but I don’t know what the gearing is. The bus has 15” wheels instead of 14”. I have 205/75R15 tires mounted. I have reason to believe the speedometer is accurate. I generally drive around town, and don’t venture onto the freeway, so I am not concerned about how fast the car will go. What bugs me is that I am typically going about 30mph around town and the engine sounds like it wants me to shift from 3rd to 4th. I don’t have a tachometer, but it’s noisy at that speed and sounds like it’s spinning pretty fast. The owner’s manual says 3rd gear is good to 45mph. No way! If I do shift into 4th at that speed it is lugging a bit, so I just put up with it in 3rd.
Here is my question: will I notice a significant difference if I change from my current 205/75R15 tires to 215/75R15 tires? According to the calculators, the 215s turn only 16 revolutions per mile less that the 205s. Will I see any practical difference in RPMs?
Thanks. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20825 Location: Sandpoint, ID
Posted: Fri Jan 20, 2023 9:01 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
'40's guy wrote: |
Thanks. |
The short answer is no. You will likely not notice a difference in felt RPM with the change in tire size.
The big question is, do you have much VW bus experience? To some folks, they feel like they are screaming at everyday speeds. Cruising around Spokane at 35MPH in third gear will be loud, but not abnormal. If you are on flat ground headed out North Division, you can shift to 4th. If you are climbing Southeast Boulevard up to Trader Joe's, keep it in 3rd. _________________ You can't spell sausage without "USA"! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7115 Location: Lawrenceville, Ga
Posted: Fri Jan 20, 2023 9:40 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
agreed. It just is loud. they absolutely go 45 in third. and that is without overreving it.
put a full interior in it and it will quiet down. still same revs, but it won't kill your ears anymore.
maybe the exhaust could use some help too?
if you don't go anywhere on the highway, it may make sense to use a slightly smaller tire that allows you to get in 4th. _________________ regards
Uli
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2377 Location: In the woods, Ontario
Posted: Sat Jan 21, 2023 7:49 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Unlikely, but it could have the 'mountain gear' ratio reduction boxes. That might effect shifting points. |
Posted: Sat Jan 21, 2023 8:26 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I appreciate this good feedback. Thank you all for responding. |
Larmo63 Samba Member
Posted: Sun Jan 22, 2023 5:39 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I’ve posted these before, no rubbing or issues. My SC isn’t a speed demon, but these take me everywhere.
_________________ Lawrence
‘61 Mango Green Single Cab
'62 Pearl White Ragtop sedan
'66 Ruby Red Cabriolet
'86 Porsche 911 Carrera |
'58 Single Cab Samba Member
Posted: Sat Mar 23, 2024 12:54 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I might as well contribute in trying to keep this thread up to date. My Cooper Discoverers in 195R15 are way past due for replacing (44th week, 2006 date code). They have been an excellent tire in that they took me everywhere and never let me down.
Not many to choose from in the US in 195R15... Linglong, Thunderer, Otani, Westlake, Cosmo. The last one I looked into a little closer. Cosmo appears to be a US family owned company that's been around since 1942. The Cosmo El Jefe Van II comes in 195R15. Curious if anyone has run them yet? They are fairly inexpensive at $82 each.
https://cosmotires.com/product/el-jefe-van-ii/
...but then I see Larmo's last post and dammit, those BFG all terrains in 215/75R15 sure do look nice...
Larmo63 wrote: |
Posted: Sat Mar 23, 2024 1:59 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
'58 Single Cab wrote: |
https://cosmotires.com/product/el-jefe-van-ii/ |
If that is a current pic of your Coopers, and that is how much wear/driving time they have had since you put them on when the date codes were fresh, don't bother getting new tires. They will be fine.
If you plan to drive 10K miles on hot summer freeways, then get new ones. _________________ You can't spell sausage without "USA"! |
Posted: Sat Mar 23, 2024 3:06 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
That pic is from today. I put less than 1000 miles on it per year. It's stored inside a windowless garage that is typically between 60 and 80 deg F all year long. I mounted them when they were brand new.
We hear horror stories of tire failures but I agree with you. Those failures are probably missing key details of how the tires were not taken proper care of.
cdennisg wrote: |
If you plan to drive 10K miles on hot summer freeways, then get new ones. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71521 Location: Phoenix 602
Posted: Sat Mar 23, 2024 9:03 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
cdennisg wrote: |
I believe it's when the sidewalls are cracked from age and/or sun exposure.
This is really common here in AZ.
I see people with shredded tires all the time and I had a couple Coker Tire Continentals 6.40x15s rot out in a few years when my Bus was outside a lot more. _________________ How to Post Photos
Posted: Sat Mar 23, 2024 10:19 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
EverettB wrote: |
cdennisg wrote: |
I see people with shredded tires all the time and I had a couple Coker Tire Continentals 6.40x15s rot out in a few years when my Bus was outside a lot more. |
Often times a tire failure due to age cannot be seen easily. They may show no outward signs of deterioration at all. But, in this situation, knowing well these tries were made, and how little this vehicle is driven, and then with the info of how the vehicle is stored, I would have no issue continuing to drive on them for many years to come. _________________ You can't spell sausage without "USA"! |
Don66bus Samba Member
Posted: Wed Apr 24, 2024 1:09 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I was having trouble finding any tire shop to supply 205 75 15 radials for my 66 bus. Finally, I went to the tire companies, found a tire of the right size and load range (1609 pounds max), looked up the company's local contacts, and had that store order me the tires. They are Hankook Kinergy. They look OK; haven't got them mounted yet. That's the next step: finding a tire shop that will deal with 15 inch VW rims.
