Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26125 Location: Olympia Wash Rinse & Repeat
Posted: Wed Dec 11, 2024 10:27 am Post subject: Re: Windshield seal replacement - How to? |
BarryL wrote: |
BonTonRoulet wrote: |
Surely you've had a chance to water test your windshield project by now. So what's the verdict? |
Totally watertight. Bulletproof. I did kinda' overkill on the goop though. |
Really needs to be over six months to be sure.
That is the longest with just new rubber without sealant without garage or canopy. Then definitely in our wet rainy weather it would begin to leak. Think that a certain amount of dirt has to get into between the seal and body to wick the water inside the interior. _________________ In Stereo, Where Available! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15310 Location: Casa de Oro, California
Posted: Tue Jan 28, 2025 6:40 pm Post subject: Re: Windshield seal replacement - How to? |
Many squalls hit this last storm just over. Watertight. |
70bus Samba Member
Posted: Tue Jan 28, 2025 9:57 pm Post subject: Re: Windshield seal replacement - How to? |
Now that we have rain coming, maybe I should put the 65 on the street to test my windshield efforts.
Major mitigating factor: in last January's storm a 125' fir fell and crushed a friend's Syncro singlecab with hardtop. Might wait until gentler spring for a test. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater |
BarryL  Samba Member
Posted: Mon Feb 03, 2025 6:30 pm Post subject: Re: Windshield seal replacement - How to? |
Had two warm days so did some final cleanup of the goo. Warm weather not a prerequisite but it is more fun.
Break flat sticks in half then split them. Use rough end to remove goo. Don't smear-swipe but more of a remove swipe. Replace stick every time.
Coleman fuel cleans leftover followed by alcohol followed by water.
For me I'm going to call this product the goto goop. |
pacrat Samba Member
Joined: April 20, 2006 Posts: 103 Location: Jennings Lodge
Posted: Sun Apr 13, 2025 6:22 pm Post subject: Re: Windshield seal replacement - How to? |
Lots of great information here. Thank you!
I have the the Wolfsburg West seals. I am having trouble getting them installed to the window. I get it started and using my thumb work the seal around the window, but they keep popping out. I replaced them maybe 25 years ago, but don't recall having this problem.
Any words of wisdom or general tips? What am I doing wrong? |
BarryL  Samba Member
Posted: Sun Apr 13, 2025 6:38 pm Post subject: Re: Windshield seal replacement - How to? |
Do you have someone to help you? Do you have the string or fat insulated wire around the groove? Or do you mean putting the rubber on the glass? |
Posted: Sun Apr 13, 2025 7:06 pm Post subject: Re: Windshield seal replacement - How to? |
Some folks require using tape to keep section by section of the seal in place on the glass. Once all in place the seal should stay fairly stable on the glass, that is when to remove the tape and install the wire into the outer lip. _________________ In Stereo, Where Available! |
pacrat Samba Member
Posted: Mon Apr 14, 2025 12:00 pm Post subject: Re: Windshield seal replacement - How to? |
BarryL wrote: |
I do have helpers, yes. To clarify, I am having trouble putting the rubber around the glass. I get a short section on and as I move around the window, it slides off the previous. Having arthritic thumbs is not helping.  |
pacrat Samba Member
Posted: Mon Apr 14, 2025 12:01 pm Post subject: Re: Windshield seal replacement - How to? |
Eric&Barb wrote: |
Some folks require using tape to keep section by section of the seal in place on the glass. Once all in place the seal should stay fairly stable on the glass, that is when to remove the tape and install the wire into the outer lip. |
This is a good idea. I'm also going to make sure the window is much cleaner. Maybe the dust and dirt is keeping the rubber from "gripping" the glass.
Thank you and BarryL for the suggestions.
Cheers,
Tony |
70bus Samba Member
Posted: Mon Apr 14, 2025 12:20 pm Post subject: Re: Windshield seal replacement - How to? |
I used some WW seals on my baywidow, and they were a bear to get on the glass. I also ended up using yards of blue painter's and some duct tape. I had less trouble with a WCM seal, FWIW.
At least you don't have the added fun of thin metal Deluxe trim in the seal. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL  Samba Member
Posted: Mon Apr 14, 2025 6:36 pm Post subject: Re: Windshield seal replacement - How to? |
pacrat wrote: |
BarryL wrote: |
I put opposite corners on then get the other opposite corners on then work around the flat sides. I pinch the rubber so it opens like a duckbill working my way around on opposite sides.
Are you using sealant between the glass and the rubber? |
pacrat Samba Member
Posted: Wed Apr 16, 2025 4:05 pm Post subject: Re: Windshield seal replacement - How to? |
BarryL wrote: |
pacrat wrote: |
BarryL wrote: |
Thank you, BaryL! I used a combination of this and a couple of pieces of blue tape. All set and almost ready for a trip to Moab! |
BarryL  Samba Member
Posted: Sat Aug 30, 2025 6:06 pm Post subject: Re: Windshield seal replacement - How to? |
Eric&Barb wrote: |
BarryL wrote: |
That is the longest with just new rubber without sealant without garage or canopy. Then definitely in our wet rainy weather it would begin to leak. Think that a certain amount of dirt has to get into between the seal and body to wick the water inside the interior. |
Huge squalls the other day. Westy parked slight uphill facing up in sun most of the day. No drips anywhere. |
