SGKent  Samba Member
Joined: October 30, 2007 Posts: 43002 Location: at the beach in Northern Wokistan
Posted: Wed May 21, 2025 10:41 am Post subject: oil 5 years |
Thought I would share this tidbit. Lake Speed Jr has a youtube channel named The Motor Oil Geek. He is the son of Lake Speed, the NASCAR driver. Probably some here have watched his youtubes. He is a specialist in motor oils. I was up late last night just unwinding, and caught one I found quite interesting.
Old motor oil does go bad. His suggestion is to not use motor oil that has been sitting for more than 5 years because the additives come out of suspension and the oil often goes go bad. He opened up some 10 and 20 year old bottles of both engine oil, and gear oil sitting around his dad's shop after he retired from NASCAR and go-cart racing about 10- 20 years ago. All that he opened had gone bad from sitting - even oils that he thought would not have done so. I guess for me, now I have to check dates on the engine oil and gear oil I have sitting around the garage, and then check them out. Many are going to be over 5 years because I often buy them by the case. That is a bummer.
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23594 Location: Oklahoma City
Posted: Wed May 21, 2025 11:03 am Post subject: Re: oil 5 years |
| SGKent wrote: |
Yes! I watch his videos all the time. Great stuff!
This is the kind of chemistry issues I try to bring to peoples thought process all the time.
Most people think rubber and plastic are just inert...waterproof...stable. They think oils and petroleums are stable too but all of these are "compounds" brought together with various combinations of heat, pressure and chemical reactions.
The metals and minerals in them oxidize...some through just time, some through contract with minerals and metals of opposite polarity or PH etc. etc.
Some of my first technical exposure to this level/type of oxidization.....was in the printing industry at the commercial print level. Working in quality control, I ran the accelerated fading/weathering units, the real time weathering farm on the roof and the controlled environment dark storage testing.
I learned that certain colors can change radically in pitch dark at stable room tempereatureand humidity simply because their mineral based pigments oxidize from entrained oxygen.
Likewise, because people do not understand that the pigments in many paints are mineral or metal based (some are plastic which are resin based).....colors change under light, heat, UV light and just with time.
and is also why I quit commenting on questions in the forums of.... "can I get a paint match for L-XXX". Too many people think its just follow a formula and you get a color.
The breakdown of oil over time.....might oxidization or sometimes just decomposition and stratification....or a combination of the two.....is also very similar to the changes in rubber products over time.
After a certain point in time in my career...really about 15 years ago, I found out that grease really does change/oxidize....so ijust assumed that motor oil also MUST have some shelf life limit but just could never prove it in my line of work. I am glad Lake Speed did this.
Ray |
SGKent  Samba Member
Posted: Thu May 22, 2025 1:12 am Post subject: Re: oil 5 years |
I followed up watching his scientific study of old vs new oil and was stunned. No way am I buying oil in cases anymore and keeping it around. The stuff is best new and it goes bad with time. Like really bad.
George Carlin:
1971 deluxe (sold)
1977 deluxe |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5980 Location: Los Alamos, New Mexico, USA
Posted: Thu May 22, 2025 6:36 am Post subject: Re: oil 5 years |
Like old tires. I am having to replace all the tires on my pickups, even the unused spares, with new since I realized that they were all 10 years old, or nearly so. I drives my neighbor crazy, since he uses old tires on his trailer that are clearly cracked and failing in my view. I see it as a safety issue, as much for your own ride or trailer as to others on the road. I have been nearly hit by tires blowing out on other vehicles.
Old tires are bad news. And oil only good for 5 years? I had never thought of that.
