Windshield seal replacement - How to?
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Dec 11, 2024 10:27 am    Post subject: Re: Windshield seal replacement - How to? Reply with quote
BarryL wrote:
BonTonRoulet wrote:
Surely you've had a chance to water test your windshield project by now. So what's the verdict?
Totally watertight. Bulletproof. I did kinda' overkill on the goop though.
Really needs to be over six months to be sure.
That is the longest with just new rubber without sealant without garage or canopy. Then definitely in our wet rainy weather it would begin to leak. Think that a certain amount of dirt has to get into between the seal and body to wick the water inside the interior.
In Stereo, Where Available!
BarryL Premium Member
BarryL is offline
PostPosted: Tue Jan 28, 2025 6:40 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Many squalls hit this last storm just over. Watertight.
70bus
70bus is offline
PostPosted: Tue Jan 28, 2025 9:57 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Now that we have rain coming, maybe I should put the 65 on the street to test my windshield efforts.
Major mitigating factor: in last January's storm a 125' fir fell and crushed a friend's Syncro singlecab with hardtop. Might wait until gentler spring for a test.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
BarryL is offline
PostPosted: Mon Feb 03, 2025 6:30 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Had two warm days so did some final cleanup of the goo. Warm weather not a prerequisite but it is more fun.
Break flat sticks in half then split them. Use rough end to remove goo. Don't smear-swipe but more of a remove swipe. Replace stick every time.
Coleman fuel cleans leftover followed by alcohol followed by water.
For me I'm going to call this product the goto goop.
pacrat
pacrat is offline
PostPosted: Sun Apr 13, 2025 6:22 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Lots of great information here. Thank you!
I have the the Wolfsburg West seals. I am having trouble getting them installed to the window. I get it started and using my thumb work the seal around the window, but they keep popping out. I replaced them maybe 25 years ago, but don't recall having this problem.
Any words of wisdom or general tips? What am I doing wrong?
BarryL is offline
PostPosted: Sun Apr 13, 2025 6:38 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Do you have someone to help you? Do you have the string or fat insulated wire around the groove? Or do you mean putting the rubber on the glass?
Eric&Barb
PostPosted: Sun Apr 13, 2025 7:06 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Some folks require using tape to keep section by section of the seal in place on the glass. Once all in place the seal should stay fairly stable on the glass, that is when to remove the tape and install the wire into the outer lip.
pacrat
pacrat is offline
PostPosted: Mon Apr 14, 2025 12:00 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
I do have helpers, yes. To clarify, I am having trouble putting the rubber around the glass. I get a short section on and as I move around the window, it slides off the previous. Having arthritic thumbs is not helping. Rolling Eyes
pacrat
pacrat is offline
PostPosted: Mon Apr 14, 2025 12:01 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
This is a good idea. I'm also going to make sure the window is much cleaner. Maybe the dust and dirt is keeping the rubber from "gripping" the glass.
Thank you and BarryL for the suggestions.
Cheers,
Tony
70bus
70bus is offline
PostPosted: Mon Apr 14, 2025 12:20 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
I used some WW seals on my baywidow, and they were a bear to get on the glass. I also ended up using yards of blue painter's and some duct tape. I had less trouble with a WCM seal, FWIW.
At least you don't have the added fun of thin metal Deluxe trim in the seal.
Craig K
70 Neunsitzer
65 Pritschenwagen
BarryL is offline
PostPosted: Mon Apr 14, 2025 6:36 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
I put opposite corners on then get the other opposite corners on then work around the flat sides. I pinch the rubber so it opens like a duckbill working my way around on opposite sides.
Are you using sealant between the glass and the rubber?
pacrat
pacrat is offline
PostPosted: Wed Apr 16, 2025 4:05 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Thank you, BaryL! I used a combination of this and a couple of pieces of blue tape. All set and almost ready for a trip to Moab!
BarryL is offline
PostPosted: Sat Aug 30, 2025 6:06 pm    Post subject: Re: Windshield seal replacement - How to? Reply with quote
Huge squalls the other day. Westy parked slight uphill facing up in sun most of the day. No drips anywhere.
Page 10 of 10
