BarryL  Samba Member
Joined: November 01, 2004 Posts: 15484 Location: Casa de Oro, California
Posted: Sat May 17, 2025 6:14 pm Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
| Yes. When I first got my Standard it had 7 X 14s. It was squirrelier and they wore out super fast. But the spare tire well hits the holding lug hole for both sizes in the same place. |
DanM Samba Member
Joined: June 07, 2002 Posts: 1389 Location: Falls Church, VA
Posted: Sun May 18, 2025 9:38 am Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
I haven't seen anyone mention these in this thread, but I like the Maxxis UE-168 Bravo. They're radial with the right weight / ply rating and the 205/0R14 gets you the 27" diameter of a bias ply 700-14 with a little more meat, but nothing crazy.
https://www.maxxis.com/us/tire/bravo-series-ue-168/ |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20993 Location: Sandpoint, ID
Posted: Sun May 18, 2025 4:37 pm Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
| DanM wrote: |
That 205R14 C is an interesting size. I bet it would fit well on a bus meant for on road use. Or use as a steer tire combined with something a bit more rugged out back. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
ted698 Samba Member
Joined: June 17, 2016 Posts: 153 Location: Shropshire, UK
Posted: Mon May 19, 2025 8:03 am Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
I run 205R14C's on my UK bus, to max out the gearing with tyre size, although these only really bring it back up to the 27" diameter that the OG crossplies were... some of the modern radials are comically small, so the final gearing is all over the place.
I use Mazzini EffiVan - as they are a 'van' tyre they seem OK, and they're pretty cheap!
https://www.camskill.co.uk/m90b0s1673p181391/Mazzi...se%3A_72dB
Not sure if these are available in the States? |
BarryL  Samba Member
Posted: Tue May 20, 2025 6:44 pm Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
| mandraks wrote: |
| BarryL wrote: |
Here's a couple from farther away showing stance and size as you requested.
Basically stock.
Barry 185/14 may be stock replacement, but they are definitely much smaller in diameter compared to a 7.00/14. I remember back when i worked for a tire manufacturer just how much smaller they are compared to 7.00/14s. same thing with the 6.40/15 or 5.60/15 on the beetles. huge difference in diameter.
people did like the radials, of course, because they last longer, and they make you think your bus is faster and uses less gas per mile indicated. it just takes longer to get places and distances are suddenly longer.... |
I did the math:
184/ 14" go around one rotation 790 times in a mile.
7.00X14" go around one rotation 747 times in a mile. |
Posted: Tue May 20, 2025 7:48 pm Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
| BarryL wrote: |
| mandraks wrote: |
| BarryL wrote: |
Basically stock.
I did the math:
And that math is variable. Different manufacturers build tires differently, and actual size/width/diameter will vary. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19915 Location: Land of Whine and Phonies
Posted: Wed May 21, 2025 6:46 am Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
I run these on all of my buses.
https://www.ebay.com/itm/382651774165 _________________ Your Vanagon sucks, Stop waving at me.
| HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
BarryL  Samba Member
Posted: Wed May 21, 2025 12:02 pm Post subject: Re: Split Bus 14" tires - modern equivalent to 7.00x14 |
I was going by the 185/R/14 s in this chart vs the 27" ones commented on.
Now that you guys pointed out the size when I look at my bus I feel the 25.5" diameter tires have diameter envy. |