So, I am also taking the opportunity to repaint all my rims! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2813 Location: Plattsburgh, New York
Posted: Thu May 22, 2025 6:47 am Post subject: Re: oil 5 years |
| jtauxe wrote: |
So, I am also taking the opportunity to repaint all my rims! |
My tires are 20 years old and I’m replacing them. I ran them until I saw cracks between the treads on one. When I first got my bus, the tires had good treads but were old and dried out. I had a good old fashioned blowout on the Pierre Laporte bridge in Quebec City and soon after a front tire with a separating belt. It shook the whole bus and felt like I was driving on a square wheel. Never thought about oil going bad in the bottle. Lots of stuff on my shelf like paint that I thought I bout 2 years ago, but often it’s more like 12. |
Posted: Thu May 22, 2025 12:03 pm Post subject: Re: oil 5 years |
Comparing as SF oil to an SP oil is pretty pointless. New and fresh out of the bottle the wear with an SF oil might well have been 10-20 times a great as with an SP oil. We're are talking about an oil that was over 40 years old when this video was made. Lots has changed since then, a house brand oil today would give you noticeably better performance than a top of the line oil would have 40 years ago, so I would not expect a forty year oil oil to have aged well compared to how a newer oil would age, especially one that is expected to be capable of going 15-25,000 miles. The ZDDP molecules in today's oils are far more stable than the ZDDP molecules of yore, which is why manufactures have been able to drop the concentration of ZDDP over the last few years and still get superior anti-wear performance.
I know that for my high mileage 1800 which I rebuilt in the summer of 1990 when it got torn down 250,000 miles later there was essentially zero cylinder taper and the cross hatching was still visible at the top of the ring travel where wear is the greatest, the cross hatch at the top of the ring travel was renewed in just seconds with a bar hone. This engine got semiannual oil changes (~6000 mile) with 10w30 in the winter and 30wt during the summer for the first half of its life, and then got semi annual oil changes running thinner synthetics every 20-25,000 miles for the second half of its life.
I really doubt that an SN oil would age significantly in even ten years, but by the time it is tens years old, better oils will be on the shelves at the FLAPS.
As for shaking oil, heat the bottles in a water bath to 180°F+ before pouring it into the engine and let the bottles drain well and you should get next to nothing left laying in the bottom of the bottles. |
SGKent  Samba Member
Posted: Thu May 22, 2025 12:10 pm Post subject: Re: oil 5 years |
| Wildthings wrote: |
The second video is quite definitive that old oil fails miserably at protecting bearing. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
jlrftype7 Samba Member
Posted: Thu May 22, 2025 2:02 pm Post subject: Re: oil 5 years |
Haven't watched the videos YET, but will. Wonder if non-detergent oil like I use for my Commerical Grade Air Compressor in my shop suffers the same fate sitting in a bottle on the shelf year after year. ???
What do you think, SGKent, having watched the Videos??  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
SGKent  Samba Member
Posted: Thu May 22, 2025 2:15 pm Post subject: Re: oil 5 years |
| jlrftype7 wrote: |
What do you think, SGKent, having watched the Videos??  |
There are still additives in it and from what the video shows, and it was a lab test, the anti-foaming properties go away, and the oil also oxidizes so it looses lubrication ability for running on an engine bearing.
I had one bearing on my last rebuild that had some spalling on the bearing surface of #2 rod. Now I know why, I had been using 15 year old Brad Penn I bought in case form. If it foams, the air concentrates and ejects out rod bearing #2. So I am sending all my engine oil and transmission oil over 5 years old to HHW. Just not worth the risk. Watch the second video. To be candid, some of the awful results on old oil even caught Lake off guard. The oxidization chemicals in all the old oils were burned out. The anti-foaming additives were used up. It doesn't matter what S number the oil has. Even 30 - 40 years ago anti-oxidization and anti-foaming additives were added to oil whether multi or single grade, whether detergent or non-detergent. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Thu May 22, 2025 3:30 pm Post subject: Re: oil 5 years |
| SGKent wrote: |
| The second video is quite definitive that old oil fails miserably at protecting bearing. |
One of his samples was for an SF oil from the mid to late 1970s so rather pointless to use for comparison, if he dated the other "old" oil samples I failed to note what dates they were. In my mind to be meaningful he need to make comparisons to oils people are much more apt to have in the back of their cabinets. Like a half case of SM oils with no SN rating which can be as old as 2004 or 21 years old, but there again those oils had the earlier ZDDP formulas that are well know to cause problems. Even the SN rating goes back to 2011 if my sources are correct so that is 14 years at this point, so I would guess the oldest oil I have has a SN rating.
