TheOneTrueQuux Samba Member
Posted: Fri Aug 23, 2024 7:23 am Post subject: Re: 1995 EVC: Testing the Coil, ECU and Hall Sensor |
| Saturn wrote: |
Jeff suggests hooking up a lightbulb to rig and find it goes between bright and dim instead of completely out. Now it is Sunday night, and we need to obtain a replacement in the next 18 hours as we are heading down to Monterey on Tuesday. Look up the sensor on the FCP Euro site to find it is also in 1990s Cabrios, Golfs and Jettas. Time to mount an expedition to the junkyard to locate some potential donors. Look up and find 7 cars in the closest two Easy Bay boneyards with the same Hall sensor. Instead of the 12V power supply, we use a 9V battery to see if that will also work. It certainly does and this allows us to have a mobile rig to test the junkyard sensors. This way we know the part will be usable and not the reason the car ended up being sent to be junked.
If the boneyard isn't successful, this seems to be the right one:
https://www.vanagain.com/product/hall-effect-sende...ngine-only
Based on the difficulty of getting these apart and back together without breaking something, I'd also suggest this:
https://www.vanagain.com/product/new-distributor-for-95-eurovan-5-cylinder
The one that busdepot is selling should have worked, but I ordered one, and the plastic overmold on the sensor was out of position a bit, and caused it to hit the tone wheel. I never heard from them that they'd resolved the issue, and wound up returning it.
I think this one is correct as well:
https://europarts-sd.com/halleffectsender1995-1996.asp |
onefred Samba Member
Joined: January 06, 2012 Posts: 283 Location: Thaïland - Geneva
Posted: Fri Aug 23, 2024 5:35 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
Hello,
I followed the 8 pages of your post.
Good job!
I have a question for you, I have a 1994 AAF syncro, and I am looking for a document on the procedure to adjust the engine (CO, ignition advance, etc.)
Do you have a document that you can send me by email?
Thank you.
Fred. |
Saturn Samba Member
Joined: April 06, 2019 Posts: 266 Location: San Francisco
Posted: Sat Aug 24, 2024 9:48 am Post subject: Browsing at the Boneyard For A Hall Sensor |
Thank you for the links and relating your experience with some of these parts. My last post didn't have the link for the part at FCPEuro https://www.fcpeuro.com/products/vw-distributor-ig...96#fitment
| onefred wrote: |
My main information source is the Robert Bentley Eurovan Manuals which covers the AAF engine. I recommend picking the set of these books if you are doing your own wrenching. Another resource is the Just-T4s site out of the UK. These are mostly taken from the Mitchell Repair guide and can be a little hit or miss (https://just-t4s.co.uk/downloads/)
At the PicknPull near the Oakland Coliseum complex sit two potential donors to the south in Newark, CA are 5 more. Hitting the road after the morning rush hour has subsided, it is a 30 minutes drive to the Oakland yard, and the first car on the list is a 1999 Golf. To our surprise, turns out it has a coil pack set up and not a distributor. A couple minutes later arrive at a 1997 Cabrio and thankfully the distributor is still with the engine. It takes about 10-15 minutes to extract it out from the car. A good deal of this time is prying and leveraging as it didn’t just pull out, it was more like serving an eviction with the amount of effort needed to release it from its perch. Set up the test rig on the fender and voilà!, the Hall sensor works.
In order to remove the sensor, the bottom gear needs to be removed to pull out the main shaft. A retaining pin needs to be removed in order to release the gear. Spent 15 minutes in vain trying to dislodge this pin with a hammer and punch having it move a measly 1mm and no more. Realizing time is the critical aspect in this repair decide to just purchase the entire distributor, which is about double the cost of just the Hall Sensor and attempt the removal with a better assortment of tools. Test the sensor again to see if it survived all of the blows to the retaining pin. Tell the cashier I just want the Hall sensor and not the entire distributor. They nod their head and ring it up for the price of the sensor, an unexpected gift to say the least.
After getting back to the workspace in the early afternoon, put the distributor in a vice to attempt to dislodge the locating pin with no movement whatsoever. For expediency, break out a sawzall to cut through the center shaft. Install a spare distributor cap to prevent shavings from getting on the magnet/sensor area. Takes 2-3 minutes to cut through the steel and get access to the sensor’s mounting screws. The locating pin on the Eurovan distributor comes off without much effort. Comparing the two sensors, the one from the EVC looks bad visually, a hazy, oxidized coating all over it. Trade the Cabrio’s sensor into the Eurovan’s distributor and bust out the mobile test rig to make sure it is still operational. It is to our relief.
