Unusual (?) remote oil filter
bnam
bnam is offline
PostPosted: Mon Jun 23, 2025 10:39 pm    Post subject: Unusual (?) remote oil filter Reply with quote
I saw this filter set up in a car that was at our meet over the weekend. I've not seen this before. Anyone have any experience or knowledge about this filter?
It appears to have the input (?) from the T-adapter at the pressure switch location, and the return seems to be thru the stud that it is mounted on - which is one of the studs for the alternator stand.
Seems like a convenient setup that does not have any issue with exhaust clearance etc. and could be retrofitted more easily.
Byas
Click to view image
1952 Citroen TA 11BL
Molly HasaBeetle
Molly HasaBeetle is offline
PostPosted: Mon Jun 23, 2025 10:45 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
I don't know anything about it, but I want it. Very, very badly. That is beyond awesome! @_@
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jun 24, 2025 3:51 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Not unusual, they've been around for a number of years.
I forget it's origin.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Q-Dog
Q-Dog is offline
PostPosted: Tue Jun 24, 2025 8:23 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
That is a bypass filter, not full flow. Better than nothing, but not by much.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
MrGoodtunes
MrGoodtunes is offline
PostPosted: Tue Jun 24, 2025 8:25 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
When you change that filter, how do you avoid making a big mess?
Sure don't want oil on fan belt or crank pulley!
bsairhead
bsairhead is offline
PostPosted: Tue Jun 24, 2025 8:49 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
You need to park on a steep hill Laughing
Root_Werks
Root_Werks is offline
PostPosted: Tue Jun 24, 2025 9:22 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Kinda cool, haven't seen that before either.
When I set my timing, why do I flush, then take a pee?
Cusser
Cusser is offline
PostPosted: Tue Jun 24, 2025 10:19 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
When I was a mechanic at rental agency Sun Buggy Rentals in 1974-1975, some of our VW dune buggies had these, they are bypass filter systems, were made by Purolator #0014180008
https://www.classiccult.com/vw-bug-by-pass-oil-filter-nos.html
https://www.thesamba.com/vw/classifieds/detail.php?id=2606178
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Jun 24, 2025 1:15 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Cusser in your experience did these filters offer any real improvement over a stock VW system?
67rustavenger
67rustavenger is offline
PostPosted: Tue Jun 24, 2025 1:25 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Q-Dog wrote,
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Cusser
Cusser is offline
PostPosted: Tue Jun 24, 2025 2:17 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
I do not know, as the only engines we tore down and rebuilt were private customers' cars.
But we had maybe 50 rental dune buggies and maybe 10 VW sedans, and I remember most of the dune buggies had these filters on their engines. These buggies were built elsewhere and purchased by Sun Buggy Rentals, used a full-size VW pan, and sat four.
I would guess that such filters do help some, as particles suspended in the oil would get filtered out; it's just that some of the oil would go through the filter on each rpm, some would not, so any particles may not be caught by the filter as quickly as on a full-flow filter system. Remember that when oil is cold it goes through the relief valve system and doesn't get filtered even on a full-flow filter system.
Bobs67vwagen
PostPosted: Tue Jun 24, 2025 5:42 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Thanks for the reply Cusser as I had never seen one of those before. Maybe they were not very common on the East coast.
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Jun 25, 2025 8:44 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
A bypass filter was good enough for early Porsche 356 engines, so it must have done SOME good!
One comment about these was (emphasis mine):
The 356 oil filter is a bypass filter which means that it samples a portion of the oil with each pass and filters much smaller particles than can a full flow filter. Bypass filters don't need a bypass valve and use a different filter medium than full flow filters. Filtration of 95% of particles larger than 1 micron seems possible. There is probably a trade off between the filter particle bypass size and the flow, and probably an optimum for our engines.
Then again, if you want a really unconventional filet setup, go for one of these vintage filters!:
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Mikemck356
Mikemck356 is offline
PostPosted: Wed Jun 25, 2025 8:53 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Then there was the filter that used a roll of toilet paper.
KTPhil is offline
PostPosted: Wed Jun 25, 2025 9:12 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
That is the Stilco I posted above.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bobs67vwagen
PostPosted: Wed Jun 25, 2025 9:48 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
I wonder how long Stilco stayed in business with a " lifetime guarantee" on this?
NJ John
NJ John is offline
PostPosted: Wed Jun 25, 2025 11:26 am    Post subject: Re: Unusual (?) remote oil filter Reply with quote
Don’t know if that’s the Purolator system. I sold one, recently. There was a kit probably from Brazil that was available years ago. I think it went between the cooler and case. You had to trim the bottom of the fan shroud for it.
Edit: Found the pic of mine. It looks the same.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Cusser
Cusser is offline
PostPosted: Wed Jun 25, 2025 12:09 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
What kind of crap was that?
Mr. 010
Glenn is offline
PostPosted: Wed Jun 25, 2025 12:17 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
https://www.frantzfilters.com/
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
halfassleatherworks
PostPosted: Wed Jun 25, 2025 1:07 pm    Post subject: Re: Unusual (?) remote oil filter Reply with quote
As good as a full flow? No, but Better then a screen? Yes, and it will filter the oil as long as the Engine is running, it is hooked to the main oil supply before the bypass.
