chicagovw Samba Member
Joined: January 06, 2007 Posts: 1513 Location: Chicago IL/CHandler AZ
Posted: Tue Jul 16, 2024 10:29 pm Post subject: Re: Buggeee's 1972 Super Beetle |
| I've watched your build over the past several years, and spent some time tonight catching up-looking good! I may have missed it, but does the number "13" have significance? I like that you have done this car yourself! |
Buggeee  Samba Member
Joined: December 22, 2016 Posts: 5048 Location: Stuck in Ohio
Posted: Thu Jul 18, 2024 2:10 pm Post subject: Re: Buggeee's 1972 Super Beetle |
| chicagovw wrote: |
It's my wife's lucky number. Plus it's an ugly-fun number in a way, and, for me, this car has survived lots of bad luck in prior lives, so much of it was crushed and beat out in various collisions that were unearthed during the excavations. Somehow owning the weirdness like a badge of honor seemed right. _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
Posted: Thu Jul 18, 2024 3:33 pm Post subject: Re: Buggeee's 1972 Super Beetle |
| Very cool-my wife's lucky number too, which is why I asked. |
bruceo98 Samba Member
Posted: Sat Aug 31, 2024 7:48 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Congratulations on the award. That’s what it’s about. Having fun with something you work hard on and getting to enjoy it.
Love the co pilot . Mine doesn’t take up much room . Whole 5 lbs .Lol _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
vamram  Samba Member
Posted: Sun Sep 01, 2024 3:52 am Post subject: Re: Buggeee's 1972 Super Beetle |
Awesome!  _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 873 Location: Ontario, Canada
Posted: Tue Feb 18, 2025 10:54 am Post subject: Re: Buggeee's 1972 Super Beetle |
| Buggeee wrote: |
Then I had submitted to the idea of a winter overlay under the huge tarp tent that my neighbors have all been gossiping to you about behind my back.
My Super Duper is missing the Bakelite Heater tubes that run into the body under the rear seat. I got some and they are in my basement. It takes a miracle or a pan separation to install them into the bug so I have lived with the California block off plates that probably went on when my bug was still in California.
AND THEN - I stumbled on this absolutely life changing, awesome thread in the Vanagon area about really inexpensive knock-offs of the gas heaters that normally cost more than my whole bug! I will link you to it here so you can debate and comment about the wholesome goodness or the life endangering recklessness of these heaters over there in that thread (not in my build thread please! Its messy enough over here already) https://www.thesamba.com/vw/forum/viewtopic.php?t=703569 All my info about where I got this thing, etc. is posted there.
I decided to try the diesel air heater and here's how it goes...
First, inspired from some other thread somewhere on the Samba, I went to Lowes or Home Depot and got some one-and-a-quarter inch pool hose to connect my heater channels to my defrost ports on the left and right side of my dash.
I used a bit of the hose and clamped it to my wife's vacuum (shhhhh) to clean out the mysteries from the dark place down in the corner of the trunk area. I used a pick to tear off the remainder of the paper hoses and free the wooden necklace beads and other weirdness that was blocking the heater channels, etc.
Then I wrapped some Gorilla Tape around the end of a tube to act as a stopper/gasket and worked it down into the darkness and into the top of the heater channel.
Here it is almost seated into the heater channel before the final push to snug it together.
That works.
Then I installed the knock-off diesel heater under the rear seat on the passenger side and plugged it into the heater channels where the y-pipes would have been coming from the Bakelite tubes (which are in my basement rather than my Super). I will simply drop a randomly organized pictograph explanation without a bunch of words as this is totally a DIY proposition on this nonsense right here. I got a little half-liter minibike gas tank and mounted that, along with a filter and the little diesel pump, next to the brake reservoir under the hood.
And here is the controller zip tied to one of the many holes in my dash, with fashionable masking tape blocking much of the cold air that comes through my un-gasketed front trunk area.
This works great!!! Say what you will amongst yourselves but with a heated cabin, I was able to get some Christmas shopping done in style!!!
