eireann311 Samba Member
Posted: Wed May 14, 2025 2:25 pm Post subject: 1776 Build |
I’ve used the search function, though I’m not seeing anything quite like what I’m having problems with…or I could just be wording it wrong in the search tab.
Built a new 1776 and the engine will not start. I’ve swapped plugs, reset the valves, swapped distributors, swapped coils, rechecked the wiring 100 times, changed grounding points for the battery, swapped plug wires…….still will not start. Engine turns over, it’s getting air and fuel but won’t spark it seems. Used a multimeter and made sure I’ve got power to the coil. I’ve got spark to the distributor, the plugs have spark also. Really at a loss here, if anyone can help? |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4267 Location: San Diego
Posted: Wed May 14, 2025 2:36 pm Post subject: Re: 1776 Build |
| Does it backfire? If so, the distributor drive may be in 180 out. If so, swap 1 and 3 plug wires and swap 2 and 4 |
Posted: Wed May 14, 2025 2:40 pm Post subject: Re: 1776 Build |
| chrisflstf wrote: |
It does pop through the carb |
sled Samba Member
Posted: Wed May 14, 2025 4:26 pm Post subject: Re: 1776 Build |
find top dead center on #1. Then check to see where the rotor is oriented and make sure the plug wires line up accordingly on the cap. _________________ drive your split. |
Posted: Thu May 15, 2025 10:13 am Post subject: Re: 1776 Build |
| Okay swapped everything around, everything looks good. It’s better, now when cranking it wants to start and just doesn’t. Seems like it’s one good spark away from starting… |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2207 Location: Gardnerville, NV
Posted: Thu May 15, 2025 2:33 pm Post subject: Re: 1776 Build |
| eireann311 wrote: |
if you keep struggling with it you may have to consider the cam may be out of sync... I had that happen once when i was younger.... it was two teeth off and would chuff and chuff and act like it wanted to start but wouldnt. I hope thats not the case but its a possibility. _________________ If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4332 Location: Rapid City, South Dakota
Posted: Thu May 15, 2025 2:55 pm Post subject: Re: 1776 Build |
Have you verified you are 100% sure you are on TDC of THE COMPRESSION STROKE? TDC comes around 2 times per cycle.
Pull out the #1 plug, and have someone hold their finger over/in the plug hole while you turn the engine quickly by hand. They will feel the pressure rise as the piston comes up. That is the compression stroke. Once you find that, set the pulley to about 10deg BTDC, and pull off the rotor cap. Turn the dist. till one of the posts is aligned with the rotor, and make that your new #1. Wire up the others, and fire it up.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
Posted: Mon May 26, 2025 8:23 am Post subject: Re: 1776 Build |
| Apologies for the late response, got it fired up and running, thank you for the help. Was 180 out (didn’t even realise it) and just needed a little more timing |