Returning to the EVC in Alex’s driveway, the distributor is reinstalled into the cylinder head, Check and recheck all of the various connectors and wires are back in place. Get behind the wheel, turn the ignition key and the engine roars to life. Feel my shoulders drop and relax, from the lungs a noisy exhale signals a sense of great satisfaction from this victory. Relish in this delicious feeling, although all too briefly. As the engine quietly idles, pack up the various tools and spare parts brought out during the diagnosis and repair phases of this operation. At the same time the Weekender arrives after its 500 mile NorCal camping roadtrip. It did not have any running or driving issues, which while not surprising is a relief to hear. After letting the EVC run for 20 minutes and a short test drive, deem it ready, willing,and able to make the 125 mile trip southward. Now it is time to prepare and pack for the trip to Monterey.
Next: The Trip South to Laguna Seca and Monterey
soissisc Samba Member
Joined: April 04, 2007 Posts: 769 Location: Western Pennsylvania
Posted: Sat Aug 24, 2024 10:13 am Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
Congrats! _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
KillerGriller Samba Member
Joined: June 15, 2022 Posts: 90 Location: Ontario, Canada
Posted: Sat Aug 24, 2024 10:00 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
| Well done! |
Saturn Samba Member
Posted: Thu Aug 29, 2024 9:27 am Post subject: Car Week and Laguna Seca 2024 |
Some of the Indigenous Wildlife Encountered During Car Week
Tuesday
After resuscitating the 1995 EVC, finally can begin the organization and packing for Laguna Seca. Since Alex is driving his 1961 Maserati to Car Week, most of his camping gear and other items would be going there with Tristan and myself. After loading up the Weekender, we arrive at Alex’s house to pick up the EVC along with his items. Heading to the workshop space at around 11 am, it takes about an hour to finish loading up the vans as well as conduct a round of fluid and other maintenance checks on the vans plus an impromptu tire rotation. Since the EVC has been parked outside, hook up the pressure washer for a long overdue bath. Sparkling in the sun, the van is finally ready to start on its next adventure.
Our first destination is the Taco Bell in Pacifica with the million dollar view. It sits overlooking Linda Mar, one of the main beaches and surf spots in the town. Grabbing a seat along the beach front railing, we soon realize several Humpback whales are swimming just off shore. They have been around the Bay Area beaches for about a week drawn by an abundant supply of fish. Spouts and dorsal fins are easily spotted as well as the occasional exuberant breach. This is a surprising experience for Tristan having never experienced seeing Whales in the wild. With lunch consumed we continue south down Route 1 along the Pacific ocean. Stopping at Pigeon Point Lighthouse, the next wildlife surprise is watching a Sea lion bob up and down between a couple rocks about 30-40 yards out. Another first for Tristan.
After slogging through stop and go traffic outside of Santa Cruz, we finally arrive in Seaside at 5:45pm. In the Costco parking lot we meet up with Jeff who has driven down from Seattle over the last two days. Stocking up with supplies there as well as another grocery store, we finally arrive at the track at 7:15. As the sky transitions to twilight, Jeff’s deploys his tent for occupation/sleep and Tristan puts Alex’s up to store his items until he arrives Wednesday afternoon.
As the orange sky starts to fade away and a brisk sea breeze whips through our site, stoke a fire to enjoy our dinner around. A ham radio enthusiast, Jeff sets a small array of equipment on the picnic table along with a 17-foot high antenna. In the next hour he is able to make several contacts to other hambones in Australia, Europe and Africa. After seeing a couple shooting stars, the remnants of the Perseid meteor shower, Tristan, Jeff and I disperse ourselves to our respective domiciles.
