Newbe66 Samba Member
Posted: Fri Jun 27, 2025 12:22 pm Post subject: Tire size recomendation ?? |
I purchased a set of Foosh wheels in 17" with 4.5 wide in the front for my 66 Beetle
The recommended tire size is 155-50-17 or 165-50-17
I can't find either size !
Is anyone running these JBW wheels and can suggest a source or if they are running wider wheels in the front ?
It is a Porsche lug pattern with 2.5 drop disc spindles
Thanks |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1631 Location: San Diego
Posted: Fri Jun 27, 2025 1:22 pm Post subject: Re: Tire size recomendation ?? |
The sizes they are recommending are equal to or narrower than the stock 165/80-15 size. Check out this calculator and play around with different sizes to see what options will give you a wider width tire. I'm not sure how much wider you could go on a 4.5 wheel and when you'd start running into rubbing issues on the inner fender and outer edge. Keep in mind that the offset on those new wheels will be a factor to consider as will any offset on a disc brake kit if you have that installed.
https://tiresize.com/calculator/ _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2332 Location: Vancouver, BC
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23592 Location: Oklahoma City
Posted: Fri Jun 27, 2025 2:02 pm Post subject: Re: Tire size recomendation ?? |
The widest tire you will be able to get on a 4.5" rim will be a 185mm.
BUT...whether it actually fits safely will also depend on the sidewall profile. Most sites and calculators will say a 185/70 is pretty much the lowest sidewall series and widest tire that willSAFELY fit on a 4.5" rim.
When you get to 185/60...most will move you to a 5" rim.
Ray |
EVfun  Samba Member
Posted: Fri Jun 27, 2025 10:59 pm Post subject: Re: Tire size recomendation ?? |
I'm not really seeing any 17 inch diameter tires less than 195mm in width, except for temporary spares. A P195/60R17 tire would be 26.2 inches tall (slightly taller than stock) and manufacturers says it requires a rim width of at least 5.5 inches.
One manufacture seems to have a slightly narrower width in the recommend rim width range, the Toyo tire from Discount Tire. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
