SGKent  Samba Member
Joined: October 30, 2007 Posts: 42643 Location: at the beach
Bnanwel Samba Member
Joined: November 10, 2022 Posts: 280 Location: Ft Lauderdale
Posted: Sat Jun 14, 2025 7:52 pm Post subject: Re: Engine/Transmission removed where and how would you start? |
Do yourself or someone a future favor. Don’t put the bottom screws back in the firewall after you replace the tank. It makes it much easier if you have to go in again. _________________ ‘72 Karmann Ghia Conv.
‘73 Karmann Ghia Coupe
‘74 Karmann Ghia Coupe
‘70 Deluxe
‘72 Deluxe |
SGKent  Samba Member
Posted: Sat Jun 14, 2025 9:36 pm Post subject: Re: Engine/Transmission removed where and how would you start? |
On a 1977 it is easy to get to the bottom screws when the bus is on stands. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
poundman Samba Member
Joined: April 05, 2024 Posts: 426 Location: Sugar Land, Texas
Posted: Sun Jun 15, 2025 8:18 am Post subject: Re: Engine/Transmission removed where and how would you start? |
Bnanwel wrote: |
Do yourself or someone a future favor. Don’t put the bottom screws back in the firewall after you replace the tank. It makes it much easier if you have to go in again. |
I was thinking the same thing. However, I can't imagine getting the tank out without engine out. It was a struggle with both engine and trans out. But you are correct, if transmission is still in it will be attached to that bracket.
Or I could relocate to a more ideal spot that is accessible with hanger in place. _________________ -----------------------------------------
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas |
Posted: Sun Jun 15, 2025 8:32 am Post subject: Re: Engine/Transmission removed where and how would you start? |
After doing more research on tanks and senders. Here is what I understand and don't understand.
It appears my 72 has a unique tank only used for about 1.5 years 72 and part of 73. It is part number 211 201 075 H and has the barrel type sender that bolts in. 68-71 had barrel also. Later it was changed to float style used in bugs and is screw in top.
Questions I have.
I assume the 68-71 does not have the middle top filler vent? What about the other vents on each side? If get one of those I would need to retro fit the filler vent?
My fuel gauge works with barrel type senders, if retro fit a 73-74 (non FI), I will need to change my fuel gauge or put some adapter to make it work. I would still need to retro fit the top filler vent?
Are the barrel senders better than the floats? Or opposite?
Final question, how did the other years deal with filler vents?
So, i think my choice is:
1. Buy used tank and get it cleaned and fingers crossed. Seems like a crap shoot. It is still a 50 year old tank.
2. Buy the WW version and retro fit the filler vent. I assume WW has decent quality. The picture on there site actually appears to have the filler vent, I just can't see the 1 on each side that crosses over.
I am 100% going to cut an access port for sender for future. Based on the lottery system with senders I have been reading about on samba. I also want to find a charcoal canister solution for the venting. It is missing on my bus. _________________ -----------------------------------------
Sugar Land, Texas |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52847 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jun 15, 2025 9:59 am Post subject: Re: Engine/Transmission removed where and how would you start? |
The gas filler door moved aft in 72, it allows the sliding door to open fully with the nozzle in the neck. The 71 tank has all the other fittings, it just needs that extra larger one at the top middle to work with the long skinny filler tube used in 72/73. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jun 16, 2025 8:58 pm Post subject: Re: Engine/Transmission removed where and how would you start? |
I got my nose cone back from the machine shop today. They milled it 1mm per the instructions from Weddle. I installed the new metal ball joint also. I put a light coat of gasket maker between the transmission body and the thrust plate. Then I put a paper gasket between thrust plate and nose cone. The shifting seems very stiff and I am wondering if I should remove the paper gasket or if that is just the new ball joint. Maybe it was to loose before with the ball joint, I am not sure what is normal. Hard to tell without a proper shifter in the bus. Instructions for thrust plate says to don't need any paper gasket. I can't see how .3mm of paper would make that big of difference, but if I take apart I might leave out to test.
Also, I had to ream the new bushing I installed to get the shift rod back in.
Going to do some more shift testing.
Sugar Land, Texas |
SGKent  Samba Member
Posted: Mon Jun 16, 2025 9:38 pm Post subject: Re: Engine/Transmission removed where and how would you start? |
looks normal to me. Did the transmission hang on the shift rod at any time when you worked on it?
What kind of shifter do you have? _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Tue Jun 17, 2025 6:28 am Post subject: Re: Engine/Transmission removed where and how would you start? |
Test shifting by hand at the nosecone? Even a sloppy one is pretty stiff without the leverage of the shifter, just saying. _________________ ‘72 Karmann Ghia Conv.