Wednesday
The one interesting & annoying new aspects of our spot is being closely monitored by a trio of tenacious Scrub Jays and a bold ground squirrel with eyes on our supplies. While cooking breakfast, one of the Jays grabs two slices of bacon cooking on the skillet but drops them after 3-4 feet onto the picnic table. It takes a bit to realize we are the only ones cooking out in the open as most everyone else in the section are in large RVs or 5th Wheels so we have their undivided attention. After breakfast and watching some of the practice laps, it is time to head down the coast to check out Big Sur. While the sky is clear above the track unfortunately the marine layer remains a thick blanket along the Pacific Ocean. Just past the Bixby Bridge we decide to abandon the excursion and head back to Monterey due to the thick soup of gray.
Just after lunch, the first person of the day arrives and joins us watching the cars on the track. Jumping back into Jeff’s car, we head out to check out “The Lil’ Car Show” happening in Carmel-by-the-Sea. This event is for vehicles with less than a 1601cc engine displacement, though it looks like it is more like 2000cc. It is mostly populated with foreign-produced cars and classic muscle cars are nowhere to be found. Run into a couple friends in the crowd and after an hour it is time to head back to Laguna Seca.
Shortly after getting back to our camp, Armando arrives quickly followed by Alex and his daughter in the Maserati then another friend on his BMW motorcycle. Dinner is burgers and brats next to a warm and flickering fire. During clean up, pour the burger grease into the flames producing a bright and very warm flame up. Mop up the Brats pan with some paper towels and before tossing those into the fire, sneak one of these packets (https://www.amazon.com/gp/product/B0BXTFCCZZ/) amid the layers to watch the surprise reactions and comments to the sudden appearance of bright, multi-colored flames.
Next: Car Week Continued
sanchius  Samba Member
Saturn Samba Member
Posted: Sat Aug 31, 2024 10:13 am Post subject: Meals and Wheels at Laguna Seca |
| sanchius wrote: |
Nice, no massive RV + tent sitting in that site across the road from you, blocking the sight line between you and turn 5.
Did Sergei and his trophy wife stay home this year???
I guess we'll see in the next installment. |
Sergio's RV was delivered on Wednesday afternoon. Thankfully there was not a shade structure erected this year obstructing our view of the track. What did impede it was actually done by the organizers when they installed signage onto the outer fence along Turn 5. This generated a fair bit of grumbling and salty comments from us as well as the neighboring campsites.
Car Week Continued: Meals and Wheels
Thursday
Post breakfast, we head out to Route One to watch the parade of the Pebble Beach contenders as well as lots of interlopers during the Tour d’Elegance to Big Sur. This is an amazing collection of some of the rarest cars out there. One of the few times most of these cars are actually out driving on public roads. A police escort, horns a’ tooting and endless waves from the passengers and spectators alike signal the arrival of the tour. Spread out with two main groups about 25 minutes apart, we watch as they migrate southward. About an hour later the procession returns north back to Pebble Beach.
One of our friends stops by in his McBride Wild Hare Special, one of 3 DIY cars from the late 50s. It was designed and built by a shop teacher from Stockton with help from the students. The chassis is a 1946 Ford and powered by a flathead V8. The bodywork takes cues from a Manta Ray, especially surrounding the grill and the fenders over the rear wheels. We assist on a repair of a lost nut on the drivers side suspension while waiting for the cars to return from Big Sur.
The afternoon is spent back at the track, while Armando and Tristan go to check out the Mecum auction courtesy of a pair of complementary passes. In the early evening the group heads to the parking lot car show at Baja Cantina in Carmel Valley then inside for dinner. With a bit of foresight, prep the firepit before heading to dinner. Within minutes of returning, a fire is roaring and snapping away helping to take the edge off of the swift sea breeze whistling through the campsite. Later in the evening Jeff attempts to make two batches of Jiffy Pop to hilarious and disastrous results. The first immolates itself due to attempting to heat it over flames rather than coals. The second try is not much better, but with less carbon.
Friday
With the first day of racing commencing, this is the day we all pretty much stay at the track. Morning starts with the now traditional bagel bar. Armando begins the process smoking 6 racks of ribs for tonight’s dinner. While Tristan and Jeff head out to check the paddock, I elect to stay at camp to tend to the EVC.
One of the things I have been monitoring on the EVC is the house battery (replaced just over a year ago). While working on the no-start problem several days before, check the battery condition from the interior panel and its barely lighting up the LED at the 11V mark. Plug in the shore power overnight and it registers 12V. When leaving SF Tuesday morning, the level is barely at 11V again. When arriving at our camping spot plug the shore power almost immediatly. After almost 2 days of constant power, the panel display is still showing 11V. Since it does not seem to be taking a charge, hook up a battery tender to it for a couple hours during the day. In the afternoon recheck the level and it really hasn’t changed. Move the battery tender to the start battery as during the evening we have been using the EVC’s stereo for playing music after racing concludes into the evening.
