floor vent covers
freekazoid
freekazoid is offline
PostPosted: Wed Apr 18, 2007 3:40 am    Post subject: floor vent covers Reply with quote
Does anybody know where I can get some front floor vent covers for my '70? I don't suppose the beetle ones are the same are they?
70 140
70 140 is offline
PostPosted: Wed Apr 18, 2007 6:13 am    Post subject: Reply with quote
Find someone parting a car out. They should come with the cable and levers as well - to open and close the vents.
Gary
Person of Interest
Gary is offline
PostPosted: Wed Apr 18, 2007 6:23 am    Post subject: Reply with quote
70 floor vents don't have cables. They are operated by hand with a direct lever on the vent.
And no, they aren't the same as Beetle vents. IIRC, the cable vents started in 1973.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Ghiaddict
Ghiaddict is offline
PostPosted: Thu Apr 19, 2007 6:40 am    Post subject: Reply with quote
A point of clarification:
1969 & 1970 floor vents do originally have cables, with the
operating lever mounted high up on the corner underdash kick panels.
1972-1974 floor vents have the cable to the heater control knobs/levers.
Karmann Ghia & Beetle parts available.
Convertible tops installed.
Achilles3588
Achilles3588 is offline
PostPosted: Thu Apr 19, 2007 7:09 am    Post subject: Reply with quote
bfy obsolete parts might also have them, used IIRC.
Larry V.~
'91 Syncro Doka 1.9L TDI 'AFN'
Gary
Person of Interest
Gary is offline
PostPosted: Thu Apr 19, 2007 8:30 am    Post subject: Reply with quote
Are you sure about 1969? IIRC, a 69 I parted out had the hand lever operated vents. I even remember seeing a friend's 70 with them. Perhaps it was a retrofit?
Ghiaddict
PostPosted: Thu Apr 19, 2007 8:39 am    Post subject: Reply with quote
Yes, I'm sure.
But sometimes you see the cables eliminated
by a PO and they just install a knob at the floor vents,
or they swap out the plastic covers to some with handles/knobs.
Here's a pic, 1969 KG convertible, underdash levers, cables
properly hidden behind kick panel carpeting:
ghiajake
ghiajake is offline
PostPosted: Mon Oct 13, 2014 6:01 pm    Post subject: Reply with quote
I had a hard time figuring where the cables/levers routed, so thought I would share. Neither end of the cable is adjustable, so you need to "dry fit" it before it's hidden behind carpet.
dingerjunkie
dingerjunkie is offline
PostPosted: Wed May 28, 2025 6:26 am    Post subject: Re: floor vent covers Reply with quote
Question on the "grey-zone" year. Mine is an early '71 coupe, as it still has the 70-style dash/defrost vent configuration. It came with the heater channels bare. Cables or on-cover knobs?
modoc_333
modoc_333 is offline
PostPosted: Wed May 28, 2025 6:44 pm    Post subject: Re: floor vent covers Reply with quote
My 71 coupe is the no cable type. Built in late 70
Steelz21
Steelz21 is offline
PostPosted: Sun Jun 08, 2025 9:10 am    Post subject: Re: floor vent covers Reply with quote
My 71 convertible has no cables, I used super beetle vents.
Steelz21
Steelz21 is offline
PostPosted: Sun Jun 08, 2025 9:13 am    Post subject: Re: floor vent covers Reply with quote
Heiferman
Heiferman is offline
PostPosted: Mon Jun 09, 2025 2:30 am    Post subject: Re: floor vent covers Reply with quote
I am curious about this. Above Gary said they were different. You had no problem with fitment?
I have a 1970 and it has cables but they are pretty trashed so I was considering just putting in non-cable Beetle ones if they fit. I am not too worried about correctness.
- 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance
Steelz21
Steelz21 is offline
PostPosted: Mon Jun 09, 2025 10:39 am    Post subject: Re: floor vent covers Reply with quote
They popped in with very little drama, and do a great job of directing the warm air.
I will dig through all my CIP.1 invoices and get the part number I used.
Steelz21
Steelz21 is offline
PostPosted: Mon Jun 09, 2025 10:58 am    Post subject: Re: floor vent covers Reply with quote
From CIP.1
FLOOR H/VENTS L/R PR T1 67-79
VWC 111-898-189-APR $69.99 CDN ( a couple of years ago now)
Tariff 8708.29.5060
I hope this helps.
Steelz21
Steelz21 is offline
PostPosted: Mon Jun 09, 2025 1:15 pm    Post subject: Re: floor vent covers Reply with quote
Oops. I forgot to attach this.
Steelz21
Steelz21 is offline
PostPosted: Mon Jun 09, 2025 1:16 pm    Post subject: Re: floor vent covers Reply with quote
Heiferman
PostPosted: Mon Jun 09, 2025 4:23 pm    Post subject: Re: floor vent covers Reply with quote
Steelz21 wrote:
From CIP.1
Tariff 8708.29.5060
I hope this helps.
Fantastic. Thanks so much. Riveting the control handle to the kick panel seems sort of hokey. Plus I would need to get my carpet bound at the hole where it comes through.
HouseofGhia Premium Member
HouseofGhia is offline
PostPosted: Tue Jun 10, 2025 1:52 pm    Post subject: Re: floor vent covers Reply with quote
Heiferman wrote:
Steelz21 wrote:
From CIP.1
Tariff 8708.29.5060
I hope this helps.
The Ghia vents are shorter than the Beetle ones, that's why yours touch the sill plates. I have several used Ghia specific ones, both cable and non-cable, here at House of Ghia. (503) 364-GHIA or www.HouseofGhia.com
House of Ghia, since 1980
We Speak Karmann Ghia!!
