North GA 1973 Veteran's Addition
Heiferman
Heiferman is offline
PostPosted: Thu Apr 04, 2024 5:17 pm    Post subject: North GA 1973 Veteran's Addition Reply with quote
Hi folks. I have been lurking for a while hoping one day I would again own an airculd machine. I started in 1986 with my first car being a 1968 Beetle. Then I got a beat up '69 Baja and I built a pretty nice Franken Bug Baja Prerunner that is still running around Virginia Beach, Virginia.
Then a couple months ago, with retirement looming, I scored a 1973 Thing up in North Carolina after months of scouring the classifieds, Facespace and Craigslist for my next project. I have always wanted a 181 and finally! I have one! Well - We have one!
I brought him home in the rain through the mountains of NC with my adoring wife who not only approved the purchase but was excited about it!
We rolled him off the trailer and into the garage.
Made an assessment...
And got to work!
Always some hidden stuff up in there but we are up to the task.
It is possible that this 181 may have been on here before or may be recognized. But there is plenty to do. A little pan/frunk and bumper work and inside body work, pedals and cables, brakes, exhaust and get the seats sorted. The biggest project is the electrical. I have been down that road before on a few old Toyota trucks and Beetles so "I ain't sceered!"
I will try to post here from time to time to keep you all up to date. I am retiring in 86 days so the speed should pick up!
Enjoy!
fastmc25
fastmc25 is offline
PostPosted: Tue Apr 09, 2024 7:16 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Awesome project. Looking forward to seeing ilupdates 😎👍
I retired USAF IN 2013 after 31 yrs. Congrats on your upcoming retirement 😎
Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Grumpy Old Vet”
fastmc25
fastmc25 is offline
PostPosted: Tue Apr 09, 2024 7:26 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Peace,
Paul
Semper_Dad
Semper_Dad is offline
PostPosted: Wed Apr 10, 2024 8:10 am    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Congrats on your new acquisition.
My recommendation (if the budget allows) is to ditch the entire old electrical system and install a complete new one from the Thing Shop.
45+ years have made the wiring brittle and the copper has increased resistance. Not to mention all the modifications previous owners have made.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Heiferman
PostPosted: Wed Jul 17, 2024 5:45 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
You will all learn I am slow on these projects but I have accrued a pile of parts to throw at the Thing. I retired on June 29 and figured I could thrash on the project and get it going in short order. Not so.
Today I got in a new rag joint (the on in it was bodged).
And discovered that a PO had added a new hard line and it was pinched everywhere. I pulled it.
I am going to replace it with -an fittings and proper line. The original line was broken off in the back below the transmission horn.
(PO left me the visegrips. They came in handy today.)
I did get my pedals re-installed. They were laying on the floor when I got this home. The petal stop was merely a piece of angle iron loosely bolted to the floor so I made new one.
I also figured out there master probably was not bench bled so I am doing that tomorrow in situ and then will get everything all hooked back up the the brakes bled. There are a bunch of new lines already.
After that it is all about this mess:
The PO had a bunch of accessories like offroad lights and even a winch on the car. I have pulled all that off and pulled a mile of mystery wire out. He also had tried to move the signal lights to some chineseum headlights with LED signals incorporated in them. I will get rid of that and go back stock.
Stay tuned. Or not. Laughing
Heiferman
PostPosted: Wed Jul 17, 2024 5:53 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
For sure. I have re-wired a few old FJ40s so not my first rodeo. Much of the wiring is new but not fully hooked up. I am going to start up front and figure out the lights and sorta work my way back. Neither of the electric fuel pumps were hooked up (engine and heater) so I need to get those properly mounted and wired as well. The list is long.
Semper_Dad
PostPosted: Wed Jul 17, 2024 7:10 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
I can't tell from this photo but there should be a jumper wire going across the steering coupler (AKA Rag Joint). This provides a ground path for the horn wire.
Heiferman
PostPosted: Thu Jul 18, 2024 5:37 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
I screwed around bleeding the brakes most of the qfternoon. Rear was easy but I absolutely could not get fluid to come from the front bleeders.
I ran across a thread on pressure bleeding and that seems to have done the trick.
I drilled a 1/2 hole in a plastic Coke bottle cap and pulled through a valve stem. It fit the reservoir perfectly. Then I just gave a bit of pressure with a bike pump and was able to get fluid through the bleeders. Finally.
The PO had replaced the reservoir and all lines. The wheel cylinders and master looked new but were really rusty I guess just from sitting. I had even tried to bench bleed the master in situ but that just made a mess. I am not convinced that there may be a bad check valve in the master but we shall see once I get my helper back.
Heiferman
PostPosted: Fri Jul 19, 2024 3:42 am    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
There will be. The connection is there on the new joint. It had been "deleted" by the PO. He had tried to install an aftermarket steering wheel which led to an aftermarket horn amd he add a "shim" to the old rag joint. It was a mess. You can see the "engineering " in the top right. Surprised
Heiferman
PostPosted: Fri Jul 19, 2024 3:10 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Well, I found so many janky connections I pulled the main loom and stripped it. Glad I did. There were some soldered and frayed wires. Car never would have run and frustrated me blowing fuses.
