andrigs fan
Page: Previous  1, 2, 3 ... 18, 19, 20, 21  Next
jpaull
jpaull is offline
PostPosted: Fri May 03, 2024 4:01 pm    Post subject: Re: andrigs fan Reply with quote
Dave thats a pretty good point. The air resistance is a big part of the horsepower loss.
But having a choice of dropping 800 grams or keeping them, I would be excited to give that 2nd gen fan a try.
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
txoval
txoval is offline
PostPosted: Fri May 03, 2024 4:46 pm    Post subject: Re: andrigs fan Reply with quote
If this fan draws in the air in with less resistance and is more efficient, it could push more air at less HP draw…but that’s above my mathematical knowledge
TXHCBeetle
TXHCBeetle is offline
PostPosted: Fri May 03, 2024 5:39 pm    Post subject: Re: andrigs fan Reply with quote
vwracerdave wrote:
TXHCBeetle wrote:
I'm interested in the rotating mass reduction, even if it flows the exact same
The tiny bit lighter his fan will be compared to a stock dog house fans will not make any amount of noticeable difference. He is over stating the issue as a selling point to convince you it is a big deal.
A belt driven fan takes power to move air: rotational mass + fan blade drag. While the blade drag will consume more power, you can't completey dismiss reduction in rotational mass. I'll take any gain..no matter how small
In Progress:
1958 Beetle Sedan - L243 Diamond Gray
1967 Beetle Sedan - L456 Ruby Red
Bruce
Bruce is offline
PostPosted: Sat May 04, 2024 3:46 am    Post subject: Re: andrigs fan Reply with quote
vwracerdave wrote:
It takes 10-11 HP to turn a stock dog house fan at highway speeds.
More like 6000-7000 rpm as dyno testing has shown. The stock belt could never survive transmitting that much hp continuously.
vwracerdave wrote:
A larger fan that pushes more air will take more HP to spin.
Not necessarily. Every fan has a fan curve. This is the graph of the hp vs. CFM. It is possible to change to a different fan that can move more air requiring less hp. But we don't know if that applies because AFAIK, there has never been published fan curves of the stock fan, or the two andrigs fans.
Bruce
Bruce is offline
PostPosted: Sat May 04, 2024 3:52 am    Post subject: Re: andrigs fan Reply with quote
The rotational inertia of the fan is only a factor when you're accelerating it. Once you're at cruising speed, its mass is irrelevant.
The mass of the fan will have zero effect on mileage. Since it's lighter, your engine should pick up revs a tiny bit quicker, similar to a lightened flywheel, but not as pronounced.
TXHCBeetle
PostPosted: Sat May 04, 2024 11:30 am    Post subject: Re: andrigs fan Reply with quote
Wait....are you saying that rotational mass is not a factor when you're parked too?.......no waaaaay....
In Progress:
dubman67
dubman67 is offline
PostPosted: Sat May 04, 2024 2:27 pm    Post subject: Re: andrigs fan Reply with quote
I cant get mine to not rub. Stock everything.
67 Bug
62 Double Cab
[url=https://www.vw-mplate.com/mplate2-54829.png]Click to view image[/URL]
"At 17 got my first Volkswagen...and mastered the life long art of dragin...." Ice Cube
67rustavenger
67rustavenger is offline
PostPosted: Sat May 04, 2024 9:03 pm    Post subject: Re: andrigs fan Reply with quote
Is yours a Gen I or Gen II fan?
My Gen I rubbed a little. When I first tried it. The rubbing caused the fan material to melt a little. I trimmed the lightly melted bit away and remounted the fan on the gen.
You need to check that the fan has equal spacing all the way around the gen backing plate. Mine was a little off on the spacing. I made a minor adjustment to the fan and gen backing plate spacing. No more rubbing.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
dubman67
dubman67 is offline
PostPosted: Sun May 05, 2024 7:14 am    Post subject: Re: andrigs fan Reply with quote
Gen 2. Rubs on the inlet side of the shroud. I thought about shaving the spacer on the alternator shaft a bit, but ran out time and had to get the engine back in (bus). Next time the engine comes out I'll mess with it more.
67 Bug
62 Double Cab
Fern_b57
Fern_b57 is offline
PostPosted: Tue Aug 13, 2024 6:04 am    Post subject: Re: andrigs fan Reply with quote
will the stock doghouse fan work on his evolution fan shroud?
can't seem to find pics of the rear of the shroud, thank you
94touring
94touring is offline
PostPosted: Tue Aug 13, 2024 8:21 am    Post subject: Re: andrigs fan Reply with quote
Yes.
Fern_b57
Fern_b57 is offline
PostPosted: Fri Aug 16, 2024 3:49 am    Post subject: Re: andrigs fan Reply with quote
Yes.
awesome, is the evolution shroud same as scat , far as size. I know they are hand built so curious if they don't look wierd?
can you mount the venturi ring onto the evolution shroud?
can seem to fin pics of installed in vws.thanks
94touring
PostPosted: Fri Aug 16, 2024 6:12 am    Post subject: Re: andrigs fan Reply with quote
Fern_b57 wrote:
Yes.
The shroud is roughly the same dimensions, though you may need to loosen tins to get it to slide in. It didn't just drop in for me. The fan opening is considerably larger so a regular velocity ring won't work. I believe Andrig is making a ring for it. I made my own by welding a sheet metal ring around it, making slices, bending the tabs over, and then fiberglassed to fill in the slices. It turned into a 2 inch tall velocity stack.
Fern_b57
Fern_b57 is offline
PostPosted: Fri Aug 16, 2024 3:58 pm    Post subject: Re: andrigs fan Reply with quote
94touring wrote:
Fern_b57 wrote:
Yes.
thank you for responding
David Raistrick
David Raistrick is offline
PostPosted: Sun Oct 27, 2024 1:11 pm    Post subject: Re: andrigs fan Reply with quote
since this is the definitive thread..... anyone have a gen1 fan they want to sell? Very Happy
...david - '66 SO-44 #231
Dake
Dake is offline
PostPosted: Tue Dec 10, 2024 5:32 pm    Post subject: Re: andrigs fan Reply with quote
Back for sale in the classifieds!
Interests
VW's, Jeeps & Old McCullock chainsaws
ps2375
ps2375 is offline
PostPosted: Tue Dec 10, 2024 5:49 pm    Post subject: Re: andrigs fan Reply with quote
Got one ordered for the race car! This will go nicely with the 10# FW and the 51/2" crank pulley. Shocked
cmaxcliff
cmaxcliff is offline
PostPosted: Tue Dec 10, 2024 6:18 pm    Post subject: Re: andrigs fan Reply with quote
Too bad he hasn't figured out how to make the dual inlet design work. Very clever. There must be a way to get that done in another material but maybe the tooling cost etc. is too much of a barrier.
BFB
BFB is offline
PostPosted: Tue Dec 10, 2024 7:50 pm    Post subject: Re: andrigs fan Reply with quote
I really like the look of the evolution one’s, i ordered 2
Most experts aren't.
vamram Premium Member
vamram is offline
PostPosted: Tue Jan 14, 2025 10:44 am    Post subject: Re: andrigs fan Reply with quote
Bump. Just curious if there are any new real-world results w/this.
Click to view image
Save the Supers!!
Page 19 of 21
