Swing axle rubber boots
phil60
phil60 is offline
PostPosted: Sun Jun 22, 2025 10:48 am    Post subject: Swing axle rubber boots Reply with quote
Just as a matter of interest - why must the join not point straight up? Various positions are recommended depending on whose advice you take - 3 o'clock / 9 o'clock, 2 o'clock / 10 o'clock etc but for some reason 12 o'clock is frowned upon. It seems the obvious position so why is that?
aquifer Premium Member
aquifer is offline
PostPosted: Sun Jun 22, 2025 10:54 am    Post subject: Re: Swing axle rubber boots Reply with quote
Because the joint/seam doesn’t expand. So when the car is raised and the rear wheels drop down, it puts strain on the boot and would probably cause it to pull off off the hub. I think it has to be 3:00 or 9:00, and not 10/2 for the same reason, but 10/2 is much better than 12/6. At 3/9, the joint can just bend and doesn’t need to stretch.
Edited to add: the only time I’ve ever done it, I did 3:00/9:00 and they’re still holding up after 25 years (or more). I’d be tempted to believe that 4:00/8:00 would be better than 10/2, because of how the boot needs to flex when the car is off the ground. It’s rare that the wheels would ever be very far “up”, but they’re down all the time when the car is lifted. I would think that 10/2 would still put plenty of stress on the seam. I’m pretty convinced that 3/9 is the best position. That way it never “pulls” on the seam, the seam simply flexes.
Parts needed:
Front & rear NOS or used OEM door panels for a '67 in the original Gazelle color (dark tan/light brown).
Also looking for used white headliner pieces, both perforated and non-perforated.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Jun 22, 2025 10:57 am    Post subject: Re: Swing axle rubber boots Reply with quote
Maybe because when the car is jacked up or on a lift and the axles unload and swing down this may put stress on the top of the boot and if your seam is there it might tear.
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jun 22, 2025 12:09 pm    Post subject: Re: Swing axle rubber boots Reply with quote
Yes the thick rubber seam area of the boot will not stretch or even compress as well as the thinner bubble shaped rest of the boot. Due to this the boot tears up sooner than later when installed in the vertical position.
While we do not totally agree with all the literature VW put out over the decades, in this we do, and is backed up with experience we have had with this.
Below from the workshop manual that is a must for any VW owner to have on hand!!
In Stereo, Where Available!
phil60
phil60 is offline
PostPosted: Sun Jun 22, 2025 1:17 pm    Post subject: Re: Swing axle rubber boots Reply with quote
That makes sense - thank you all for the explanation
Eric&Barb
PostPosted: Sun Jun 22, 2025 1:40 pm    Post subject: Re: Swing axle rubber boots Reply with quote
No worries!! That is why the vast amount of us crazies are here!
Personally got into VWs way before the whole internet thing. So got a lot of good info from manuals or busting something that should not have gotten busted. Thankfully the old timers that started out in the 1960s & 70s working on VWs that were generous to take some time out of their busy lives to pass on what they had learned to us. Wish could go back and thank everyone of them, have lost touch with a few, most are known to have passed on.....
When you can someday "Pay it forward". Just do be a little careful when you do. Remember Ted Bundy drove a beetle.....
Bobs67vwagen
PostPosted: Sun Jun 22, 2025 2:20 pm    Post subject: Re: Swing axle rubber boots Reply with quote
Eric and Barb some of us who started working on vws in the 1960s (like me) are still here and still working on them although not as quickly. Like you said we learned from trial and error and also from manuals. I still find it wonderful that I can go to the internet and have lots of first hand experience(like yourself) right at my fingertips. Charles Manson was also a vw guy!
EVfun Premium Member
EVfun is offline
PostPosted: Sun Jun 22, 2025 10:30 pm    Post subject: Re: Swing axle rubber boots Reply with quote
Personally I run them at 10 and 2 to the rear and install the axle boots dry. The swingaxles move up and forward and the suspension compresses, and down and forward as the suspension drops below zero camber. The idea is to bend the seam, but not compress or stretch it. If it is pointed below level (9 and 3) it may leak a little as it isn't a well clamped joint, nothing solid is backing the seam except the washers under the screws and nuts.
VW recommends 9 and 3 to the rear, and the use of sealant.
Wildthings wrote:
viiking
viiking is offline
PostPosted: Sun Jun 22, 2025 11:52 pm    Post subject: Re: Swing axle rubber boots Reply with quote
Me too. I was 12 when Dad bought home his blue 64 and then later the 68.
I don't know, but I think our generation "just had a go". There was no internet obviously and if you were rich you might have had a manual and lots of shiny tools.
All I know is that I made a lot of mistakes (which I paid for) but generally once made, I didn't repeat them. It's surprising how much learnt on one marque of cars just translated to other marques. I've lost count of how many cars I've had in my lifetime but I've learned a lot. Not saying I'm an expert, but I know some stuff.
Like a lot of technology, the skills on old cars are disappearing with time. So many trades and professions are not there anymore. For newer cars these days, very little is repairable anymore so all you do is replace things. When I open the hood on my electronic this and that daily driver, I realise I wouldn't be able to fix much on these new cars at all. Old cars are very simple and not complex at all like the newer vehicles.
To get it into perspective if I think back to the time my Dad bought home his 64 (i.e.60 odd years ago). When he bought that, 60 year old cars were those being made at the dawn of car building in the early 1900's. The same thing applied. The skills to keep those early cars had also probably disappeared by the 60's.
Now fast forward 60 years from now into the late 21st century, the fabulous state of the art cars we drive now will also be curiosities and probably no-one can be bothered to fix them either. The only difference will be that the information to do so, will be available over the internet or what it will morph into in the future.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Jun 23, 2025 8:28 am    Post subject: Re: Swing axle rubber boots Reply with quote
If you look closely at the boot before you install it, you will see the thickness is not the same all around. It is thinner/thicker at various "clock" positions. It was engineered to resist tearing and stretching for installation at 9/3.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