Late in the afternoon everyone migrates to the Corkscrew to watch the final race of the day, a 1 hour long enduro race. Once this finishes, return back for ribs, sides and Junglebird cocktails courtesy of Jeff. Utilizing the last of the coals from Armando’s smoker, Jeff finally finds success and redemption in making the 3rd container of Jiffy Pop.
The view of the campsite from the top of the Corkscrew
Next: Car Week Concludes
Saturn Samba Member
Posted: Mon Sep 02, 2024 9:18 am Post subject: Finishing up Car Week, Visiting a Veteran & a Contest |
The Last Days at the Track and a Musuem
Saturday
The built-in alarm goes off at 7:45am with the announcer's voice echoing over the PA system in preparation for the first race at 8am. Alex and his daughter have already departed for Concorso Italiano as the rest of the camp slowly emerge. It is another bagel breakfast finishing off what was not consumed on Friday. Trackside, Bring A Trailer is hosting an alumni event near the paddock which is worth visiting. Our friend with McBride Special shows up to store his truck and trailer. Because he is experiencing some overheating because of a bad pressure cap, the decision is made to trailer the car over the Laureles Grade. Several of us assist in unloading the car so it can join the other jalopies at the BaT event. Walk down there to look through all the vehicles on display (multiple Porches and one Vanagon).
Tristan and I meet up with my co-brother-in-law (my sister-in-law’s brother) who is visiting the Paddock during the morning. Return to the campsite to cook up the last of the brats for lunch. We get several visitors (aka BaT refugees) during the afternoon who are enjoying the view, chairs, shade and lively conversation.
After the last race of the day, a fire is built up, partially for reheating the last two racks of ribs as well as to combat the chill as for the first time the marine layer is actually blanketing the racetrack. As the evening wears on, a few hearty souls remain around the campfire as a heavy mist continues to swirl around us. Because of all this moisture, we have to move our camp chairs away from under the perimeter of the shade structure as it occasionally produces a surprise cascade of accumulated water. A swarm of car carriers descend on the track during the evening. There is a steady rumble of these for the next couple of hours to and from the Paddock. Sometime around 11pm the fire no longer has an audience as we retreat to our various shelters and beds.
Sunday
For the first time the morning is quiet as there are no events scheduled for the racetrack. After breakfast, begin the process to break camp. It is 11:30am when we finally depart on our way back to San Francisco. Jeff decides to head up along the coast and targets Coos Bay, OR as a place to stay overnight on his way back to Seattle. Armando elects to take the most direct path back to San Francisco. The Eurovans convoy with the Maserati back up along the ocean on Route 1 just in case there is any sort of mechanical issue along the way.
Alex stops at a roadside fruit stand which I miss and Tristan and I end up about 10 minutes ahead of them. North of Santa Cruz we pull over to let them catch up. As we wait in a pull-off, see a Vanagon approaching in the mirror. As it goes by, we hear a double-beep salute which is always great to receive from a member of the extended family. With our convoy reassembled, we continue to drive northward with the Pacific Ocean to the left. First unloading stop is at the shop space, then it is to Alex’s house to unload his items and put the EVC back in his driveway. Finding a parking in front of my place, it takes multiple trips to fully empty the Weekender. Finally get to relax and decompress on the couch after the busy and fun-filled days at Car Week. Another aspect of the overall satisfaction of this trip is both Eurovans were pretty much flawless during the entire excursion. This is especially true after all the work getting the EVC back in operational status. After experiencing driving and living in the Weekender, Tristan related it would definitely be a vehicle he would consider acquiring at some point.
Monday
With Tristan staying a couple days post Laguna Seca, we decide to visit the USS Hornet Museum Ship anchored across the bay at the former Alameda Naval Air Station. We spend about three hours on the ship wandering around and taking the Bridge tour led by a Docent. Afterwards we meet up with a friend in Alameda for lunch and a debrief of our experiences at Car Week and the Racetrack. We head out to get back across the bridge before the maelstrom of rush hour makes it a slog and not a drive.
