Split Bus 14" tires - modern equivalent to 7.00x14
ozark23
ozark23 is offline
PostPosted: Mon Sep 25, 2023 8:18 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
are these the right Grabbers for a 65 DC with 14's?
junichi
junichi is offline
PostPosted: Mon Sep 25, 2023 8:31 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I have those exact ones on my 64 with 14’s and love them.
1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf
ozark23
ozark23 is offline
PostPosted: Mon Sep 25, 2023 8:53 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Are they super loud?
This is my daily
type241
type241 is offline
PostPosted: Mon Sep 25, 2023 10:16 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Who's ad is that above? Seems like a good deal @ $665.
ozark23
ozark23 is offline
PostPosted: Mon Sep 25, 2023 11:04 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Ebay deal
thats what im thinking, great deal especially when i need some new shoes
junichi
junichi is offline
PostPosted: Mon Sep 25, 2023 1:11 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
This is my daily
I don’t find them particularly loud but my bus has no interior and my daily has very noisy Wrangler Duratrac mud terrains. I’d say they’re way quieter than my M/T’s.
ezcamper
ezcamper is offline
PostPosted: Mon Oct 02, 2023 10:14 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I may get these... D rated, 8 ply. 195R14
https://www.ebay.com/itm/355059803150?_trkparms=am...p_homepage
I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks
CinnabarVan
CinnabarVan is offline
PostPosted: Mon Nov 27, 2023 1:06 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
hey gang,
Wondering if the following tire size will fit on my stock 66 DeLuxe. Any advice appreciated.
Thanks,
Hankook Kinergy ST
215/75 R14 100T tires $107 at the Tire Rack
https://www.tirerack.com/tires/tires.jsp?tireMake=...mpare1=yes
Chuey
Chuey is offline
PostPosted: Mon Nov 27, 2023 3:02 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I have stock 14" rims on my 66 camper and 215 tires on the front and 225 on the rear. No interference at either end.
Chuey
BonTonRoulet
BonTonRoulet is offline
PostPosted: Mon Nov 27, 2023 4:05 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
CinnabarVan wrote:
hey gang,
Thanks,
Hankook Kinergy ST
I think you'll find those tires to be mushy like marshmallows and your bus would be all over the road in cross winds and getting passed by larger trucks. Spend a few more bucks and go with the Hankook Vantra LT (Light Truck) RA18's with stiffer sidewalls you'll be happy you did.
Good Luck!
Never argue with an Idiot. They'll only bring you down to their level and beat you with experience.
obus Premium Member
obus is offline
PostPosted: Sat Aug 24, 2024 6:48 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
will these work on standard 14 inch 66 bus rims? Load index ok?
https://www.tiremart.com/vee-rubber-marathon-evo-1...f4QAvD_BwE
cdennisg
cdennisg is offline
PostPosted: Sat Aug 24, 2024 6:53 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Will they fit? Yes. Is the load index OK? Yes. Are they good tires? Maybe...
robin.richard
robin.richard is offline
PostPosted: Mon Jan 06, 2025 9:24 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Unfortunately looking for new tires to replace my worn Hankook RA08 195R14C tires I’ve been running for many miles now. Boy tire prices have increased since I last bought tires. I was very pleased with the RA08s and I am considering replacing them with the new 195R14 RA18, especially with the D1 load rating.
I just want to make sure these are the same size as the RA08s since they don’t list a middle number (Europe standard way of listing tires?) . It’s causing some confusion at the tire shops.
Is the RA18 195R14 close to the original 7.00x14 tires? Perhaps just slightly wider?
Also considering, although more expensive, a set of General Grabbers A/TX LT 27x8.50R14 C tires. Not sure if I really need them since I spend 95% on the highway here in the East.
-Rich
Drive your bus!
cdennisg
cdennisg is offline
PostPosted: Mon Jan 06, 2025 9:56 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
-Rich
When no aspect ratio is listed, it is @ 82. Can do the math from there. An old tire shop guy would know this, but lots of younger guys have likely never seen it come up.
Buskraut Premium Member
Buskraut is offline
PostPosted: Mon Jan 06, 2025 6:43 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
I just ordered a set of the Yokohama Y356 LT195/75R14 (D load rating) for my 14 inch stock rims. I was looking at both the Yokos and Hankook Vantras, which seem very similar... several supplier list the Hankooks as also being LT195/75R14. From comments I have read, this size seems to fit, wear and handle well on our busses, and least in non-icy environments.
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
matthew henricks
matthew henricks is offline
PostPosted: Wed May 14, 2025 4:08 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Anyone have pictures of their bus with Yokahama Y356 185R14 tires? Needing to replace my tires and those seem affordable and close to the bias ply stock tire diameter.
Found a few images in the gallery of the tire mounted but none of a bus far enough away to see the stance.
Image below from @barryL
1964 Original Owner build Thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=702135&highlight=
Ambulance Fan's. https://www.thesamba.com/vw/forum/viewtopic.php?t=627707&highlight=
Parts i am looking for:
64 bug nice used front/rear Black LHD floor mat.
BarryL Premium Member
BarryL is offline
PostPosted: Wed May 14, 2025 6:15 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Here's a couple from farther away showing stance and size as you requested.
Basically stock.
matthew henricks
PostPosted: Thu May 15, 2025 7:14 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Thank you Barry!
von_hansel Premium Member
von_hansel is offline
PostPosted: Thu May 15, 2025 9:36 am    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
oldbusboy wrote:
I'm planning on buying bias ply tires for my '67.
https://www.cokertire.com/700-14-bf-goodrich-1-whitewall-tire.html
It says the ratings are:
Brand: BF Goodrich
GTIN UPC: 00842199104882
Product Size: 700-14
Rim Diameter: 14
Tread Width: 4.40
Section Width (Actual): 7.20
Overall Diameter: 26.80
Max Load Capacity: 1360@32PSI
Recommended Rim Width: 5.00 - 5.50
Tube Type or Tubeless: Tubeless
There is no specific mention of LT.. or ply rating.
Should a assume these will work?
Trevor
Has anyone bought this tire?
I'm considering purchasing this BFGoodrich tire (without the whitewall) for my bus, specifically for use as a spare tire. Since it will primarily be for emergency use, daily usage and versatility isn't my main concern.
If any of you have bought this particular tire, I would be very grateful if you could:
-Share a picture or two of the tire mounted on your bus.
-Let me know your general thoughts on the tire.
Mugatu wrote:
mandraks
mandraks is offline
PostPosted: Fri May 16, 2025 8:03 pm    Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 Reply with quote
Basically stock.
Barry 185/14 may be stock replacement, but they are definitely much smaller in diameter compared to a 7.00/14. I remember back when i worked for a tire manufacturer just how much smaller they are compared to 7.00/14s. same thing with the 6.40/15 or 5.60/15 on the beetles. huge difference in diameter.
people did like the radials, of course, because they last longer, and they make you think your bus is faster and uses less gas per mile indicated. it just takes longer to get places and distances are suddenly longer....
regards
Uli
Page 7 of 8