I had Cooper Discovers of the same size and load range that have served me well for 7 years. They probably have several thousand miles left but I am contemplating another long trip and do not want to run out of rubber while travelling. |
Posted: Thu Jun 06, 2024 5:19 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Well ... the Hankooks have no specific sidewall stiffening. I just finished a 1000 mile trip, though, and they were quiet, very comfortable (cushy even), and handled fine. My major reservation is that they flex so much that moving around in a parked bus while camping can get the bus rocking (no, not front to back caused by bed antics but side-to-side when getting up from the table). I will see if I can actually get proper light truck tires locally and compare. |
Posted: Thu Jun 06, 2024 5:41 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Don66bus wrote: |
Are they a P metric size? No LT or C or D rating? If that is the case, they are essentially passenger car tires. Load rating my be OK, but those designations I listed denote reinforced sidewalls.
Also, any knowledgeable/reputable tire shop can mount 15 VW wheels. The issue is balancing with modern machines. I don't bother balancing bus wheel/tire combos and have not had an issue in over twenty years of bussin'. But, if you really want them balanced get your hands on a wide five to Chevy/Ford/Porsche adapter. With that bolted to the wheel, the center hole will fit modern balancing cones. _________________ You can't spell sausage without "USA"! |
Lind Samba Member
Joined: November 06, 2000 Posts: 10216 Location: idaho
Posted: Thu Jun 06, 2024 7:15 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
cdennisg wrote: |
Don66bus wrote: |
Also, any knowledgeable/reputable tire shop can mount 15 VW wheels. The issue is balancing with modern machines. I don't bother balancing bus wheel/tire combos and have not had an issue in over twenty years of bussin'. But, if you really want them balanced get your hands on a wide five to Chevy/Ford/Porsche adapter. With that bolted to the wheel, the center hole will fit modern balancing cones. |
slightly pricey, but good to have.
https://www.thesamba.com/vw/classifieds/detail.php?id=2576677
These are the 15" tires that I run on most of my buses. They feel great.
195R15 thunderer ranger r101 from simpletire.com (if the mile-long link doesn't work)
https://simpletire.com/brands/thunderer-tires/rang...amp;rad=DD _________________ .
Wanted:
Posted: Thu Jun 06, 2024 7:25 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Lind wrote: |
cdennisg wrote: |
Don66bus wrote: |
https://simpletire.com/brands/thunderer-tires/rang...amp;rad=DD |
These are way cheaper, sometimes even free...
Several years back I had a local mechanic use his vintage brake lathe to cut the braking surface and snout out of a beetle brake drum for me. I use it as an adapter for my manual tire changer, but it would work great for a balancing adapter, too. Cost me twenty bucks as I recall. _________________ You can't spell sausage without "USA"! |
Posted: Fri Jun 07, 2024 3:46 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Regarding passenger car tires vs. light truck tires:
- I have been running passenger car tires (load range 1600 pounds +) for fifty years now and have never had a problem with their capacity. I do distance, I carry loads, I do some back roads. They work. It may be that light truck tires work better BUT
- Up here in Canada, I cannot find any tires to fit my 15 inch rims that are in the 195/75/15 to 205/75/15 range. I go to big tire companies and say "What have you got in 205/75/15?" and they say "Nothing." So, if I can find in some obscure garage or website a tire that fits, I try it out. So far, all have been good. The most recent, Hankook Kiinergy, work well dynamically but bug me when I am camping in the bus. Maybe I will go down to standard 14 inch rims so I can tap into the range of tires sold for Vanagons. |
Lind Samba Member
Posted: Fri Jun 07, 2024 5:17 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Don66bus wrote: |
For many years, I could not find any 15" tires with the proper load rating. Only in the last ten years or so I have been able to find the right tires. It makes a noticeable difference in the handling. Passenger car tires are too soft, and it feels like you are driving on a marshmallow. I would recommend crossing the border and getting some of the right tires down in the states, or going with 14s to get the right tire.
The other thing for making the bus handle good is the anti sway bar. Of course this came stock on all '66-'67 buses. Anyone out there with a '55-'65 bus would do good to put an anti-sway bar on their bus. you will notice the difference. I was recommending them long before I was selling them.
Shameless plug:
https://www.thesamba.com/vw/classifieds/detail.php?id=2675822
_________________ .
Wanted:
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Fri Jun 07, 2024 9:37 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Wow, this seems a good answer.
I estimate I've driven bays an more on Vanagons about 700,000 miles in my life. Almost every bit of it on 185R-14C properly rated tires. And always more pressure in rear than front. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Brendel20 Samba Member
Joined: October 21, 2010 Posts: 301 Location: Troy, IL
Posted: Tue Jul 09, 2024 5:18 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
So I took Lind up on both of his suggestions....bought his front sway bar kit and upgraded my tires to the thunderer rangers he linked above. Holy cow did it make a difference in the handling around corners and overall feel of my bus. If you are on the fence on either of these upgrades, do it. Both will be going on any future bus I may encounter. Thanks Lind! |