Contest
A couple weeks ago while across the bay I was killing some time driving through the Port of Oakland. One interesting thing I discover is a public scale to weigh your vehicle. Had to try this out with my 1975 Volvo 242. On the trip to the Hornet, decide to take the Weekender onto the scale to see what the read out is. The van is pretty much unloaded from the trip with two strapping lads in the front seats and around a ½ tank of gas. Does anyone care to put out a guess of what our weight came in at? Post your guess by Tuesday at 5pm (Pacific Time). Price is Right rules in effect, nearest without going over will be deemed the winner. Remember GVWR is the maximum, fully loaded weight a vehicle can safely operate at as determined by VW.
bikes! Samba Member
Joined: April 27, 2014 Posts: 127 Location: Central CA Coast
Posted: Mon Sep 02, 2024 9:57 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
As always, great writing and interesting tales you share.
I’ll guess 4250 pounds.
What is the address of the scale? |
Posted: Tue Sep 03, 2024 6:38 am Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
I'm going to guess it comes in pretty near 4900 pounds.
Also, from your earlier post about the levels panel, those LEDs are not that precise. On mine, the top one almost never lights, even with the charger active. I installed a "coulomb counter" style battery monitor that actually monitors the load current and then integrates how much has been used. They are cheap, and give you much more piece of mind, as you can know within a few percent how much of the capacity you've used. |
Saturn Samba Member
Posted: Tue Sep 03, 2024 5:48 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
| bikes! wrote: |
Thank you for the feedback. The scale is located on the 1500 block of Middle Harbor Road in the Port of Oakland. The other caveat is the condition of the road around the bridge over the railway tracks when it is Adeline Street. There are sections with are in bad condition, such as exposed rebar in potholes.
https://maps.app.goo.gl/HKx7JZLsUXgXha7g7
| TheOneTrueQuux wrote: |
| I'm going to guess it comes in pretty near 4900 pounds. |
Was hoping for more participation, so thank you both for venturing a guess. Turns out the scale weighed us at 4650 Lbs. I thought it was going to be higher than that myself. We drove over the scale twice just to make sure the reading was consistent. Congratulation to bikes! for the winning guess.
Realize these are not the most accurate gauges. Seeing it register the battery at at 12V+ after hooking up shore power overnight while working on the no-start issues, made me think there is an issue from the readings at the campsite. I need to put a multimeter on the battery to see that is at vs. the one in the cabin.
bikes! Samba Member
Posted: Tue Sep 03, 2024 7:25 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
Buying myself a chicken dinner!
Next time I’m up there with the van, I’ll weigh it so we know what a later VR6 weekender tips the scales at. Way more than I thought, is the likely answer. |
Saturn Samba Member
Posted: Sat Oct 05, 2024 6:31 pm Post subject: Latches, Windows, Lighting & Entertainment |
More Incremental Improvements
At the same time I was trying to solve the no-start issue in the 1995 EVC, there were a few other items which were also being addressed before heading to Monterey/Laguna Seca. Figured these should be covered in a separate post rather than intermingling it with the ones about diagnosing and replacing the Hall Sensor.
Rear Seat Locking Pins
One of the irritating aspects of the EVC is converting the rear seat into and out of the bed position. This has been a lingering issue since purchasing the van in 2018. A couple years ago I adjusted the cables around the front handle but that really only fixed the drivers side. The passenger side locking pin still would not raise enough without requiring some manual assistance as there was too much slack in the cable. This became an intricate ballet of reaching under the seat to grab the pin while pulling on the front handle and sliding the assembly at the same time. After doing a quick inventory of the galley for the camping trip, it was time to fix this issue once and for all. After gazing at the set up for a bit, realize the release cable also has an adjustment at the locking pin. Because of the cramped/limited space, the best way to address this is to fully pull the seat out. Now that there is access to the locking pin assembly, the excess slack can be adjusted out of the cable. Grabbing a deep socket, this is inserted under the pin to keep it a raised position. Loosen up the cable lock, pull on the wire to take up the resulting slackness and resecure things in place. This is repeated several times to get the locking pin in the correct position when at rest and while activating the front handle. Slide the seat assembly back into place and it now works like a charm.
