Chootrain470 Samba Member
Joined: March 01, 2023 Posts: 149 Location: Simi Valley, CA
Posted: Thu May 15, 2025 12:32 pm Post subject: Vanagon Drum Brake Adjusters |
I am rebuilding my rear drum brakes and have a question about the orientation of the automatic adjusters. I currently have the skinny side out and the beveled side out. Is this correct?
VicVan Samba Member
Joined: July 01, 2015 Posts: 1936 Location: Vancouver Island, BC
Posted: Thu May 15, 2025 1:07 pm Post subject: Re: Vanagon Drum Brake Adjusters |
There are good pictures, and answers to your questions, in the FAQ if I remember correctly. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
SCM Samba Member
Joined: January 26, 2011 Posts: 3365 Location: Bozeman MT
Posted: Thu May 15, 2025 1:18 pm Post subject: Re: Vanagon Drum Brake Adjusters |
VicVan wrote: |
There are good pictures, and answers to your questions, in the FAQ if I remember correctly. |
Yeah but unfortunately a lot of photos are no longer visible and there's a search for "vanagon brake adjuster + thesamba" returns some unrelated and maybe even unreliable info.
Here's a starting point for your searching https://www.thesamba.com/vw/forum/viewtopic.php?t=655319&start=0 _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Thu May 15, 2025 1:27 pm Post subject: Re: Vanagon Drum Brake Adjusters |
Looking at photos, I am fairly certain that the skinny side, facing the rear of the van, of the adjuster faces out.
The end towards the front of the van is unclear. I have seen some photos with the bevel side out and some with it in. I'm not sure if its critical. |
Posted: Thu May 15, 2025 4:19 pm Post subject: Re: Vanagon Drum Brake Adjusters |
https://youtu.be/b6H7QZicAyI?si=zro-CabubpMsdYEw
I found this video that goes into detail. I believe my current setup is wrong but at least I have only done one brake so far. |
do.dah Samba Member
Joined: August 27, 2015 Posts: 795 Location: Washington
Posted: Fri May 16, 2025 2:56 pm Post subject: Re: Vanagon Drum Brake Adjusters |
I was able to take my drum off again and fix this yesterday. Thanks. |
