Beetle Door Hinge Screw Plug
Loki54
Loki54 is offline
PostPosted: Wed May 07, 2025 3:07 pm    Post subject: Beetle Door Hinge Screw Plug Reply with quote
For late production 1967 Beetles, i.e. March in my car's case, are the door hinge screw plugs white or black?
I'm seeing that only 68 and up have white plugs.
My March 67 production beetle has white plugs, but I'm missing lower plugs on both sides and want to make it correct.
67conv
67conv is offline
PostPosted: Thu May 08, 2025 6:50 am    Post subject: Re: Beetle Door Hinge Screw Plug Reply with quote
The "white" hole caps are actually a clear plastic and usually fade to a light amber / slightly yellow shade after 50+ years. They are the correct choice for your '67. Black is incorrect for 67's, was used on earlier Beetles.
1967 VW Convertible, owned 36 years.
1957 DKW 3=6, owned 22 years.
PREVIOUS: 1972 "Baja Champion SE" Spec. Edition Beetle bought NEW @ Pierce VW in Denver; 1979 Super Beetle Convertible bought NEW @ Downtown LA VW; 1967 type 1 savanna beige; 1967 Porsche 2.0 911S; 1973 Porsche 2.4 911T; 1963 356 T6 B Cabriolet; 1964 356 SC sunroof coupe; 1972 Type-3 Squareback; 1968 + 1969 Type-3 Fastbacks; 1987 Vanagon GL Weekender
Loki54
Loki54 is offline
PostPosted: Thu May 08, 2025 7:30 am    Post subject: Re: Beetle Door Hinge Screw Plug Reply with quote
Great information, thank you!
Would you or anyone else know where to source these clear plastic hole caps in NOS condition?
branston
branston is offline
PostPosted: Thu May 08, 2025 7:47 am    Post subject: Re: Beetle Door Hinge Screw Plug Reply with quote
Lots of new manuafactured ones out there, wolfsburgwets has them amongst orther vendors
NOS ones here:
https://www.thesamba.com/vw/classifieds/detail.php?id=1790423 he's in the Pillipines, but well know on Samba as a seller
67conv
67conv is offline
PostPosted: Thu May 08, 2025 7:54 am    Post subject: Re: Beetle Door Hinge Screw Plug Reply with quote
Aftermarket clear plastic caps are readily available through vendors such as Wolfsburg West and West Coast Metric. However, since they'll be repops, the original "VW" and "Knipping" scripts wont be on them. Depends on if you're doing a bone stock restoration or not, if that will matter to you. Otherwise, you might want to check the Samba classifieds for the 'correct' OEM ones for sale. Be aware that not all of these caps are of the same size diameter. Depends on what hole application they're covering... So, know what you will need in advance.
thomas.
thomas. is offline
PostPosted: Thu May 08, 2025 2:08 pm    Post subject: Re: Beetle Door Hinge Screw Plug Reply with quote
A number of years ago I bought some of these org. German items from this vendor in the Philippines. They have the VW markings on them. Same part number as yours too. I changed all of them at the time so they would all look the same. I bought these around 5 or 10 years ago and it doesn't look like the price has changed.
Loki54
Loki54 is offline
PostPosted: Thu May 08, 2025 2:20 pm    Post subject: Re: Beetle Door Hinge Screw Plug Reply with quote
Thanks I'll try to connect with this vendor and see if they are still available.