Does the rear bench seat fit down correctly with that diesel heater hose crossing over to the heater channel? I may try this setup as well. _________________ 74 Super
84 Westy |
Posted: Tue Feb 18, 2025 5:22 pm Post subject: Re: Buggeee's 1972 Super Beetle |
| boxer74 wrote: |
Does the rear bench seat fit down correctly with that diesel heater hose crossing over to the heater channel? I may try this setup as well. |
That is a very good question. I was not able to drop the seat bottom in over top of what you see, because the seat frame has a bar that rests on the tunnel. I felt that there would be room enough between the seat spring and the tunnel if I fed the flexible tube up and through the seat, but never fully solved that puzzle. I just ended up feeding the drivers side only with an Elbow rather than both sides with the Tee seen in the picture. The seat fit fine over the heater and it worked well from my perspective in the driver's seat. I have heater boxes at this point but that diesel heater did serve me well that winter. _________________ Big Time 1988 Vanagon Westy
Chinaclipper Samba Member
Joined: October 03, 2019 Posts: 820 Location: Somewhere in the great Midwest
Posted: Thu Feb 20, 2025 7:43 am Post subject: Re: Buggeee's 1972 Super Beetle |
Ooh nice!
Gotta have heat where I am too. Its -13 degrees
BTW, what did Santa give ya from Guitar Center?
I just picked up a new 338 "Firefly" guitar and it really rocks!
Take care my friend,
CC _________________ China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight= |
Posted: Fri Apr 04, 2025 5:28 am Post subject: Re: Buggeee's 1972 Super Beetle |
Spring has Sprung!
Here's me and my buddy getting our cars positioned for the annual indoor Piston Powered Autorama show. It's a huge 3-day indoor car show that my dad would bring me to as a kid and I would dream of one-day building a car for it. Think day camp for gear heads with food trucks, coffee stand and lots of cool cars and great people all weekend long.
The show was a lot of fun and Dr. Kopressor got a trophy! Dream come true for that little kid.
There was a herd of pinstripe artists making cool art for charity, like this one that the missus has approved for our living room
The artist that did that picture did my helmet too with gumball numbers, racing stripe and pinstripes, all handpainted during the show. The proceeds go to kids tuition for trade school.
It was an awesome way to start the season.
We've come a long way baby!!!
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7585 Location: Houston, Texas
Posted: Fri Apr 04, 2025 6:43 am Post subject: Re: Buggeee's 1972 Super Beetle |
It's really nice seeing all the fun you are having with that car. _________________ www.vwnos.com [email protected]
vamram  Samba Member
Posted: Fri Apr 04, 2025 9:22 am Post subject: Re: Buggeee's 1972 Super Beetle |
| Buggeee wrote: |
Spring has Sprung!
Amazing, one of my favorite builds!! _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
vamram  Samba Member
Posted: Sat May 03, 2025 6:46 am Post subject: Re: Buggeee's 1972 Super Beetle |
Nice, Buggee! Um, whatcha doin' w/your "old" motor....?  _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
candyflame73 Samba Member
Joined: September 03, 2005 Posts: 440 Location: Texas
Posted: Sat May 03, 2025 7:19 am Post subject: Re: Buggeee's 1972 Super Beetle |
| Ceezer wrote: |
| I'm digging that stance! I know it's not typical for VW, but those pictures (with the hood & fenders) are just screaming for a hot rod flame lick! |
Hit the nail on the head. Here you go. Lowered front end and rear, but with a rake. And good old hot rod flames.
Posted: Sat May 03, 2025 8:59 am Post subject: Re: Buggeee's 1972 Super Beetle |
| vamram wrote: |
Nice, Buggee! Um, whatcha doin' w/your "old" motor....?  |
Well for now it will be sitting here in Ohio as a backup for you if you ever throw a rod while traveling through on one of your transcontinental journeys!
I pulled it because it needed a main seal badly and one thing led to another. Hahaha.
Now that it's out I see I had crossthreaded one of the plugs when I was taking them out repeatedly to read the mixture when jetting the carburetor for the blower - so I'm lucky that didn't pop out on me! I'll pull the head, put a Timesert in that hole and generally just look it over. I've only got 6,000 miles on it so far.
I am working on 58 Panel Bus that's in the welding stage at the moment, and I think this will be a convenient thing to drop in it if you haven't called for help by then! Kidding aside, I really do admire your epic journeys.
Bug on! _________________ Big Time 1988 Vanagon Westy
vamram  Samba Member
Posted: Sat May 03, 2025 12:43 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Ah, not sure where my next epic journey will be. My mom passed away in March so the Miami trips will be seriously cut back as a result. The Midwest may finally be on the horizon.
Epic journeys are the thing if TDCTDI. Now HE puts some serious miles on his cars. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