Visibility
While awaking the EVC for the big trip, hit the windshield wipers to clean off an accumulation of dust on the front windscreen. Pull back on the stalk to realize the spray pattern needs to be adjusted as it is hitting all over the windshield and not in the optimal places. With dual nozzles what I do with setting up is to create an overlapping “W” pattern. This equates to the outside nozzle being aimed towards the closest person (driver) and the inner one at the opposite person (passenger). This provides redundancy so each sprayer can project fluid to reach both wiper arms/blades. If one of them becomes clogged for any reason, there still is coverage for the width of the windshield. Adjust the sprayers on the EVC accordingly and now cleaning fluid is not being wasted by being too high or low on the windshield. Check and adjust this on the 1993 Weekender as well.
Lighting
One of the things I notice on the EVC is the bulb for the cigarette lighter is burnt out. Earlier in the year I addressed this on my 1993 Weekender. (https://www.thesamba.com/vw/forum/viewtopic.php?p=10183529#10183529) Since this bulb is not a serviceable item I figured out how to replace it with an LED bulb. After fixing the one in the Weekender, I converted another one of these light fixtures to an LED set up as a spare. This was a simple fix on the EVC, as all I had to do was to remove the old illumination assembly and install the new one. While access is limited because of the internal partitioning of the center dash piece, use a small screwdriver to lever the old one out. Slide the new one into place and the lighter and ashtray are lit up once again.
Fine Arts Outing
While talking with a friend of mine, the suggestion comes up about catching a movie, I check online to see where it is being shown and see its playing over in the East Bay at the Concord Drive-in. Propose this particular venue with the response, “Hell yeah! It's been years since I have been to the Drive-in.” On the way there, pick up some Indian take-out and have dinner in the Weekender as the orange western sky fades away and the previews start to roll. Back the van up and had a thoroughly enjoyable time watching Beetlejuice II through the rear hatch. Next time need to remember to bring something with decent back support.
Saturn Samba Member
Posted: Mon Nov 18, 2024 1:36 am Post subject: Mirrors & Treasure Hunting At The Boneyard |
On the 1993 Weekender, a lingering issue since the middle of the summer is a damaged driver’s side mirror. Went out one day to discover a v-shaped crack in the mirror. Yet another case of a mystery injury inflicted on the van, one of the occasional taxes of parking on city streets. While a bit annoying, compared to the no-start issue happening on the 1995 EVC before heading to Monterey Car Week, it fell quickly to the bottom of the to-do list. After touring the USS Hornet across the bay while my nephew was still in town, 1/3 of the mirror finally detached and shattered itself along the main drag of Alameda. My cache of Eurovan parts includes two passenger side mirror assemblies but no drivers side units so it is Amazon to the rescue. Order this replacement mirror (https://www.amazon.com/dp/B0131R19QW) and install it into place. The mirror adheres to the backing with several discs of double-sided tape so something I should probably check on in several years.
After the maelstrom of August, focus turned back to my 1967 Volvo 122 project and rebuilding the braking system. A friend of mine reaches out to me about helping value a couple cars from an estate. Their friend’s boyfriend passed away over the summer leaving several cars and motorcycles to deal with. Among the collection was a Volvo 240 wagon, “some kind of Mercedes” and a couple pickup trucks. These are sitting about an hour north of SF on the way to Sacramento. As we make plans to go check them out, receive the alert a 1993 Eurovan has arrived at the Fairfield Pick-n-Pull. Definitely time to mount an expedition. First stop is to check out and assess the vehicle collection. Find an early 90s 240 wagon which part of the dash ripped out and a no-start condition. The Mercedes turns out to be a mid-80s 380SL, while sitting in a barn it is fortunately under a car cover. There is also a mid-1970s F250 pickup which we need to spend fifteen minutes sifting through a coffee can of keys to locate its proper set. I express interest in the Volvo and the Mercedes after getting the titles sorted out at DMV. From there it is onto the boneyard to check out the Eurovan there.
It is a pretty derelict cargo can sitting in the rows. The drive train is MIA and the interior is filled with multiple boxes of VW pieces and parts though predominantly non-Eurovan related. Begin to wonder if this van originated from a closed-down VW shop/garage. End up extracting the instrument cluster out from the dashboard. While perusing through the boxes of parts in the very back, come across two other Eurovan instrument clusters. One of them is a stamped 1992 with the temp and fuel gauges featuring numbers on the face (deg F and gallons respectively.) End up swapping those two gauges into the cluster I originally pulled out of the dash. Do not unearth anything else worth picking up except a 70s-era ignition switch and wiring complete with the oval key with the VW logo cast into it. Figure this could be utilized as a remote starting setup while working in engine bays.
Back at home, inspect the instrument cluster, give it a cleaning and reflow the solder on the joints for the voltage stabilizer. A couple days later install the cluster into the Weekender in order to see if everything works properly. After getting it into place start the engine to let it idle and get to operating temperatures. Oil pressure and coolant lights work as expected as do the gas and temperature gauges.
Reinstall the steering wheel to take it for a test drive. Drive towards the airport and turn around back to home, a 20 mile trip. Everything works as expected, including the odometers as well as the speed sensor for the cruise control. The one thing I do note is the coolant temperature reading. The needle settles out at the same position as in the other cluster, at about 10 o’clock. This is marked at 230°F on the gauge face though this a registering around 190°F on the 52mm gauge mounted in the center dash area. Start to wonder if this might be the reason these faces with degree numbers included were only found in the early production vans. Remove the cluster and reinstall the older one back in its place.
At about the same time the Weekender goes up on alert status. My friend Armando is taking part in the Virginia City Hill Climb put on by the Ferrari Club of America. While driving his 1975 308 GT4 during the practice session, his alternator warning light suddenly becomes a bright beacon on his dashboard. A multimeter confirms his alternator is no longer charging and he texts me about the situation. Give him some recommendations on how to get the Ferrari 245 miles back to SF and make the offer to drive the Weekender to Sacramento with a fully charged battery. The van could also provide an escort back to the Bay Area while charging up batteries along the way. Fortunately, Armando is able to borrow an old battery charger from the event organizers. On the way back he stops in Reno to purchase a second battery and starts the climb up the eastern Sierras to cross the Donner Summit. After swapping out the batteries on I-80, he stops at a gas station in Auburn, CA (halfway point) and the attendant there allows him to plug in the battery charger into their garage outlet while getting lunch. The Ferrari is able to make it back home and a new alternator is on order. After getting the text of Armando’s successful arrival unplug the battery on the charger and the Weekender stands down.
In a less fortunate event, two weeks later I receive news that the barn where the Mercedes sat and next to the F250 burned to the ground taking the 350SL with it and scorching the side of the pickup truck. Easy come, easy go… The Volvo wagon was nowhere near the fire so it may still join the fleet in a month or so. Where the person’s shadow is hitting, that is the remnants of the front of the 350SL. One of the "x"-shaped supports in front of the radiator is just off their elbow.
Update 11/20/24 My friend texted these images of the Mercedes as they were helping their friend with the inventory of the barn for the insurance company. Apparently the pictures I took of the 350SL when initially inspecting and assessing it are the only recent ones of the car.
rckolson Samba Member
Joined: December 14, 2024 Posts: 9 Location: S. Maine
Posted: Sat Mar 01, 2025 5:37 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
Saturn, do I understand you torqued the crank bolt to 330ft/pd with the DeWalt driver wrench? Does that tool allow torque setting?I didn't see a model that does that. How did you secure the crank while you did this? (Or is that why the timing marks moved?)
I'm getting ready to do this job on the same model, so your response will be helpful.
Thanks |
Saturn Samba Member
Posted: Mon Mar 03, 2025 1:17 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
| rckolson wrote: |
Thanks |
The straightforward answer is no, I am not sure what ft/lbs the crankshaft bolt is torqued to.
This is referencing a post 2.5 years ago covering changing the timing belt, idler pulleys, water pump and serpentine belt in my 1995 EVC ( https://www.thesamba.com/vw/forum/viewtopic.php?p=9897063#9897063). The specification of 330 ft/lbs is beyond my capacity to measure with my tools as my torque wrench only goes up to 75-80 ft/lbs.
