busdaddy Samba Member
Joined: February 12, 2004 Posts: 52924 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 17, 2025 8:06 am Post subject: Re: The Stupid Question Thread |
KentABQ wrote: |
Yes, the smoke test has been done, and everything is now sealed correctly. |
Yet the whistle persists? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KentABQ  Samba Member
Joined: September 11, 2016 Posts: 2491 Location: Albuquerque NM
Posted: Thu Jun 19, 2025 5:33 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
KentABQ wrote: |
Yet the whistle persists? |
Yes.
The smoke generator produces a very low pressure.
So I will try connecting the air pressure (starting at a very low setting) to the vacuum system directly and see what I get.
But not sure if it will replicate the sound though since it's created by a vacuum.
And it's time to replace the ignition switch. The last one lasted almost six years,which I understand is very good for the new ones. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1654 Location: New Brunswick,Canada
wagen19 Samba Member
Joined: November 16, 2007 Posts: 750 Location: germany
Posted: Thu Jun 19, 2025 7:52 am Post subject: Re: The Stupid Question Thread |
lil-jinx wrote: |
could that squeal be from the distributor ? |
You mean missing grease on fiber part of points / shaft?
Remembering, yes, that can make loud noise.
One good drop of oil inside the center of the dizzy-shaft can also be a good thing.
Vacuum hoses around and to air filter? |
Posted: Thu Jun 19, 2025 3:15 pm Post subject: Re: The Stupid Question Thread |
wagen19 wrote: |
lil-jinx wrote: |
I hadn't thought of that possibly being the problem.
While I'm pretty regular at adding a drop of oil on the dizzy shaft, it doesn't hurt to add a few more. So I did, but no change with the squeal. Thanks for the idea!
I have also wiggled all the vacuum hoses many times and smoke tested them, so I'm pretty sure they're not leaking.
Now another issue popped up this week...
When I would turn the key to the start position, the dash lights would come on, but no click, no crank, no nothing. But every five to ten tries, it would finally crank and start up normally.
Since the ignition switch is about six years old, I replaced it with a new one that I had bought at the same time as the one I removed.
But the same no-start issue remains, with it taking numerous turns of the key before starting.
Is it possible the lock cylinder needs to be replaced?
Or am I missing something else? _________________ -Kent-
---williamM |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 1949 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Thu Jun 19, 2025 3:37 pm Post subject: Re: The Stupid Question Thread |
hey kent,
i’ve only got the obvious.
battery voltage?
amp draw on the battery when trying to start?
hope you sort it out, and get back on the road in that sweet bus. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
not starting? is it cranking and not starting or is it not cranking,check the starter for power at the s terminal while someone turns the key to the start position,chech all connections including grounds ,if no power going to the s terminal ,check the circuit back to the ignition switch, _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Thu Jun 19, 2025 4:16 pm Post subject: Re: The Stupid Question Thread |
Same result with a fresh switch says there's a loose or dirty connection somewhere in the chain, time for some wiring terminal fiddling.
The distributor squeak is often from the point rubbing block, but can also come from the bushings in rare cases. But the way the squeal drops off for s split second when you crack the throttle says to me it's vacuum. Maybe connect your shop vac to the manifold/S boot (throttle open) and pull a real vacuum on it to try and make it squeal, then you can listen with a tube to isolate and dribble non flammable liquids (water?) on suspect spots to listen for a change. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6541 Location: East Bay, CA
Posted: Thu Jun 19, 2025 5:14 pm Post subject: Re: The Stupid Question Thread |
Could the starting issue be the ground cable? _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
Posted: Thu Jun 19, 2025 5:15 pm Post subject: Re: The Stupid Question Thread |
NorCalWeekender wrote: |
Could the starting issue be the ground cable? |
Battery ground cable, that is. It was an issue on my 71 that took a while to realize. _________________ 9th Owner of a 1971 Tintop Westy
Posted: Thu Jun 19, 2025 5:39 pm Post subject: Re: The Stupid Question Thread |
Yes it could, one single broken link in the chain can cause a no start, each end of each main cable as well as the transmission strap, and all the connections on the starter can be an issue if any single one is dirty or loose.
And no "looking at them" either, physically unbolt it, shine it up if there's any white or grey stuff and reassemble with a fresh blob of grease spread around over all the parts that touch each other as you assemble. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 680 Location: On the coast in NZ, somewhere...
Posted: Sat Jun 21, 2025 12:59 pm Post subject: Re: The Stupid Question Thread |
Hopefully a quick one...
Taking my case to the machinist this week to have the bores checked and for cleaning...
Is it best / polite to take it to them with the case halves bolted together for checking the bores? All the fasteners, or just the six main bearing bolts?
Type 4 case - thanks! _________________ '73 westy, 1700 type 4 with 34icts |
Posted: Sat Jun 21, 2025 2:16 pm Post subject: Re: The Stupid Question Thread |
The six main bolts (properly torqued) are all you need. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jun 21, 2025 4:13 pm Post subject: Re: The Stupid Question Thread |
Thanks BD, much appreciated. _________________ '73 westy, 1700 type 4 with 34icts |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4648 Location: Pasadena CA/DTLA soon China
Posted: Sat Jun 28, 2025 8:33 pm Post subject: Re: The Stupid Question Thread |
Whatythe difference between an H30/31 and a 34pict-3? I have seen both of them mentioned for 1600 bus engines.
Excuse my ignorance.
Martin
Allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
germansupplyscott Samba Member
Posted: Sun Jun 29, 2025 6:53 am Post subject: Re: The Stupid Question Thread |
30/31 is used on single port engines, 34 on dual port engines. '68-'70 Bus engines were single port. '71 Bus was dual port.
The bottom flange of the 30/31 where the carb mounts to the manifold is smaller. There are differences in the vacuum ports also. _________________ SL |
Posted: Sun Jun 29, 2025 12:04 pm Post subject: Re: The Stupid Question Thread |
germansupplyscott wrote: |
The bottom flange of the 30/31 where the carb mounts to the manifold is smaller. There are differences in the vacuum ports also. |
Like always, Thank You for the information,
Martin Serrano
allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Mon Jun 30, 2025 8:43 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
Same result with a fresh switch says there's a loose or dirty connection somewhere in the chain, time for some wiring terminal fiddling. |
Once again you nailed it, BusDaddy.
I went thru and cleaned/tightened all the connections, and it started right up.
So I replaced a good ignition switch with another good ignition switch.
dodger tom wrote: |
hey kent,
battery voltage?
hope you sort it out, and get back on the road in that sweet bus. |
Thanks Tom.
I also checked the voltage which was a little low, so stuck the charger on for a few hours. _________________ -Kent-
---williamM |
Posted: Mon Jun 30, 2025 12:11 pm Post subject: Re: The Stupid Question Thread |
Finally getting to the point with my rebuild where I seriously have to look at sourcing some main engine bearings.
One of the sets I've come across - which looks on first glance to be better quality, but who knows - is advertised as having oversized thrust, but there isn't a number on it.
My assumption (yes, I know, root of all f*ck ups) is that this means an oversized thrust surface, as opposed to a bearing which is wider (fore-aft?) than standard to take up excess endplay.
Am I on the right lines? _________________ '73 westy, 1700 type 4 with 34icts |
