JoshSnow1973 Samba Member
Joined: April 28, 2023 Posts: 6 Location: Central Coast, CA
Posted: Fri Feb 07, 2025 7:01 pm Post subject: Instrument cluster wiring/ identification |
Still sorting thru the dash on my 73.
Trying to match wiring diagram to the wires I have and to the actual cluster.
1. Does anyone have a good photo or diagram of just the backside of the cluster?
2. Can someone please i.d. #1 and #2 in this pic? Im not wrapping my head around all of the different terminals as they relate to the wiring diagram
Thx again!
Josh |
Semper_Dad Samba Member
Posted: Sat Feb 08, 2025 2:44 pm Post subject: Re: Instrument cluster wiring/ identification |
#1 is called a vibrator, essentially a mechanical form of a volt regulator. It should be connected to a black wire (Circuit 15) and a terminal of the fuel gauge.
#2 is the fuel gauge. Should never be connected directly to Circuit 15 (Black wire) otherwise it will burn out pretty quickly.
If you haven't already, you should download the wiring diagram in the technical section of the forum.
https://www.thesamba.com/vw/archives/info/wiring/181_Wiring_Diagram_4-73.pdf
Maybe this will help.
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Heiferman Samba Member
Joined: February 28, 2024 Posts: 373 Location: Georgia, USA
Posted: Mon Feb 10, 2025 11:41 am Post subject: Re: Instrument cluster wiring/ identification |
It also appears the spade is broken off the back of your vibrator? _________________ - 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance |
