Pdsit 32/34 fine tune...
Davy_B.
Davy_B. is offline
PostPosted: Fri Mar 07, 2025 2:46 pm    Post subject: Pdsit 32/34 fine tune... Reply with quote
Just installed a set that was overhauled by a company nearby. (Belgium) Concerns a 2l GD (injection) from 76' replacement for the 1.7l from 72' Supposedly everything was transferred to this engine from the top! (Po) Currently I can drive but have some reservations. I adjusted the pdsit's the colin, ratwell, Bentley way! thank you all in advance.... i just read too much i guess!
distributor is DVDA:
bosch 021 905 205 E
currently at:
870 rpm idle 5°ATC
3200 rpm 28°BTC
valves are set to 0.15 intake and 0.20 exhaust. probably should be 0.15 too??? big difference?
fix:
a) At low rpm a hesitation. especially after standing still for a while....
b) The exhaust pops slightly but i still need to plug a leak in the flange of the exhaust. Or they are a little too rich? Currently 3 and 3.5 off on the mix screw?? To see no difference on the test mix hose.(colin way) Valves?
c) I am still missing the burst at cold start on fast idle. I had them tuned to 0.6mm according to Bentley. can i set it more? Bentley said no more...
Both throttle plates don't open equally now but isn't that normal if you adjust the 10mm nut (72') AFTER synchronizing the crossbar to synchronize the airflow at 2500 rpm?
Then you change the position of the throttle valves, right? At idle rpm right does have much higher airflow than left??? cis??? Do you have to fix this with the throttle stop screws??? right is only tuned to 0.10mm as Bentley suggested, so i can't turn much in there. And left i will then presumably plug a hole as airflow increases.... Got me a STE BK sync now so I'm doing it all over.
still have some learning to do but hopefully we will get there!
67rustavenger
67rustavenger is offline
PostPosted: Fri Mar 07, 2025 2:57 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
A slight language barrier.
Sync the carbs with the engine warmed up. They should flow the same amount side to side.
Then sync the linkage so both carb throttle plates open evenly and at the same time.
Since you like to read, read the first 20 pages of this thread. While it concerns wideband results. It does offer very good tuning idea's for dual carbed engines.
https://www.thesamba.com/vw/forum/viewtopic.php?t=293837
Even if you don't have a wideband, it will help you understand getting dual carbs setup and running well.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
SGKent Premium Member
SGKent is offline
PostPosted: Fri Mar 07, 2025 3:13 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
once you get them synced, you can cup your two hands together like you were going to strangle a carb, then bring your hands in to cover up the top. If the RPM goes up as you get your hands closer then the mixture is too lean. If the RPM falls as you bring your hands in, the mixture is too rich. Your hands are acting as a choke. you should be right on top of the carb almost before the RPM starts to fall from your hands cutting down the airflow and richening the mixture. The sync them again.
George Carlin:
Skills@EuroCarsPlus:
busdaddy
busdaddy is offline
PostPosted: Fri Mar 07, 2025 3:50 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Idle synch is different than cruising synch, that 10mm nut sets the cruising synch, the individual stop screws adjust the idle. The book settings are really just a starting point, rebuilt or not they are 50+ years old and worn in places, if the high idle isn't high enough add a turn to the choke links, but try the rich/lean test SGK suggested first, if it's super rich (or lean) the high idle cam may not be able to compensate.
Слава Україні!
Davy_B.
Davy_B. is offline
PostPosted: Fri Mar 07, 2025 11:47 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Ok I will definitely try this method!
How would it be that the sync at high speed is the same but then when I look at low rpm there is a big difference in airflow between left and right. Surely you would think that this should not give a big difference anymore? Bad uni-syn??
I'm going to plug the exhaust leak first. Then the valves in/out 0,15... it's not 74' so why I did 0,20 God knows... Hopefully the "popcorn" of the exhaust is already a lot less! Then I'll just redo the procedure with the STE-bk instead of the uni -syn. Hoping for the right result!
I will keep you informed.
mikedjames
mikedjames is offline
PostPosted: Sat Mar 08, 2025 10:05 am    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
I once was asked to look at a dual carb setup like this and found the linkage one side had two badly worn heim joints, so there was about 1/8" of slop.
This bus was set for balanced air flow at idle, using the end stop screws, but one carburettor would open well before the other - if I put my head half way between them with the engine idling and blipped the throttle with the air cleaner removed, you could hear the "cough" as one side opened up well before the other as an interesting stereo effect..
I confirmed it by turning the throttle spindles one at a time and discovering that one side was properly connected to the linkage, and the other side was not .
Ancient vehicles and vessels
Starbucket
Starbucket is offline
PostPosted: Sat Mar 08, 2025 10:30 am    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Step one is to sinc. the linkage, hold two plastic drinking straws lightly (one on each butterfly) and have a helper SLOWLY start to press on the gas pedal Don't open the throttle all the way you are just feeling that each carb. is starting to open at the exact same time, if not adjust the linkage (loosen the linkage to the one that opened first) until both open at the same time.
step two is to look down the carb. throats as your helper SLOWLY starts to press on the gas pedal, the accelerator pumps should start to squirt a stream of gas down the carb. throat AS SOON as the throttle starts to open or adjust the pump linkage until they do.
Take a drive and if all is not fine work on your mixture/timing.
wagen19
wagen19 is offline
PostPosted: Sat Mar 08, 2025 11:20 am    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
bosch 021 905 205 E
currently at:
870 rpm idle 5°ATC
3200 rpm 28°BTC
fix:
Your distributer and setting is wrong for carbs. The 1.8 l and 2,0 l engines, for ex german AP and CJ engines are using the 021 905 205 P, Bosch 0 231 168 005 (sigle vacuum). The setting is 7,5 BTDC when idling 875 rpm. (it seems, your 021 905 205 E has much wear too)
Davy_B.
Davy_B. is offline
PostPosted: Mon Mar 10, 2025 12:30 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Exhaust leak is bigger than thought. Of both front exhaust pipes, all 4 gaskets are leaking and the flanges are deformed.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Mar 10, 2025 1:49 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
3.5 turns out on the carburetor mixture screws sounds like a lot. When I get these dialed in with Colin's instructions, I find them about 1.5-2 turns out at the carburetor and four turns out (or more) at the central idle mixture.
870 RPM isn't helping you. The closer you get to 950-1,000 with the CIS adjustment, the smoother you'll be driving.
Cold start speed is set with the hex nut linkages off the choke. The closer to the end of the threads your assembly goes, the faster your cold start will be. Cold start enrichment is set by twisting the choke elements. The amount of enrichment affects the speed setting, so set the choke flaps to open in sync and close enough for your climate, THEN move on to cold engine speed.
Of course, you will never get perfect cold idle without working distributor vacuum. It looks like your tests are good, but you also need to test maximum vacuum advance when revved (up to 42°btdc is fine.) Without working vacuum advance, cold idle and throttle response will suffer. Also, test vacuum retard by pulling off that hose at warm idle. Speed should jump up.
Good luck,
Robbie
www.airschooled.com
Road trip reports and tech blog:
Davy_B.
Davy_B. is offline
PostPosted: Tue Mar 11, 2025 1:33 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
*3.5 is finger off no change. But I don't like it either... 4 turns on the idle mix is about right. Going for the cupping test next.
*870 is at idle hoses (retard) on. If I remove retard hose speed will go to 1050. Not good?
*I will set up the fast idle links a bit higher. Choke open sync.
*Vacuüm advance i will check... It works but I don't know the numbers
Vacuüm retard is ok I think. +/-1050 without and +/- 850 connected. Warm engine.
Good luck,
Robbie
airschooled
Air-Schooled
PostPosted: Wed Mar 12, 2025 11:19 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Davy_B. wrote:
A) *3.5 is finger off no change. But I don't like it either... 4 turns on the idle mix is about right. Going for the cupping test next.
B) *870 is at idle hoses (retard) on. If I remove retard hose speed will go to 1050. Not good?
C) *I will set up the fast idle links a bit higher. Choke open sync.
D) *Vacuüm advance i will check... It works but I don't know the numbers
Good luck,
Robbie
A) You could lean out the carb screws and richen the CIS mixture screw to experiment. Count your turns and you can always revert back.
B) The 870rpm idle speed is too low unless 110% of your setup is factory perfect fresh. Try for 950-1000rpm warm idle for best cold start and smoothest drivability. All idle speed should be set with the big brass CIS screw on the top left side.
C) Your picture shows the fast idle speed setting a little lower than I'm used to seeing. I would bring the nuts/barrel assembly up 2-3 full turns and adjust to taste.
D) Sounds good.
www.airschooled.com
Davy_B.
Davy_B. is offline
PostPosted: Fri Mar 14, 2025 3:16 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Checklist...
Today exhaust leak repaired.
And gave fast idle links a turn up! 1st test better... Tomorrow more testing!
busdaddy
busdaddy is offline
PostPosted: Fri Mar 14, 2025 4:07 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Excellent!, stuff like this is a marathon, not a sprint, keep dealing with a little at a time. Cool
Слава Україні!
Davy_B.
Davy_B. is offline
PostPosted: Tue Mar 18, 2025 12:21 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
When should my vacuum advance take effect? And how can I check that. Retard seems ok.
Set my idle at 950rpm and my fast idle links 1 turn up. Much better at thé moment.
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Mar 18, 2025 12:53 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
The advance should overtake the retard just off idle. So your timing should be able to get to 8°BTDC and then keep going up, as soon as you open the throttle. Retard should only be in with the throttles closed. So it's a pretty big swing in timing right off idle.
SL
airschooled
Air-Schooled
PostPosted: Tue Mar 18, 2025 12:56 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
You can check it by watching the timing scale with a strobe light while revving the engine. Like Scott said, timing should jump up 10-20° right when you open the throttle.
Another way is to hold the engine at 1,500-2,000RPM and connect/disconnect the vacuum advance hose while watching the timing light. The timing (and probably engine speed) will jump up when connecting the hose, and down when disconnecting.
When EVERYTHING is perfect with your choke and fast idle adjustment, the vacuum advance will be activated at cold start by the fast idle linkage holding the throttle open until the chokes warm up and open fully.
Robbie
www.airschooled.com
Davy_B.
Davy_B. is offline
PostPosted: Tue Mar 18, 2025 1:15 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Ok so if I remove retard when i'm at 2000rpm it should not change on the Strobe.
But when i remove vac advance I should go down at 2000rpm.
airschooled
Air-Schooled
PostPosted: Tue Mar 18, 2025 1:17 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
Probably. The position of the throttle affects vacuum timing more than the actual engine RPM.
You can also test vacuum
Advance by checking for maximum advance at high RPM with and without the hose. You should see a 10 degree difference or so.
www.airschooled.com
lil-jinx
lil-jinx is offline
PostPosted: Tue Mar 18, 2025 1:39 pm    Post subject: Re: Pdsit 32/34 fine tune... Reply with quote
at 2000 rpm most of the advance is from the centrifugal advance,you may not see a big drop in timing removing the vacuume,it depends on how open the throttle is,wide open there is very little to no vacuum advance,as throttle closes and the rpm drops then vacumm advance come in play and the weights go to their rest position.when the throttle is fully closed the retard vacuum comes in.
thats how i understand it.
the vacuum timing will behave different under high idle (high rpm with no load) as opposed to the same rpm under heavy load,because the throttle will be more open under load resulting in less vacuum .
1968 Dune Buggy sold dec 2024
1974 parts bus