In that post I describe the pieces being reassembled along with the torque value listed in the Big Blue Bentley Book. The intent of these values is to include those so its accessible to the reader in the write-up and not have to have a Bentley Book open at the same time.
| Quote: |
| Reattach and secure the lower timing belt cover then reinstall the harmonic balancer. Install the four and 6mm allen bolts (15 ft/lbs) grab the Dewalt Impact driver, as it makes quick work tightening down the crankshaft bolt (330 ft/lbs.) A breaker bar is braced against the lower suspension arm and the camshaft bolt is torqued (74 ft/lbs) into place. Recheck the tension on the timing belt and then secure the 13mm tension roller nut (10 ft/lbs) |
When removing the harmonic balancer, my 1/2" Dewalt impact driver was able to loosen the main bolt with not much effort at the highest setting. While this Speed 3 setting does not equate to a specific torque setting, this is what I used on the crankshaft bolt to loosen and tighten it. What the final torque value turned out to be is unknown, I do believe it is comparable to what it was before removal.
In the above text I reference jamming a breaker bar against the suspension while torquing the camshaft bolt after installing the timing belt on. That was done to prevent the engine from rotating and to obtain an accurate torque reading. An impact drive operates differently, creating a series of quick jolts to loosen a fastener. This quick on/off action tends not to create much rotation on engines with nominal compression. It is times like alternator bolts where parts (fan assembly) may need to be locked to prevent spinning. When using the impact gun on the crankshaft bolt, the engine did start to rotate but not in any significant way.
Abscate Samba Member
Joined: October 05, 2014 Posts: 24504 Location: NYC/Upstate/ROW
Posted: Tue Mar 04, 2025 2:09 am Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
You can get pretty close as in good enough, on a bolt like that with punch marks. VW wants you to buy a counterhold tool of course.
Source; 55 years experience, punch marks 500+ , loose harmonic balancer nuts 0 _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
eurovanrescue Samba Member
Joined: April 08, 2018 Posts: 8 Location: San Diego, CA, USA
Posted: Thu Apr 10, 2025 8:31 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
Wow, what a thread. I have a 1993 Weekender (auto trans) that I've owned for about 12 years. A lot of similar issues over the years.
I still have the blinking coolant light.
I'm in the midst of a no radiator fan issue that seems to be related to relay 114. I tried a "tested" oem replacement from ebay. No change.
With the key in ON position...
The test that I've been told to try is the jumping pins on the connector at the radiator fan switch. No power there. If I pull relay 114 and jump #2 & 3, I can get power to the radiator fan switch connector... and jumping middle to outside will engage the fans.
I'm not an electrical engineer, but I'm wondering if there is something that the relay 114 is not receiving to bridge the power. I checked all of my fuses and even #19 since I saw that you had some issues with that. No difference.
I'm just imagining that relay 114 may not be receiving the signal that the key is ON or something else...
Any thoughts? |
Saturn Samba Member
Posted: Mon Apr 14, 2025 1:16 pm Post subject: Re: Space Capsule 1995: Repairs, Roadtrips, Retrofits, & Wrenching |
| eurovanrescue wrote: |
I still have the blinking coolant light. |
After working on addressing this on my 1993 Weekender, my belief is the root issue is an electrical component in the instrument cluster circuit board. Only after swapping the main board out did the blinking coolant light finally extinguish. I do not possess the electrical engineering knowledge and skills to figure out what has either failed or gone way out of spec with that circuit so it stays a mystery.
Right now I am experiencing another issue with my instrument cluster, my temperature and fuel gauges ranging between not registering at all, reading really low and occasionally working normally. It is looking like the issue is in the main harness connection into the instrument cluster. If I reach behind the cluster and press on the main connector sometimes the gauges will come back to life. I plan this in detail in an upcoming post.
During recent crossing of the Bay Bridge into Oakland. These pictures are taken approx. 4 miles and 4 minutes apart while driving highway speeds.
I'm not an electrical engineer, but I'm wondering if there is something that the relay 114 is not receiving to bridge the power. I checked all of my fuses and even #19 since I saw that you had some issues with that. No difference. |
One of the things I tried is jumping #2 and #6 connectors on the #140 relay at the fuse box. (https://www.thesamba.com/vw/forum/viewtopic.php?p=10056361#10056361) This activates the radiator fans when the AC system kicks on. You could do the same thing with the 114 relay to see what happens there. I am not sure which exact two connectors will need to be bridged, that should be able to be figured out from a wiring diagram.
Other items to check are the 50A fuses which is next to and underneath the row of 5 relays and behind the drivers side headlight. There are also the fan resistors which can go bad, these also sit behind the headlight.
