1776 Build
eireann311
eireann311 is offline
PostPosted: Wed May 14, 2025 2:25 pm    Post subject: 1776 Build Reply with quote
I’ve used the search function, though I’m not seeing anything quite like what I’m having problems with…or I could just be wording it wrong in the search tab.
Built a new 1776 and the engine will not start. I’ve swapped plugs, reset the valves, swapped distributors, swapped coils, rechecked the wiring 100 times, changed grounding points for the battery, swapped plug wires…….still will not start. Engine turns over, it’s getting air and fuel but won’t spark it seems. Used a multimeter and made sure I’ve got power to the coil. I’ve got spark to the distributor, the plugs have spark also. Really at a loss here, if anyone can help?
chrisflstf
chrisflstf is offline
PostPosted: Wed May 14, 2025 2:36 pm    Post subject: Re: 1776 Build Reply with quote
Does it backfire? If so, the distributor drive may be in 180 out. If so, swap 1 and 3 plug wires and swap 2 and 4
eireann311
PostPosted: Wed May 14, 2025 2:40 pm    Post subject: Re: 1776 Build Reply with quote
It does pop through the carb
sled
sled is offline
PostPosted: Wed May 14, 2025 4:26 pm    Post subject: Re: 1776 Build Reply with quote
find top dead center on #1. Then check to see where the rotor is oriented and make sure the plug wires line up accordingly on the cap.
drive your split.
eireann311
PostPosted: Thu May 15, 2025 10:13 am    Post subject: Re: 1776 Build Reply with quote
Okay swapped everything around, everything looks good. It’s better, now when cranking it wants to start and just doesn’t. Seems like it’s one good spark away from starting…
VWporscheGT3
VWporscheGT3 is offline
PostPosted: Thu May 15, 2025 2:33 pm    Post subject: Re: 1776 Build Reply with quote
if you keep struggling with it you may have to consider the cam may be out of sync... I had that happen once when i was younger.... it was two teeth off and would chuff and chuff and act like it wanted to start but wouldnt. I hope thats not the case but its a possibility.
Brian_e Premium Member
Brian_e is offline
PostPosted: Thu May 15, 2025 2:55 pm    Post subject: Re: 1776 Build Reply with quote
Have you verified you are 100% sure you are on TDC of THE COMPRESSION STROKE? TDC comes around 2 times per cycle.
Pull out the #1 plug, and have someone hold their finger over/in the plug hole while you turn the engine quickly by hand. They will feel the pressure rise as the piston comes up. That is the compression stroke. Once you find that, set the pulley to about 10deg BTDC, and pull off the rotor cap. Turn the dist. till one of the posts is aligned with the rotor, and make that your new #1. Wire up the others, and fire it up.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
eireann311
PostPosted: Mon May 26, 2025 8:23 am    Post subject: Re: 1776 Build Reply with quote
Apologies for the late response, got it fired up and running, thank you for the help. Was 180 out (didn’t even realise it) and just needed a little more timing
