What did you do for your Bus today?
Page: Previous  1, 2, 3 ... 686, 687, 688, 689  Next
thom
thom is offline
PostPosted: Sat May 17, 2025 4:01 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
I had the dash ashtray re-chromed, and it looked awesome, but all of the tabs broke off when I tried to re-attach it (probably hydrogen embrittlement), so I glued it with Marine PC-11 epoxy
-Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type
BarryL Premium Member
BarryL is offline
PostPosted: Sat May 17, 2025 6:40 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
You glued the chrome lid to the ash holder? Or you glued the assembled ashtray to the painted dash?
thom
thom is offline
PostPosted: Sat May 17, 2025 6:49 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
I glued the lid to the ashtray
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Sun May 18, 2025 10:28 am    Post subject: Re: What did you do for your Bus today? Reply with quote
I polished and installed the rocker trims, and the WCM trim insert matches my paint perfectly
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Buskraut Premium Member
Buskraut is offline
PostPosted: Sun May 18, 2025 5:26 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Thom,
Your trim came out awesome... I'm just getting ready to do mine. Can you share your technique?
Also, sources for chroming are becoming far and few between... who did you use?
Thanks!
Erik S
'65 Type 251 / Deluxe
'03 Eurovan MVWK
thom
thom is offline
PostPosted: Sun May 18, 2025 7:37 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
I bought a bench polisher on amazon, a couple of wheels, and went to town. There's lots of online resources for this. I bought a two-speed unit, which was a good idea in hindsight, as it's easier to handle the smaller pieces at the lower speed.
I used Sherm's plating here in Sacramento. I've also used Ogden chrome in Utah, which specializes in 'mail order' chrome plating, but you really have to be on them about the quality. They destroyed a set of Type 34 door handles; luckily I had a spare set and they re-chromed those for free.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Buskraut is offline
PostPosted: Sun May 18, 2025 8:02 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Thanks. I've got a variable speed HF grinder/buffer and various buffing wheels and compounds I've been experimenting with, but I'm not super happy with the results yet. I need a process aggressive enough to remove some light pitting, and then work my way up to the beautiful shine you have.
Erik S
'03 Eurovan MVWK
perello
perello is offline
PostPosted: Mon May 19, 2025 1:34 am    Post subject: Re: What did you do for your Bus today? Reply with quote
blinded the heat riser holes
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
thom
thom is offline
PostPosted: Tue May 20, 2025 9:29 am    Post subject: Re: What did you do for your Bus today? Reply with quote
You're probably better off wet-sanding with a progression of 400/600/800/1000/1500 to handle the pitting. Start with the higher grit, if it's not working, then move down a grit until you start seeing results, then work back up. Rotary buffing is not going to remove pits unless you use a very aggressive compound. Remember, you're ultimately removing material to smooth out the pits.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
ComfortablyNumb
ComfortablyNumb is offline
PostPosted: Tue May 20, 2025 9:35 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Today I ordered a Vintage Speed exhaust, a hitch from Jeremy Hoggard, and a new fuel tank and wiring harness from Wolfburg West. Good thing my bus is a camper because when the Visa bill comes in my wife will make me go live in it!
I still need to order a fuel pump, fuel line, and a German shroud and tin so I can get it back together and running. Also need to either get the carbs rebuilt or replaced as I suspect they, or at least one of them, was the cause of my troubles.
Buskraut is offline
PostPosted: Tue May 20, 2025 9:53 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Glued some vinyl on the rear quarter panel. Yeah, yeah, I know stock was painted, but IMHO the vinyl looks good and should wear well. Went overboard on the clamps because I hate puffy edges. Next is to add some piping.
Erik S
'03 Eurovan MVWK
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Wed May 21, 2025 3:33 am    Post subject: Re: What did you do for your Bus today? Reply with quote
For me it's more like "What did your bus do for you today?". I used my repro ladder on my bus to help me store my 16' DN iceboat mast and the plank to the rafters in my garage. Little did I know I overworked my crappy knee and needed lots of fluid drained yesterday.
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
melville
melville is offline
PostPosted: Wed May 21, 2025 8:23 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Tell me about your Airhead! Is that an R100R?
2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan
Pau
Pau is offline
PostPosted: Wed May 21, 2025 10:10 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Pau wrote:
Good morning.
I attacked the front nose again. Last time:
Pau wrote:
in one hour I did only the right corner of the nose.
I keep on going.
Cheers.
Yesterday I spent three hours and I was quite satisfied with the result. The day before I spent almost the same time for passenger's door (only the white paint!!).
Gowing forward.
Have a nice day.
Freedom for the Catalan Countries
Si ens destrossen les contrades alçarem les barricades !!*!!
thom
thom is offline
PostPosted: Tue Jun 03, 2025 9:18 am    Post subject: Re: What did you do for your Bus today? Reply with quote
My 1957 deluxe's original rebuilt and first run-in. It's a little noisy, so I'm going to re-adjust the valves this afternoon. I still need to build a new carb; I put a bug air cleaner on it because that's what I had at-hand - need to clean up and re-paint a bus air cleaner.
AA 80mm pistons and cylinders
AA H-beam rods
Wolfsburg West high-performance cam
019 distributor with Pertronix ignition
Vintage Speed muffler
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
PostPosted: Thu Jun 05, 2025 3:09 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Sweet, I like your starting switch too.
AA H-beam rods
Lind wrote:
thom
thom is offline
PostPosted: Mon Jun 09, 2025 7:14 am    Post subject: Re: What did you do for your Bus today? Reply with quote
More random assembly
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
thom
thom is offline
PostPosted: Mon Jun 09, 2025 7:15 am    Post subject: Re: What did you do for your Bus today? Reply with quote
I should stick to commercial models: all of these deluxe bits are a PITA. I spent 4 hours yesterday getting the rear bumper to this point, and I probably have a couple more hours to go.
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
BarryL is offline
PostPosted: Thu Jun 12, 2025 6:06 pm    Post subject: Re: What did you do for your Bus today? Reply with quote
Inventory some guts.
thom
thom is offline
PostPosted: Sat Jun 14, 2025 8:40 am    Post subject: Re: What did you do for your Bus today? Reply with quote
Drove it for the first time today
-Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type
Page 687 of 689