https://www.onallcylinders.com/2019/03/26/video-api-oil-ratings-mean/
If I am in the middle of Nevada, have a bad oil leak, and am two quarts low on oil and someone offers my a half case of SD oil from 1970, you can bet I will run it versus head on up the road with the oil not reaching the stick. |
SGKent  Samba Member
Posted: Thu May 22, 2025 3:49 pm Post subject: Re: oil 5 years |
| Wildthings wrote: |
| SGKent wrote: |
I don't get two quarts low or overfill my engines. And when I need oil at a stop for gas, I carry extra just for that type situation.  _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Thu May 22, 2025 4:03 pm Post subject: Re: oil 5 years |
| SGKent wrote: |
| Wildthings wrote: |
| SGKent wrote: |
I don't get two quarts low or overfill my engines. And when I need oil at a stop for gas, I carry extra just for that type situation.  |
I am realist and understand that Murphy's Law applies to all. I have had oil pans ripped openm (this was a chewing gum repair) and old filters slashed out in the boonies and have limp onward with whatever oil I could get, once even had a transfer case fall apart, so we borrowed bolts form other place on the rig and filled the transfer case with water to get us moving again and made it an hour's+ drive to where we could get oil, this wasn't my rig, but I don't remember that the owner ever had problems with the rig. |
SGKent  Samba Member
Posted: Thu May 22, 2025 4:07 pm Post subject: Re: oil 5 years |
| Wildthings wrote: |
| SGKent wrote: |
| Wildthings wrote: |
| SGKent wrote: |
Would you not see an emergency repair differently than everyday maintenance? I don't see how the two events can be equated. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24522 Location: NYC/Upstate/ROW
Posted: Thu May 22, 2025 4:57 pm Post subject: Re: oil 5 years |
Equivalence of analogies to generate internet arguments is an art form. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Thu May 22, 2025 5:27 pm Post subject: Re: oil 5 years |
It does not matter if it's SF or SD...old or new. It does not matter if it's grease or oil...Dino or synthetic.
These are ALL COMPOUNDS.....with metals, some of which are electrolytically active and minerals....and oxygen. They all age and they all oxidize and they all change.
In fact, there is not one long term stable compound on this planet that contains zinc. If you wanted to just single out one component that everyone can recognize.....it's zinc. It starts reacting the day it's pulled out of the ground.
Even unopened brake fluid starts oxidizing enough to have measurable change at around 2 years. Shelflife for most brake fluid unopened is ~5 years.
One might ask what is changing. It's the glycol ether and or propylene glycol. We use the same raw materials as solvents in my industry and we consistently can measure the differen e in old 5 gallon cans of propylene glycol monobutyl ether. It changes color, PH, Baum density and strength.
There is no doubt in my mind that every single automotive chemical or lubricant we use degrades over time.
The only question is how much is too much.
Ray |
Posted: Thu May 22, 2025 5:45 pm Post subject: Re: oil 5 years |
| SGKent wrote: |
| Would you not see an emergency repair differently than everyday maintenance? I don't see how the two events can be equated. |
Never said otherwise, but I see the linked site and many others as trying to make a mountain out of a mole hill, which is the substance of way too many oil arguments.
Years ago I bought four drums of a different brand of motor oil from what we had been using, this was not my decision, but a decision made by someone above me telling me to do so. When we got the oil samplings back after the first oil changes it showed high copper in the oil and stated that they believe the copper was likely coming from the oil cooler. I decided to just pass the oil on to the logging crew that worked for the company for use as bar oil but the head of the logging crew would not use it because he was afraid to use an oil on his chainsaw bar that we wouldn't run in the diesels. I lost the argument and decided to just give the oil away to one of my mechanics who had a side business doing oil changes and went back to using the oil we had previously been buying. I don't see much difference between that incident and this one. By far the main reason people lose engines as a result of a lubrication problem is there is not enough in the crankcase due to one reason or the other, while almost no one loses an engine due to using a few bottles of old oil. Discourage someone with low crankcase oil to just keep driving because the only oil available to them has been sitting on the self a long time may cause them them to lose an engine. |
SGKent  Samba Member
Posted: Thu May 22, 2025 9:53 pm Post subject: Re: oil 5 years |
Mike - you are more than welcome to my old oil when I get time to check the production dates. Just pay for the shipping. I don't want an oxidized oil that froths up and sends a soup of air and oil to the bearings. We tossed enough connecting rods racing to know how expensive it is when it happens. Back in those days I was lucky to be able to afford an oil change for my bus, let alone buy a case and store the excess, so it never occurred to me oil had a finite shelf life - other than using it as bar chain oil or for squeaky hinges etc.. I bought it and used it right away. I just don't want something that is going to cause a bearing failure.