So I spent the entire day rebuilding it and it is ready to go back in. So much easier than a post 80s car.
It also allowed me to delete the diagnostic plug.
If anybody is doing a full resto and wants it, lemme know. Shipped free.
Heiferman
PostPosted: Sat Jul 20, 2024 7:48 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Made and installed new battery cables today and got the loom back in. This only to discover I may have taped or shrink wrapped over the black reverse switch wire. Mad I will have to figure that out tomorrow. I realized I should have run another wire in the loom for the coil fused wire but that ship has sailed. I will just have to run a seperate one.
This looks terrible....
And here is a question I will end up posting in the BN-4 thread: How does the timer knob stay on? Is there supposed to be a friction ring around the switch that keeps the green lighted knob on? (I need to post pic I guess.) Thanks to Samba I was able to ID the bulb it uses.
As an aside, great sale on Dewalt tools today on Woot.com. My drill/driver gave up high speed so I ordered a new set with a 6.5 inch circular saw, a multi-tool, LED work light, two batteries and another drill driver l for under $300.
By the way, is this an OEM part?
Heiferman
PostPosted: Sun Jul 21, 2024 3:08 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
That's more like it.
Obviously I ended up starting at the back. Seemed easier and wiser to ensure the harness was where I wanted it.
The Ms. Is going away for a few days so I will keep at it.
In other news I discovered I need to remove the rear bumper to get the exhaust in. The PO bodged in a receiver hitch (seen in posts above) that interferes. He was planning on pulling a 26 foot travel trailer. Liar Laughing
Heiferman
PostPosted: Tue Jul 23, 2024 7:12 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Well I answered my own question. I had two knobs one clicked in place the other one is either worn out or broken.
I got the rear bumper off today and cut out the 2 inch receiver hitch. I have not decided if I am going to build a new bumper or try to reinforce the original. I want a proper tire swing out like I have on my LandCruiser. The one that is on the car now is really flimsy.
I also got the exhaust on and discovered that the header is a small flange and the muffler is large so I went ahead and ordered the proper one. I know I need some 1 5/8 headers for this due to the engine size but I want to be sure I get the other necessities done.
I also need to score some gray wire. I probably only need about 3 feet but I can not bring myself to use another color. Rolling Eyes I did pull apart all the wiring up front today. More poor connections and various connectors.
Here is another question - do the 3 wire junctions for the headlights and signal lights in a Thing reside inside the headlight bucket or inside the trunk?
Heiferman
PostPosted: Thu Jul 25, 2024 5:49 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
As to my wire junction question? Well, they are going to be in the trunk now. I finished everything in the engine bay.
Hit it hard today. I am waiting for some gray 16awg wire to finish off the front marker lights. I will be able to bundle all that up and get the headlights in when that happens.
Then I worked at the dash and ignition. Once again, there was some wonkey stuff in there. There are a couple circuits I am a little confused about based on the wires I have to work with. I may just have to build those from scratch. Anyways, if the 16awg shows tomorrow, I may be able to throw some 'tricity to it! Certainly by Saturday.
sportin-wood
sportin-wood is offline
PostPosted: Thu Jul 25, 2024 9:05 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
I like the concept, but I am unable to find this thread to get more details. You wouldn't happen to have the link to it, would you?
Dave
1966 Bug project
1973 Thing project
Heiferman
PostPosted: Fri Jul 26, 2024 7:26 am    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
This is the thread I initially read through:
https://www.thesamba.com/vw/forum/viewtopic.php?t=768747&highlight=pressure+bleeding
Looked at one or two YT videos as well as I had never tried it. My front circuit would not bleed until I did this. And the Coke bottle top was a perfect fit.
- 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance
sportin-wood
PostPosted: Fri Jul 26, 2024 12:59 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Thank you my brutha!
Dave
1966 Bug project
1973 Thing project
Heiferman
PostPosted: Sat Jul 27, 2024 2:31 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
I spent the last two days trying to fix my crappy Cub Cadet mower. It has not gone well. I am pretty scared to touch anything else at this point as I am at the verge of pushing the next project that goes wrong off a cliff. Evil or Very Mad
I still have not gotten my 18awg gray wire and I do not really want to mix gauges as I am mostly following the schematic so the waiting continues.
Old friends coming to visit on Sunday so that will be a good distraction.
Heiferman
PostPosted: Tue Aug 06, 2024 3:26 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
Okay.
Back at it. Cub Cadet is fixed and Mr. Thing no longer has a frowny face! All new wiring up front.
Heiferman
PostPosted: Tue Aug 06, 2024 3:48 pm    Post subject: Re: North GA 1973 Veteran's Addition Reply with quote
If anyone is following along:
What is the common routing for the fuel sender wire?
Page 1 of 8