‘70 Deluxe
‘72 Deluxe |
soissisc Samba Member
Joined: April 04, 2007 Posts: 755 Location: Western Pennsylvania
Posted: Tue Jun 17, 2025 7:02 am Post subject: Re: Engine/Transmission removed where and how would you start? |
When I opened mine up, the small end of the pin had a lot of slop in the U shaped bracket. I ended up replacing the U shaped bracket.
That might be something to check. _________________ Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up) |
Posted: Tue Jun 17, 2025 8:31 am Post subject: Re: Engine/Transmission removed where and how would you start? |
Bnanwel wrote: |
Test shifting by hand at the nosecone? Even a sloppy one is pretty stiff without the leverage of the shifter, just saying. |
This is what I am doing. I attached the coupler and tried to shift into each gear. I am able to do so for each gear, but like you say without the leverage of the shifter it is very stiff. So I guess I am in the ball park. I watched a youtube video and found this great reference. You can watch the video if you like.
https://youtu.be/mPK34dZRXi8?si=T-6ZenwraWSi4-Zp
Sugar Land, Texas |
Posted: Tue Jun 17, 2025 8:33 am Post subject: Re: Engine/Transmission removed where and how would you start? |
soissisc wrote: |
That might be something to check. |
Thanks, I will take it apart and check this before I add gear oil. I will also lube everything manually before final seal. I have a feeling the new ball joint which is metal is making it a little more stiff than before, which should be ok. _________________ -----------------------------------------
Sugar Land, Texas |
SGKent  Samba Member
Posted: Tue Jun 17, 2025 9:21 am Post subject: Re: Engine/Transmission removed where and how would you start? |
yes, it is very hard to shift without the shifter. That is normal. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Wed Jun 18, 2025 8:51 pm Post subject: Re: Engine/Transmission removed where and how would you start? |
Had my flywheel resurfaced and re-installed today. Now I am trying to replace the seal in the front behind the fan hub. How do I get this hub off? Bentley mentions a special tool. Can I use some time of puller?
Thanks
Sugar Land, Texas |
SGKent  Samba Member
Posted: Wed Jun 18, 2025 10:34 pm Post subject: Re: Engine/Transmission removed where and how would you start? |
use can use a really big thick washer from the big box store, cut it and slide it behind. Then the bolts turn in on it and press the hub off. There is a plate steel method below too. The hub may be on really tight so do not cheap out on the steel used or the case will be damaged. Be SURE to replace the o-ring on the back of that hub / nose of the crankshaft while it is apart or it will leak.
Tcash wrote: |
VW 185 For pressing off the hub of the fan from the crankshaft
Tcash wrote: |
Type 4 Fan hub Puller
VW 190 For installing the crankshaft seal in the crankshaft on the fan side
1. Plastic cap of the appropriate size, with an 8mm hole drilled in the center.
2. 8mm bolt long enough to thread into the crank>seal>plastic cap>nut
3. 8mm Nut
4. 8mm Washer
Assemble installation tool as follows.
Bolt>nut>washer>plastic cap>seal
Thread bolt into crankshaft. Then use nut to press the seal in. |
Posted: Thu Jun 19, 2025 6:33 am Post subject: Re: Engine/Transmission removed where and how would you start? |
Thanks for the ideas. I assume that the bolt will be enough to draw the hub back on the shaft. I have not send any pictures on where the o-ring fits in. Maybe once I get apart I will know better. I can take the seal to the hardware store to find the cap and maybe even a washer or at least some flat stock.
Maybe something like this would work, cut down
https://www.homedepot.com/p/Simpson-Strong-Tie-BP-.../100375300
Is there another o-ring on the back side of the fan between the fan and hub? _________________ -----------------------------------------
Sugar Land, Texas |
SGKent  Samba Member
Posted: Thu Jun 19, 2025 7:03 am Post subject: Re: Engine/Transmission removed where and how would you start? |
between the crank and hub 021 119 125 A
https://www.thesamba.com/vw/forum/viewtopic.php?p=8004130 _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Thu Jun 19, 2025 8:42 am Post subject: Re: Engine/Transmission removed where and how would you start? |
Thanks for the link and visual, I now see how it works. I did order that part from bus depot and I think it also came as part of a gasket kit I purchased also.
It will be interesting to see when I get apart if the o-ring is in place because I found an o-ring between fan and hub, which is not on the diagrams. Let's see.
I think I would need a washer at least 3inch or 76mm OD _________________ -----------------------------------------
Sugar Land, Texas |
SGKent  Samba Member
Posted: Thu Jun 19, 2025 9:09 am Post subject: Re: Engine/Transmission removed where and how would you start? |
poundman wrote: |
I think I would need a washer at least 3inch or 76mm OD |
There is a mandatory spacer between the fan and pulley but no o-ring. The o-ring sits on the crank nose, up against the hub. You can see it in the first photo in this thread. Black o-ring sitting right on the crank nose inside the seal. https://www.thesamba.com/vw/forum/viewtopic.php?t=649747&highlight=021+119+125 _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1609 Location: New Brunswick,Canada