I kept asking myself when I tore this engine down in 2022 - what caused the spalling in new low mile bearings? It did not happen back with the 2010 engine and same components. It never happened on the type 1 motors - and I pushed that engine far harder than this type 4. Got my answer in Lake's video. Old frothy oil left over from the case I bought in 2009 - 2010. Those craters are hot spots where the froth did not properly lubricate. #3 rod was the worst. #2 and #3 rod journals are always where the air collects and ejects out in most crankshafts. By the time it gets to number 4 the air is usually gone. #2 is the worst but the oil is cooler. Some of the tiny pieces then carried down line to #4. I also don't want my lifters and cam lobes to wear excessively faster than they already do either.
These bearing had a 20 minute break in on them, and maybe 10 miles. I got my answer - they got hot from the frothy oil. Stupid ass me also tried your advice to overfill the sump to get better cooling but that would have made it worse because it churns the oil more. Must have looked like whipped egg whites in that case when the engine was running with 11 - 12 year old oil. I do not want any oil that is more than 3 - 5 years old and most of what I have is probably 8 - 12 years old.
#3 rod
#4 rod
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Thu May 22, 2025 11:37 pm Post subject: Re: oil 5 years |
SLicks oil change service
Take the oil from low mileage car #1 and use it in customer #2
Charge customer 1 for both the oil and a recycle fee.
Charge customer 2 for the oil change and a green carbon credit surcharge, and disposal fee.
Spray paint Fram filters black and label them OEM brand. Invoice accordingly.
Dont forget to add shop supplies and a DEI tax. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
SGKent  Samba Member
Posted: Fri May 23, 2025 9:15 am Post subject: Re: oil 5 years |
| Abscate wrote: |
Dont forget to add shop supplies and a DEI tax. |
You've lived in NY too long. It has affected your thinking. Time for a nice stay at a quiet beach. Stay away from the one where I buried my treasure. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Fri May 23, 2025 10:12 am Post subject: Re: oil 5 years |
If this producer of this video wanted to produce a worthwhile video, he would have chosen to use a two eleven year old oils, and two 6 year old oils of the same brand and then two newly manufactured oils again of the same brand. For all we know the SE and SF oils he tested are acting 100% factory normal and have little deterioration with time, and all he is proving is that SE and SF oils were junk compared to today's oil. I mentioned above that the circa 1990 rebuilt 1800 that was in my bus and lasted 250K miles, it didn't die from a lubrication problem but due to cracks in one of the original heads that had either 370 or 420K miles on them total since new. This engine would have always run an SG oil or newer, and had unmeasureable taper to the cylinders.
I also have an 1800 that came out of a 1974 Type 4 car and it was last run in 1995 or earlier, so assuming it got 15K miles a year on it, it had at most 315K miles on it. The cylinders had a huge 0.015" of taper. This engine would have most likely run SE and SF oils over most of it's life and maybe an oil change or two of SG oils.
Unless someone is an idiot and just wants to believe everything automotive from the 1970s was better than anything made since (which sadly a lot of people seem to do even though they own and drive far new cars that they seldom as much as check the oil on), then no one should be searching out oils of that era thinking that they are somehow better or even equal to today's oils.
I don't buy the shaking the oil thing like he did as it would be worthless, just heat the oil to 180°F and pour it in, letting it drain well and let the engine do the mixing. Shaking the bottle or can when its 3/4 empty might help get something sitting in the bottom of the container to move and drain, don't know. You might use a chop stick or something to loosen something stubborn in the bottom of the container.
He proved nothing about how a ten or even 20 year old SJ or SL oil ages, because these are not what he tested, even though these are the oils that an old car enthusiast would be most likely to search out a case of and use. |
