Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79537 Location: Sneaking up behind you
Posted: Mon Nov 18, 2024 4:37 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
oprn wrote: |
I found this photo in the gallery on this site a while back. I don't recall who posted it but when I ran across this thread I though it belonged here.
Maybe it is already posted here, I tried to find it but there are so many dead pictures here that I gave up. Here it is none the less, complete with the appropriate oil puddle!
If we're posting stupid stuff, then i'll add these.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
BFB Samba Member
Posted: Mon Nov 18, 2024 7:51 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
there's even a plug underneath which means that's a big enough trailer to have lights so its not like its a small trailer you might use for say hauling leaves around your yard or something.
I wonder how much the cover flexes and how much the force of the trailer pushing forward when you stop has caused the gears to eat into the cover?
in all actuality, its probably been in use like this for over a decade _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
FarmerBill  Samba Member
Joined: July 25, 2017 Posts: 866 Location: New England
Posted: Mon Nov 18, 2024 8:23 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
At the very least it looks like they used longer studs to take advantage of all the thread in the case. I had a bay-window with an oil pump mustache bar adapter, the stock studs were holding on by about 1 twist. Guess what happened next.  |
oprn Samba Member
Joined: November 13, 2016 Posts: 14794 Location: Western Canada
Posted: Wed Nov 20, 2024 8:01 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
cdennisg wrote: |
EverettB wrote: |
What's the recommended tongue weight on that?  |
30 PSI at 2000 RPM. |
The weight of the ball perhaps? _________________ Our cars get old, we get old but driving an old VW never gets old! |
oprn Samba Member
Posted: Thu Nov 21, 2024 5:21 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I am guessing this was done on purpose on one of those "slammed" cars to keep the edges of the oil inspection cover from catching on man hole lids on the road?
shanered Samba Member
Posted: Fri Dec 06, 2024 12:07 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Poor man's deep sump and self drain oil system, also useful for finding your way home. |
Glenn  Mr. 010
Posted: Fri Dec 06, 2024 12:49 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
oprn wrote: |
No, it was posted by a "young lady" that asked why the studs were not long enough.
The picture was a keeper. _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon Dec 09, 2024 7:07 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Nice.correction glenn....  |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2890 Location: HdG, MD & NJ
Posted: Tue Dec 10, 2024 4:11 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
My wife has the same problem. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
EVfun  Samba Member
Posted: Sun Jan 05, 2025 9:12 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
"Wishbone" by Ed Roth. It's been said that he hated it.
Wildthings wrote: |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Sun Jan 05, 2025 9:34 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
EVfun wrote: |
...especially at valve adjustment time. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Mon Jan 06, 2025 9:10 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I'd love to hear that thing run, and there is a temp gauge that'd be a fun experiment. |
Glenn  Mr. 010
Posted: Mon Jan 06, 2025 9:14 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
I like the custom zip ties on the spark plug wires _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon Jan 06, 2025 9:41 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
That custom with a “k”.
I’m more curious on the narrowed rear axles. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1384 Location: Bella Coma Canada
Posted: Mon Jan 06, 2025 10:11 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
KTPhil wrote: |
EVfun wrote: |
...especially at valve adjustment time. |
"License plates" I don't need no stinking license plates _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS |
EVfun  Samba Member
Posted: Mon Jan 06, 2025 11:03 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Da TOW'D wrote: |
KTPhil wrote: |
EVfun wrote: |
"License plates" I don't need no stinking license plates |
If you are so obviously not running front brakes you don't want to be easily identified.  _________________
Wildthings wrote: |
torchwerks Samba Member
Posted: Tue Jan 07, 2025 8:52 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
One of the reasons Ed hated 'Wishbone' was Revel didn't want to pay him to build a model of it. He also hated the way it rode. He cut it in pieces, and told Dirty Doug to throw it away. Doug stashed it away and sold it to Ed's son, Reno (that's Reno in the pic). Reno restored it, much to Ed's dismay.
My brother had a ragtop named the 'Ol Gray Mare'. Ed lettered it on the back of his Wink mirror. Ed was responsible for numerous parts on the ragtop. He had a mini junkyard in his backyard. My brother would come with a question, and Ed would send him to the backyard to grab more parts. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Tue Jan 07, 2025 10:13 am Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
EVfun wrote: |
Pretty obvious he hated it. No fan, no cooling tin, no air cleaners... the only thing left to do to try to kill the engine would be to run it without oil as well. _________________ 1960 Ragtop w/Semaphores "Inga" |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15360 Location: Syracuse, NY
Posted: Tue May 06, 2025 1:06 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
Abscate wrote: |
EVfun  Samba Member
Posted: Tue May 06, 2025 1:48 pm Post subject: Re: Abortion ENGINES ONLY Thread, come see the Horror! |
The hot dayglow spray paint is good for at least 5 horsepower. Plus ignition sparks you can see are more powerful than hidden ones! _________________
Wildthings wrote: |
