Bedliner/Herculiner/Rhinoliner
Kherome
Kherome is offline
PostPosted: Mon Jun 05, 2006 10:40 am    Post subject: Bedliner/Herculiner/Rhinoliner Reply with quote
Hey all!
Since our wonderful Things are so prone to rusting I was pondering using a bedliner type product on my new floor pans (when I get some.) We use the do-it-yourself herculiner stuff in the bed of our truck and it wears like iron! I also noted that Rhino says they can color match, so I'd be able to get it in Acapulco blue! I thought maybe when the pans got here I could have them done before attaching them to the Thing to allow the best possible coverage top and bottom...and then hopefully the pans would remain rust free for many many years. Also the bedliners are pretty maintainence free as well.
Is this ok to do? It wouldn't harm the Thing in anyway would it?
Ferretkona
Ferretkona is offline
PostPosted: Mon Jun 05, 2006 10:58 am    Post subject: Reply with quote
I have been thinking of doing the same, I had it in my jeep for years with no problems. I do think you might want to apply it after installing the pans. Any welding could damage it. And I would not want it where it mounts to the bady and seal as well.
just my $.02
Kherome
Kherome is offline
PostPosted: Mon Jun 05, 2006 11:06 am    Post subject: liner Reply with quote
Good point
kubelmann
kubelmann is offline
PostPosted: Mon Jun 05, 2006 11:21 am    Post subject: Reply with quote
We used the roll on and brush on kind on our 63 Baja prerunner and it wears like iron. Very durable. My offroad Thing has POR-15 total coverage. It also wears well and bonds perfectly to rusted metal as long as you do the three step process. I would not put the coating in until pan sections were welded in place. Remember that a Thing and a Ghia have the same pan section shapes only the Ghia ribs go in a different direction. The best pan sections are said to be Danish. There was a company selling the heavy duty ones for a good price. I will search around and try and remember who was selling them. Anyone else remeber that company?
MajerThing
MajerThing is offline
PostPosted: Mon Jun 05, 2006 1:33 pm    Post subject: Reply with quote
I used Durabak for my interior. It rolls on (kinda) and was fairly easy to do. Prep work was the hardest. Thus far it has worn well and cleaning out my interior is just a matter of grabbing the hose.
Durabak had a wider selection of colors and the price was also less.
Kherome
Kherome is offline
PostPosted: Mon Jun 05, 2006 1:42 pm    Post subject: hi Reply with quote
Thanks for the tip!
madster
madster is offline
PostPosted: Sun Jul 07, 2024 6:51 am    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
Dancing Dancing
1966 BEETLE @ 1973 THING
Heiferman
Heiferman is offline
PostPosted: Mon Oct 07, 2024 6:04 pm    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
As long as it was revived I will add.my $.02.
Raptor Liner sprays very well and is quite forgiving. It is also tintable. My plan is to redo my black lined Thing with tan.
- 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Oct 08, 2024 10:15 am    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
I used Raptor liner in the tub and trunk. It was tinted same as the outside body color. Very happy with it.
I elected to NOT use the Raptor liner in the engine bay as I thought it may it more difficult to clean oil and grease from the texture.
No Raptor in the engine bay
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
frogman_94
frogman_94 is offline
PostPosted: Wed Oct 09, 2024 3:10 pm    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
I used Monstaliner on the pan. It took one gallon on the top and one gallon on the bottom.
sportin-wood
sportin-wood is online now
PostPosted: Thu Oct 10, 2024 9:32 am    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
That looks great! Was it sprayed on using an air compressor or is that available in aerosol cans? Or rolled on?
Dave
1966 Bug project
1973 Thing project
Semper_Dad
PostPosted: Fri Oct 11, 2024 11:03 am    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
My paint and body guy did it. I'm sure it was sprayed. The Raptor Liner kit comes with a spray gun.
Dougster43
Dougster43 is offline
PostPosted: Fri Oct 11, 2024 2:19 pm    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
I did the raptor liner on my floor pans after powder coating and my wheel wells too. You can roll it on, but spraying will give much better results. Use the gun from the kit. It can be done outdoors if you prefer - the gun is very controllable and it’s fast - I think I did the pans which used about 3 bottles of the raptor liner in less than 30 minutes. Cleanup was easy and I have used the gun several times since.
Heiferman
PostPosted: Mon Oct 14, 2024 7:02 pm    Post subject: Re: Bedliner/Herculiner/Rhinoliner Reply with quote
Raptor offers two different guns. A cheapo and one that has a few more adhustments.
It also comes in spray cans but obviously color choices are limited that way. They also recommend a primer. Lots of recommendations and instructions for getting a good finish out there.
